Hello Everybody,
we need to import WMF files into BricsCAD via a lisp macro.
In AutoCAD we can use the WMFIN command, while in BricsCAD the same command is not available.
The IMPORT command is available in BricsCAD but it doesn't work with all WMF files but only with some
![cry :cry:](http://www.theswamp.org/Smileys/black/cry.gif)
I have already reported the problem to support but we can't wait for a solution.
Question: Do you know of any executable files (.exe) for use in lisp or dos prompt that can convert a WMF file to DXF or DWG or PDF?
Thank you.
