odbx delete entities in a layer
(1/1)
dgpuertas:
I want to use odbx (thanks a lot, lee for this amazing code http://www.lee-mac.com/odbxbase.html)
To delete all entities in a specific layer.
I can't use ssget
How can I do?
Thanks a lot.
Lee Mac:
Iterate over the blocks collection (which includes layouts), and then over the objects within each block (i.e. the objects in every block definition and layout), and use a conditional expression to test whether the object resides on the target layer, deleting if so.
Something like:
--- Code - Auto/Visual Lisp: ---(defun doit ( doc lyr ) (vlax-for blk (vla-get-blocks doc) (if (= :vlax-false (vla-get-isxref blk)) (vlax-for obj blk (if (and (= (strcase lyr) (vla-get-layer obj)) (vlax-write-enabled-p obj)) (vla-delete obj) ) ) ) )) (LM:odbx '(lambda ( doc ) (doit doc "YourLayer")) nil t)
Navigation
[0] Message Index
Go to full version
