Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Replace Block Lisp
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Replace Block Lisp (Read 2452 times)
PM
Guest
Replace Block Lisp
on:
January 17, 2023, 05:46:02 AM »
Hi, I have two codes . One replace the block attributes and the other syntonize attributes
I found the second code
https://www.theswamp.org/index.php?topic=40756.0
is ronjonp post.
This two codes works fine , but I need help to join them to work as one code not two.
Code - Auto/Visual Lisp:
[Select]
defun
c:blk
mmst
master rl ss i en ed bn
while
not
master
and
princ
\n
Select MASTER Replacement BLOCK: "
setq
ss
ssget
list
cons
0
"INSERT"
sslength
ss
1
setq
master
strcase
cdr
assoc
2
entget
ssname
ss
0
princ
strcat
\n
master
while
and
princ
\n
Select BLOCKs To Replace: "
setq
ss
ssget
list
cons
0
"INSERT"
setq
i
0
while
setq
en
ssname
ss i
setq
ed
entget
en
bn
strcase
cdr
assoc
2
ed
cond
bn master
member
bn rl
setq
rl
cons
bn rl
setq
i
1+
i
foreach
e rl
and
setq
ss
ssget
"X"
list
cons
0
"INSERT"
cons
2
e
princ
strcat
\n
e
setq
i
0
while
setq
en
ssname
ss i
setq
ed
entget
en
entmod
subst
cons
2
master
assoc
2
ed
ed
setq
i
1+
i
command
"_.REGEN"
prin1
And ronjonp post
[Select]
defun
c:attsync2
_name _gettatts _lst atts e name ss
defun
_lst
ss
e n out
setq
n
1
if
type
ss
'pickset
while
setq
e
ssname
ss
setq
n
1+
n
setq
out
cons
vlax
ename
vla-object
e
out
defun
_attpositions
block
att result
foreach
att
vlax-invoke
block 'getattributes
setq
result
cons
list
vla-get-handle
att
vlax-get
att 'insertionpoint
vlax-get
att 'textalignmentpoint
result
defun
_name
b
cond
vlax-property-available-p
b 'effectivename
vla
get
effectivename b
b 'name
vla-get-name
b
if
and
setq
e
car
entsel
\n
Select block to sync: "
setq
name
_name
vlax
ename
vla-object
e
setq
ss
ssget
"_x"
list
cons
0
"insert"
progn
foreach
x
_lst ss
and
eq
_name x
name
setq
atts
cons
_attpositions x
atts
command
"._attsync"
"_s"
e
"_yes"
foreach
x
apply
append
atts
if
and
setq
e
handent
car
x
setq
e
vlax
ename
vla-object
e
progn
vl
catch
all
apply
vlax-put
list
e 'insertionpoint
cadr
x
vl
catch
all
apply
vlax-put
list
e 'textalignmentpoint
caddr
x
princ
Logged
ribarm
Gator
Marko Ribar, architect
WWW
Re: Replace Block Lisp
Reply #1 on:
January 17, 2023, 08:12:09 AM »
Unchecked, but should work...
[Select]
defun
c:blk
mmst
attsync
_lst _attpositions _name master rl ss i en ed bn atts e name
vl-load-com
defun
_lst
ss
e n out
setq
n
1
if
type
ss
quote
pickset
while
setq
e
ssname
ss
setq
n
1+
n
setq
out
cons
vlax
ename
vla-object
e
out
defun
_attpositions
block
att result
foreach
att
vlax-invoke
block
quote
getattributes
setq
result
cons
list
vla-get-handle
att
vlax-get
att
quote
insertionpoint
vlax-get
att
quote
textalignmentpoint
result
defun
_name
b
cond
b
quote
effectivename
vla
get
effectivename b
b
quote
name
vla-get-name
b
while
not
master
and
princ
\n
setq
ss
ssget
list
cons
0
"INSERT"
sslength
ss
1
setq
master
strcase
cdr
assoc
2
entget
ssname
ss
0
princ
strcat
\n
master
while
and
princ
\n
setq
ss
ssget
list
cons
0
"INSERT"
setq
i
0
while
setq
en
ssname
ss i
setq
ed
entget
en
bn
strcase
cdr
assoc
2
ed
cond
bn master
member
bn rl
setq
rl
cons
bn rl
setq
i
1+
i
foreach
e rl
and
setq
ss
ssget
"_X"
list
cons
0
"INSERT"
cons
2
e
princ
strcat
\n
e
setq
i
0
while
setq
en
ssname
ss i
setq
ed
entget
en
entmod
subst
cons
2
master
assoc
2
ed
ed
setq
i
1+
i
command
"_.REGEN"
if
and
setq
e
car
entsel
\n
setq
name
_name
vlax
ename
vla-object
e
setq
ss
ssget
"_X"
list
cons
0
"INSERT"
progn
foreach
x
_lst ss
and
eq
_name x
name
setq
atts
cons
_attpositions x
atts
command
"._attsync"
"_s"
e
"_yes"
foreach
x
apply
function
append
atts
if
and
setq
e
handent
car
x
setq
e
vlax
ename
vla-object
e
progn
vl
catch
all
apply
function
vlax-put
list
e
quote
insertionpoint
cadr
x
vl
catch
all
apply
function
vlax-put
list
e
quote
textalignmentpoint
caddr
x
princ
Logged
Marko Ribar, d.i.a.
(graduated engineer of architecture)
M.R. on Youtube
PM
Guest
Reply #2 on:
January 17, 2023, 11:09:11 AM »
Thanks ribarm
Logged
AVCAD
Newt
Reply #3 on:
August 01, 2023, 09:15:39 AM »
Is there any way to make this look at real block names not the *U ones for dynamic blocks.
I need to replace blocks that were not dynamic with new dynamic blocks?
Thanks in advance!
Logged
BIGAL
Swamp Rat
40 + years of using Autocad
Reply #4 on:
August 05, 2023, 12:21:13 AM »
When you get a "*U34" block you can get its property "Effectivename" using VL code.
Logged
cmwade77
Swamp Rat
Reply #5 on:
August 07, 2023, 05:13:40 PM »
Just as a heads up, AutoCAD 2024 has a command called BlockReplace that does this natively.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
Replace Block Lisp
