Author Topic: lwsdvts.lsp - problem with BricsCAD V23...  (Read 1481 times)
ribarm
  • Marko Ribar, architect
« on: January 12, 2023, 08:36:24 AM »
Hello...
I have coded this lisp that should do everything like PLDiet.lsp by Kent Cooper from Autodesk site, but applicable for all LWPOLYLINE standard types : straight and arced... Test it with my DWG... But I tried it in AutoCAD 2022 - it worked; tried it in BricsCAD V21 - it worked, but in BricsCAD V23 - it removed middle vertices only on single arced one LWPOLYLINE... What am I missing here, if I am missing ? I haven't done any magic thing with variables, but I just don't know, why this happens...
Anyway, if you find the code useful, you can use it...
  1. (defun c:lwsdvts ( / *error* ftoa groupbynum assocon tang prelst suflst foo process osm cmd ss ti i pl obj len )
  2.
  3.   (defun *error* ( m )
  4.     (if (= 8 (logand 8 (getvar (quote undoctl))))
  5.       (if command-s
  6.         (command-s "_.UNDO" "_E")
  7.         (vl-cmdf "_.UNDO" "_E")
  8.       )
  9.     )
  10.     (if cmd
  11.       (setvar (quote cmdecho) cmd)
  12.     )
  13.     (if osm
  14.       (setvar (quote osmode) osm)
  15.     )
  16.     (if m
  17.       (prompt m)
  18.     )
  19.     (princ)
  20.   )
  21.
  22.   (defun ftoa ( n / m a s b )
  23.     (if (numberp n)
  24.       (progn
  25.         (setq m (fix ((if (< n 0) - +) n 1e-8)))
  26.         (setq a (abs (- n m)))
  27.         (setq m (itoa m))
  28.         (setq s "")
  29.         (while (and (not (equal a 0.0 1e-6)) (setq b (fix (* a 10.0))))
  30.           (setq s (strcat s (itoa b)))
  31.           (setq a (- (* a 10.0) b))
  32.         )
  33.         (if (= (type n) (quote int))
  34.           m
  35.           (if (= s "")
  36.             m
  37.             (if (and (= m "0") (< n 0))
  38.               (strcat "-" m "." s)
  39.               (strcat m "." s)
  40.             )
  41.           )
  42.         )
  43.       )
  44.     )
  45.   )
  46.
  47.   (defun groupbynum ( lst n / sub lll )
  48.
  49.     (defun sub ( m n / ll q )
  50.       (cond
  51.         ( (and m (< (length m) n))
  52.           (repeat (- n (length m))
  53.             (setq m (append m (list nil)))
  54.           )
  55.           (setq ll (vl-remove-if-not (function (lambda ( x ) (setq q (if (not q) 0 (1+ q))) (< q n))) m))
  56.           (setq lll (cons ll lll))
  57.           (setq q nil)
  58.           (sub (vl-remove-if (function (lambda ( x ) (setq q (if (not q) 0 (1+ q))) (< q n))) m) n)
  59.         )
  60.         ( m
  61.           (setq ll (vl-remove-if-not (function (lambda ( x ) (setq q (if (not q) 0 (1+ q))) (< q n))) m))
  62.           (setq lll (cons ll lll))
  63.           (setq q nil)
  64.           (sub (vl-remove-if (function (lambda ( x ) (setq q (if (not q) 0 (1+ q))) (< q n))) m) n)
  65.         )
  66.         ( t
  67.           (reverse lll)
  68.         )
  69.       )
  70.     )
  71.
  72.     (sub lst n)
  73.   )
  74.
  75.   (defun assocon ( searchterm lst func fuzz )
  76.     (car
  77.       (vl-member-if
  78.         (function (lambda ( pair )
  79.           (equal searchterm (func pair) fuzz)
  80.         ))
  81.         lst
  82.       )
  83.     )
  84.   )
  85.
  86.   (defun tang ( a )
  87.     (if (not (equal (cos a) 0.0 1e-8))
  88.       (/ (sin a) (cos a))
  89.       (if (minusp (cos a))
  90.         -1e+308
  91.         1e+308
  92.       )
  93.     )
  94.   )
  95.
  96.   (defun prelst ( lst el index / f n )
  97.     (vl-remove-if
  98.       (function (lambda ( a )
  99.         (setq n (if (not n) 0 (1+ n)))
  100.         (cond
  101.           ( el
  102.             (if (equal a el 1e-6)
  103.               (not (setq f t))
  104.               f
  105.             )
  106.           )
  107.           ( index
  108.             (if (= index n)
  109.               (not (setq f t))
  110.               f
  111.             )
  112.           )
  113.         )
  114.       ))
  115.       lst
  116.     )
  117.   )
  118.
  119.   (defun suflst ( lst el index / f n )
  120.     (setq f t)
  121.     (vl-remove-if
  122.       (function (lambda ( a )
  123.         (setq n (if (not n) 0 (1+ n)))
  124.         (cond
  125.           ( el
  126.             (if (equal a el 1e-6)
  127.               (setq f nil)
  128.             )
  129.           )
  130.           ( index
  131.             (if (= index n)
  132.               (setq f nil)
  133.             )
  134.           )
  135.         )
  136.         f
  137.       ))
  138.       lst
  139.     )
  140.   )
  141.
  142.   (defun foo ( pl pt par / plx bul parp ptp bulp a1 r1 c1 parn ptn a2 r2 c2 bulpn pll pllp plls plll )
  143.     (gc)
  144.     (if
  145.       (and
  146.         pl (not (vlax-erased-p pl)) (= (type pl) (quote ename)) (= "LWPOLYLINE" (cdr (assoc 0 (setq plx (entget pl)))))
  147.         pt (= (type pt) (quote list)) (vl-every (function numberp) pt)
  148.         par (= (type par) (quote real))
  149.         (> (length (vl-remove-if (function (lambda ( x ) (/= (car x) 10))) plx)) 2)
  150.       )
  151.       (progn
  152.         (setq pt (trans pt 0 pl))
  153.         (setq pt (mapcar (function +) (list 0.0 0.0) pt))
  154.         (setq bul (cdr (assoc 42 (vl-member-if (function (lambda ( x ) (equal x (assocon pt plx cdr 1e-6) 1e-6))) plx))))
  155.         (setq parp (1- par))
  156.         (setq ptp (vlax-curve-getpointatparam pl parp))
  157.         (setq ptp (trans ptp 0 pl))
  158.         (setq ptp (mapcar (function +) (list 0.0 0.0) ptp))
  159.         (setq bulp (cdr (assoc 42 (vl-member-if (function (lambda ( x ) (equal x (assocon ptp plx cdr 1e-6) 1e-6))) plx))))
  160.         (if (/= bulp 0.0)
  161.           (progn
  162.             (setq a1 (* 4.0 (atan bulp)))
  163.             (setq r1 (/ (distance ptp pt) (* 2 (sin (* 2 (atan bulp))))))
  164.             (setq c1 (polar ptp (+ (angle ptp pt) (- (/ pi 2.0) (* 2 (atan bulp)))) r1))
  165.             (if (/= bul 0.0)
  166.               (progn
  167.                 (setq parn (+ par 1.0))
  168.                 (setq ptn (vlax-curve-getpointatparam pl parn))
  169.                 (setq ptn (trans ptn 0 pl))
  170.                 (setq ptn (mapcar (function +) (list 0.0 0.0) ptn))
  171.                 (setq a2 (* 4.0 (atan bul)))
  172.                 (setq r2 (/ (distance pt ptn) (* 2 (sin (* 2 (atan bul))))))
  173.                 (setq c2 (polar pt (+ (angle pt ptn) (- (/ pi 2.0) (* 2 (atan bul)))) r2))
  174.                 (if (and (equal r1 r2 1e-6) (equal c1 c2 1e-6))
  175.                   (setq bulpn (tang (/ (+ a1 a2) 4.0)))
  176.                 )
  177.               )
  178.               (setq bulpn 0.0)
  179.             )
  180.           )
  181.           (setq bulpn 0.0)
  182.         )
  183.         (setq pll plx)
  184.         (setq pll (append (reverse (cdr (reverse (prelst pll (assocon pt pll cdr 1e-6) nil)))) (cdr ((if (assoc 91 pll) cddddr cdddr) (suflst pll (assocon pt pll cdr 1e-6) nil)))))
  185.         (setq pllp (reverse (cdr (reverse (prelst pll (assocon ptp pll cdr 1e-6) nil)))))
  186.         (setq plls (cdr (suflst pll (assocon ptp pll cdr 1e-6) nil)))
  187.         (setq plls (subst (cons 42 (if bulpn bulpn 0.0)) (assoc 42 plls) plls))
  188.         (setq plll (append pllp (list (assocon ptp pll cdr 1e-6)) plls))
  189.         (if (not (equal plx plll 1e-6))
  190.           (setq plll (subst (cons 90 (1- (cdr (assoc 90 plll)))) (assoc 90 plll) plll))
  191.         )
  192.         (entupd (cdr (assoc -1 (entmod plll))))
  193.       )
  194.     )
  195.   )
  196.
  197.   (defun process ( pl obj len / loop coords coordsn par pts f )
  198.     (gc)
  199.     (setq loop t)
  200.     (while loop
  201.       (setq pts (groupbynum coords 2))
  202.       (setq pts (cdr (reverse (cdr (reverse pts)))))
  203.       (foreach pt pts
  204.         (if command-s
  205.           (command-s "_.UNDO" "_G")
  206.           (vl-cmdf "_.UNDO" "_G")
  207.         )
  208.         (vl-catch-all-apply
  209.           (function foo)
  210.           (list
  211.             pl
  212.             (trans pt pl 0)
  213.             (setq par (float (fix (+ 1e-6 (vlax-curve-getparamatpoint pl (vlax-curve-getclosestpointto pl (trans pt pl 0)))))))
  214.           )
  215.         )
  216.         (if (not (equal len (vla-get-length obj) 1e-3))
  217.           (if command-s
  218.             (command-s "_.UNDO" 1)
  219.             (vl-cmdf "_.UNDO" 1)
  220.           )
  221.         )
  222.       )
  223.       (vla-update obj)
  224.       (cond
  225.         ( (/= (length coords) (length coordsn)) )
  226.         ( (and (not f) (= (length coords) (length coordsn)))
  227.           (setq f t)
  228.         )
  229.         ( t
  230.           (setq loop nil)
  231.         )
  232.       )
  233.     )
  234.   )
  235.
  236.   (or doc (setq doc (vla-get-activedocument cad)))
  237.   (or spc (setq spc (vla-get-block (setq alo (vla-get-activelayout doc)))))
  238.   (setq osm (getvar (quote osmode)))
  239.   (setvar (quote osmode) 0)
  240.   (setq cmd (getvar (quote cmdecho)))
  241.   (setvar (quote cmdecho) 0)
  242.   (if (= 8 (logand 8 (getvar (quote undoctl))))
  243.     (if command-s
  244.       (command-s "_.UNDO" "_E")
  245.       (vl-cmdf "_.UNDO" "_E")
  246.     )
  247.   )
  248.   (if command-s
  249.     (command-s "_.UNDO" "_M")
  250.     (vl-cmdf "_.UNDO" "_M")
  251.   )
  252.   (prompt "\nSelect LWPOLYLINE(S) on unlocked layer(s)...")
  253.   (if (setq ss (ssget "_:L" (list (cons 0 "LWPOLYLINE"))))
  254.     (progn
  255.       (setq ti (car (_vl-times)))
  256.       (repeat (setq i (sslength ss))
  257.         (gc)
  258.         (setq pl (ssname ss (setq i (1- i))))
  259.         (setq obj (vlax-ename->vla-object pl))
  260.         (setq len (vla-get-length obj))
  261.         (process pl obj len)
  262.       )
  263.       (prompt "\nElapsed time : ") (princ (ftoa (- (car (_vl-times)) ti))) (prompt " milliseconds...")
  264.       (prompt "\nFor UNDO - type \"UNDO\" - \"Back\" option...")
  265.     )
  266.   )
  267.   (*error* nil)
  268. )
  269.
Regards, M.R.
[EDIT] I just checked - it only works correct on BricsCAD V21.2.04 - for more recent versions it only clears single LWPOLY... [/EDIT]
« Last Edit: February 11, 2023, 05:20:46 PM by ribarm »
M.R. on Youtube
mhupp
Re: lwsdvts.lsp - problem with BricsCAD V23...
« Reply #1 on: January 12, 2023, 10:00:36 AM »
Have you asked BricsCAD? Here at work we are all on different versions. I have noticed some lisps work better on certain versions. then we use the same lisp on a different computer and it ends up crash the drawing. but only if things were done in a certain order. tried to recreate the error on the original Computer and it wouldn't crash. its probably how they are handling the lisp between version.
« Last Edit: January 12, 2023, 10:04:00 AM by mhupp »
ribarm
« Reply #2 on: January 12, 2023, 03:59:33 PM »
For segmentation and for testing, here is the one that implements vertices...
  1. (defun c:lwssegsavts ( / *error* add_vtx tttt wcs initvalueslst ucsf ti ss ii n dp i k lw p par )
  2.
  4.     (if wcs
  5.       (if ucsf
  6.         (exe (list "_.UCS" "_P"))
  7.       )
  8.     )
  9.     (while (= 8 (logand 8 (getvar (quote undoctl))))
  10.       (if (not (exe (list "_.UNDO" "_E")))
  11.         (if doc
  12.           (vla-endundomark doc)
  13.         )
  14.       )
  15.     )
  16.     (if initvalueslst
  17.       (mapcar (function apply_cadr->car) initvalueslst)
  18.     )
  19.     (foreach fun (list (quote tttt) (quote vl-load) (quote exe) (quote cmdfun) (quote cmderr) (quote catch_cont) (quote apply_cadr->car) (quote ftoa))
  20.       (setq fun nil)
  21.     )
  22.     (if doc
  23.       (vla-regen doc acactiveviewport)
  24.     )
  25.     (if m
  26.       (prompt m)
  27.     )
  28.     (princ)
  29.   )
  30.
  31.   (defun add_vtx ( ent_name par / obj bulg sw ew )
  32.     (setq obj (vlax-ename->vla-object ent_name))
  33.     (vla-GetWidth obj (fix par) 'sw 'ew)
  34.       obj
  35.       (1+ (fix par))
  36.       (vlax-make-variant
  37.         (vlax-safearray-fill
  38.           (vlax-make-safearray vlax-vbdouble (cons 0 1))
  39.           (list
  40.             (car (trans (vlax-curve-getpointatparam obj par) 0 ent_name))
  41.             (cadr (trans (vlax-curve-getpointatparam obj par) 0 ent_name))
  42.           )
  43.         )
  44.       )
  45.     )
  46.     (setq bulg (vla-GetBulge obj (fix par)))
  47.     (vla-SetBulge obj
  48.       (fix par)
  49.       (/
  50.         (sin (/ (* 4 (atan bulg) (- par (fix par))) 4))
  51.         (cos (/ (* 4 (atan bulg) (- par (fix par))) 4))
  52.       )
  53.     )
  54.     (vla-SetBulge obj
  55.       (1+ (fix par))
  56.       (/
  57.         (sin (/ (* 4 (atan bulg) (- (1+ (fix par)) par)) 4))
  58.         (cos (/ (* 4 (atan bulg) (- (1+ (fix par)) par)) 4))
  59.       )
  60.     )
  61.     (vla-SetWidth obj (fix par) sw (+ sw (* (- ew sw) (- par (fix par)))))
  62.     (vla-SetWidth obj (1+ (fix par)) (+ sw (* (- ew sw) (- par (fix par)))) ew)
  63.     (vla-update obj)
  64.   )
  65.
  66.   (defun tttt ( wcs / sysvarpreset sysvarlst sysvarvals ) ;;; wcs (T/nil) ;;; cad, doc, alo, spc - global variables (Visual Lisp main VLA-OBJECT pointers) ;;; vl-load exe cmdfun cmderr catch_cont apply_cadr->car ftoa - library sub functions common for standard template initialization ;;;
  67.
  68.     (defun vl-load nil
  69.       (or cad
  70.           (setq cad (vlax-get-acad-object))
  71.           (progn
  72.             (vl-load-com)
  73.             (setq cad (vlax-get-acad-object))
  74.           )
  75.         )
  76.       )
  77.       (or doc (setq doc (vla-get-activedocument cad)))
  78.       (or alo (setq alo (vla-get-activelayout doc)))
  79.       (or spc (setq spc (vla-get-block alo)))
  80.     )
  81.
  82.     ;;; sometimes not needed to use/initialize AxiveX Visual Lisp extensions - (comment/uncomment) following line ;;;
  83.     (or (and cad doc alo spc) (vl-load))
  84.
  85.     (defun exe ( tokenslist )
  86.       ( (lambda ( tokenslist / ctch )
  87.           (if (vl-catch-all-error-p (setq ctch (cmdfun tokenslist t)))
  88.             (progn
  89.               (cmderr tokenslist)
  90.               (catch_cont ctch)
  91.             )
  92.             (progn
  93.               (while (< 0 (getvar (quote cmdactive)))
  94.                 (vl-cmdf "")
  95.               )
  96.               t
  97.             )
  98.           )
  99.         )
  100.         tokenslist
  101.       )
  102.     )
  103.
  104.     (defun cmdfun ( tokenslist flag / ctch ) ;;; tokenslist - command parameters list of strings ;;; flag - if "t" specified, upon successful execution returns t, otherwise if "nil" specified, return is always nil no matter what outcome of function execution is - it should be successful anyway if specified tokenslist was hardcoded correctly... ;;;
  105.       (if command-s
  106.         (if flag
  107.           (if (not (vl-catch-all-error-p (setq ctch (vl-catch-all-apply (function command-s) tokenslist))))
  108.             flag
  109.             ctch
  110.           )
  111.           (if (vl-catch-all-error-p (setq ctch (vl-catch-all-apply (function command-s) tokenslist)))
  112.             ctch
  113.           )
  114.         )
  115.         (if flag
  116.           (if (not (vl-catch-all-error-p (setq ctch (vl-catch-all-apply (function vl-cmdf) tokenslist))))
  117.             flag
  118.             ctch
  119.           )
  120.           (if (vl-catch-all-error-p (setq ctch (vl-catch-all-apply (function command) tokenslist)))
  121.             ctch
  122.           )
  123.         )
  124.       )
  125.     )
  126.
  127.     (defun cmderr ( tokenslist ) ;;; tokenslist - list of tokens representing command syntax at which used (cmdfun) failed with successful execution ;;;
  128.       (prompt (strcat "\ncommand execution failure... error at used command tokenslist : " (vl-prin1-to-string tokenslist)))
  129.     )
  130.
  131.     (defun catch_cont ( ctch / gr )
  132.       (prompt "\nleft mouse click to continue or enter to generate catch error - ESC to break...")
  133.       (while
  134.         (and
  135.           (vl-catch-all-error-p (or ctch (setq ctch (vl-catch-all-apply (function /) (list 1 0)))))
  136.           (setq gr (grread))
  137.           (/= (car gr) 3)
  138.           (not (equal gr (list 2 13)))
  139.         )
  140.       )
  141.       (if (vl-catch-all-error-p ctch)
  142.         ctch
  143.       )
  144.     )
  145.
  146.     (defun apply_cadr->car ( sysvarvaluepair / ctch )
  147.       (setq ctch (vl-catch-all-apply (function setvar) sysvarvaluepair))
  148.       (if (vl-catch-all-error-p ctch)
  149.         (progn
  150.           (prompt (strcat "\ncatched error on setting system variable : " (vl-prin1-to-string (vl-symbol-name (car sysvarvaluepair))) " with value : " (vl-prin1-to-string (cadr sysvarvaluepair))))
  151.           (catch_cont ctch)
  152.         )
  153.       )
  154.     )
  155.
  156.     (defun ftoa ( n / m a s b )
  157.       (if (numberp n)
  158.         (progn
  159.           (setq m (fix ((if (< n 0) - +) n 1e-8)))
  160.           (setq a (abs (- n m)))
  161.           (setq m (itoa m))
  162.           (setq s "")
  163.           (while (and (not (equal a 0.0 1e-6)) (setq b (fix (* a 10.0))))
  164.             (setq s (strcat s (itoa b)))
  165.             (setq a (- (* a 10.0) b))
  166.           )
  167.           (if (= (type n) (quote int))
  168.             m
  169.             (if (= s "")
  170.               m
  171.               (if (and (= m "0") (< n 0))
  172.                 (strcat "-" m "." s)
  173.                 (strcat m "." s)
  174.               )
  175.             )
  176.           )
  177.         )
  178.       )
  179.     )
  180.
  181.     (setq sysvarpreset
  182.       (list
  183.         (list (quote cmdecho) 0)
  184.         (list (quote 3dosmode) 0)
  185.         (list (quote osmode) 0)
  186.         (list (quote unitmode) 0)
  187.         (list (quote cmddia) 0)
  188.         (list (quote ucsvp) 0)
  189.         (list (quote ucsortho) 0)
  190.         (list (quote projmode) 0)
  191.         (list (quote orbitautotarget) 0)
  192.         (list (quote insunits) 0)
  193.         (list (quote hpseparate) 0)
  194.         (list (quote hpgaptol) 0)
  195.         (list (quote halogap) 0)
  196.         (list (quote edgemode) 0)
  197.         (list (quote pickdrag) 0)
  198.         (list (quote qtextmode) 0)
  199.         (list (quote dragsnap) 0)
  200.         (list (quote angdir) 0)
  201.         (list (quote aunits) 0)
  202.         (list (quote limcheck) 0)
  203.         (list (quote gridmode) 0)
  204.         (list (quote nomutt) 0)
  205.         (list (quote apbox) 0)
  206.         (list (quote attdia) 0)
  207.         (list (quote blipmode) 0)
  208.         (list (quote copymode) 0)
  209.         (list (quote circlerad) 0.0)
  210.         (list (quote filletrad) 0.0)
  211.         (list (quote filedia) 1)
  212.         (list (quote autosnap) 1)
  213.         (list (quote objectisolationmode) 1)
  214.         (list (quote highlight) 1)
  215.         (list (quote lispinit) 1)
  216.         (list (quote layerpmode) 1)
  217.         (list (quote fillmode) 1)
  218.         (list (quote dragmodeinterrupt) 1)
  219.         (list (quote dispsilh) 1)
  220.         (list (quote fielddisplay) 1)
  221.         (list (quote deletetool) 1)
  222.         (list (quote delobj) 1)
  223.         (list (quote dblclkedit) 1)
  224.         (list (quote attreq) 1)
  225.         (list (quote explmode) 1)
  226.         (list (quote frameselection) 1)
  227.         (list (quote ltgapselection) 1)
  228.         (list (quote pickfirst) 1)
  229.         (list (quote plinegen) 1)
  230.         (list (quote plinetype) 1)
  231.         (list (quote peditaccept) 1)
  232.         (list (quote solidcheck) 1)
  233.         (list (quote visretain) 1)
  234.         (list (quote regenmode) 1)
  235.         (list (quote celtscale) 1.0)
  236.         (list (quote ltscale) 1.0)
  237.         (list (quote osnapcoord) 2)
  238.         (list (quote grips) 2)
  239.         (list (quote dragmode) 2)
  240.         (list (quote lunits) 2)
  241.         (list (quote pickstyle) 3)
  242.         (list (quote navvcubedisplay) 3)
  243.         (list (quote pickauto) 3)
  244.         (list (quote draworderctl) 3)
  245.         (list (quote expert) 5)
  246.         (list (quote auprec) 6)
  247.         (list (quote luprec) 6)
  248.         (list (quote pickbox) 6)
  249.         (list (quote aperture) 6)
  250.         (list (quote osoptions) 7)
  251.         (list (quote dimzin) 8)
  252.         (list (quote pdmode) 35)
  253.         (list (quote pdsize) -1.5)
  254.         (list (quote celweight) -1)
  255.         (list (quote cecolor) "BYLAYER")
  256.         (list (quote celtype) "ByLayer")
  257.         (list (quote clayer) "0")
  258.       )
  259.     )
  260.     (setq sysvarlst (mapcar (function car) sysvarpreset))
  261.     (setq sysvarvals (mapcar (function cadr) sysvarpreset))
  262.     (setq sysvarvals
  263.       (vl-remove nil
  264.         (mapcar
  265.           (function (lambda ( x )
  266.             (if (getvar x) (nth (vl-position x sysvarlst) sysvarvals))
  267.           ))
  268.           sysvarlst
  269.         )
  270.       )
  271.     )
  272.     (setq sysvarlst
  273.       (vl-remove-if-not
  274.         (function (lambda ( x )
  275.           (getvar x)
  276.         ))
  277.         sysvarlst
  278.       )
  279.     )
  280.     (setq initvalueslst
  281.       (apply (function mapcar)
  282.         (cons (function list)
  283.           (list
  284.             sysvarlst
  285.             (mapcar (function getvar) sysvarlst)
  286.           )
  287.         )
  288.       )
  289.     )
  290.       (cons (function setvar)
  291.         (list
  292.           sysvarlst
  293.           sysvarvals
  294.         )
  295.       )
  296.     )
  297.     (while (= 8 (logand 8 (getvar (quote undoctl))))
  298.       (if (not (exe (list "_.UNDO" "_E")))
  299.         (if doc
  300.           (vla-endundomark doc)
  301.         )
  302.       )
  303.     )
  304.     (if (not (exe (list "_.UNDO" "_M")))
  305.       (if doc
  306.         (vla-startundomark doc)
  307.       )
  308.     )
  309.     (if wcs
  310.       (if (= 0 (getvar (quote worlducs)))
  311.         (progn
  312.           (exe (list "_.UCS" "_W"))
  313.           (setq ucsf t)
  314.         )
  315.       )
  316.     )
  317.     wcs
  318.   )
  319.
  320.   (setq wcs (tttt nil))
  321.   (initget 7)
  322.   (setq n (getint "\nSpecify number of points along each segment without start/end points that will be also processed : "))
  323.   (prompt "\nSelect LWPOLYLINE(S) on unlocked layer(s)...")
  324.   (if (setq ss (ssget "_:L" (list (cons 0 "LWPOLYLINE"))))
  325.     (progn
  326.       (setq ti (car (_vl-times)))
  327.       (repeat (setq ii (sslength ss))
  328.         (setq lw (ssname ss (setq ii (1- ii))))
  329.         (setq i 0 k 0)
  330.         (repeat (fix (vlax-curve-getendparam lw))
  331.           (setq k (1+ k))
  332.           (repeat (1+ n)
  333.             (setq dp (/ 1.0 (- (* k (1+ (float n))) i)))
  334.             (setq p (vlax-curve-getpointatparam lw (+ i dp)))
  335.             (setq par (vlax-curve-getparamatpoint lw p))
  336.             (if (not (equal par (fix par) 1e-6))
  337.               (progn
  338.                 (add_vtx lw par)
  339.                 (setq i (1+ i))
  340.               )
  341.               (setq i (1+ i))
  342.             )
  343.           )
  344.         )
  345.       )
  346.       (prompt "\nElapsed time : ") (princ (ftoa (- (car (_vl-times)) ti))) (prompt " milliseconds...")
  347.     )
  348.   )
  349.   (*error* nil)
  350. )
  351.
HTH.
M.R.
M.R. on Youtube
ribarm
« Reply #3 on: January 13, 2023, 10:06:35 AM »
Just to inform, lwsdvts.lsp has worked with only single pass... Just checked - after single pass it could happen that some middle vertices, or vertex remains, so I've decided to do (reversecurve lw), do another pass and put it back like it was before with another (reversecurve lw)... And after checking it worked - it removed all that should... So this routine attached to first post is better than PLDiet.lsp by Kent Cooper... So look into first post *.lsp is attached as it had more than 20000 chars...
[EDIT] I've shorten it as some things repeated - it comes less than 20000 chars, so still a file and the code fully correct [/EDIT]
Regards, M.R.
« Last Edit: January 13, 2023, 10:26:50 AM by ribarm »
M.R. on Youtube
ribarm
« Reply #4 on: February 07, 2023, 03:06:36 PM »
Have anyone found a solution for "lwsdvts.lsp" for BricsCAD V23 (x64)...
Thanks for your opinions...
M.R. on Youtube
BIGAL
  • 40 + years of using Autocad
« Reply #5 on: February 07, 2023, 10:12:00 PM »
Bricscad are very helpful with problems in code I contacted support about a problem to do with Alert and they supplied a work around till next version fixed. So post to them.
Just a real guess there was an update to all the Vlax calls I have V20 and lots are missing some 200+ were added in later versions. Just a guess.
ribarm
« Reply #6 on: February 10, 2023, 10:59:03 AM »
I've changed initial code, but the same - BricsCAD V21 - fine, AutoCAD 2022 - fine, BricsCAD V23 - not good...
And BTW. I don't know how to contact support - perhaps someone else is capable more than me... To me here in site, everything is visible - check-able...
M.R. on Youtube
danAllen
« Reply #7 on: February 10, 2023, 01:18:30 PM »
Post to forum? (needs forum login)
https://forum.bricsys.com/categories/programming-and-customization
Post a support request? (needs license login)
https://www.bricsys.com/protected/support/NewSupportRequest.do
I'm still running BC v15, so can't help
ribarm
« Reply #8 on: February 11, 2023, 12:34:29 PM »
The problem was the code after all... I've updated it in the first post and reattached *.lsp...
HTH.
M.R.
M.R. on Youtube
