Author Topic: Mleaders with rotated UCS?  (Read 2960 times)
framednlv
« on: January 09, 2023, 10:30:51 AM »
I have a drawing with a rotated ucs and a mleader with a keynote block.  The horizontal landing only works on one side, to the right, but not to the other side.
Can anyone help with a fix for this?
Attached is a sample dwg.
Re: Mleaders with rotated UCS?
« Reply #1 on: January 09, 2023, 04:35:47 PM »
The Wipeout is making the Mleader act like that. Delete the wipeout from the block and it works as expected.
framednlv
« Reply #2 on: January 09, 2023, 05:27:38 PM »
I deleted the wipeout and that seems to help for that mleader style.
I still have the same issue with this one (no wipeout).
framednlv
« Reply #3 on: January 09, 2023, 05:28:36 PM »
Jeff,
I forgot to say thank you...
Thank you for taking the time to look at this.
« Reply #4 on: January 10, 2023, 11:21:02 AM »
You're welcome. For the RE-POD mleader style, I ran AUDIT and got this:
Auditing Entities Pass 1
Pass 1 800     objects auditedAcDbBlockTableRecord: "ML_POD"
                     XData Handle Unknown               Null
Pass 1 4200    objects audited
I thought this fixed it, the Mleader gets placed correctly but once it is dragged so it flips it then no longer works as it should. I have no explanation for this.
framednlv
« Reply #5 on: January 11, 2023, 02:12:05 PM »
Jeff,
Again, thanks for taking the time to look at this.
I was messing around with this a bit and noticed if I rotate the UCS just a bit more (0.0001) everything works fine.
Thanks,
Chris
