Author Topic: Error: no function definition: VLAX-ENAME->VLA-OBJECT  (Read 3022 times)
HasanCAD
« on: December 26, 2022, 04:35:44 AM »
Hi All,
I moved to new company, and they are using CAD2019.
While running a lisp gives this error
"Error: no function definition: VLAX-ENAME->VLA-OBJECT"I found this is a bug in CAD19 and needs to modify in register, but IT refuse to solve this issue and saying we can't modify the register.
So is there any other solution to solve this issue without modifying in register.
for example:
  1. (defun _value   (str / )
  2.   (while
  3.     (not
  4.       (if (and (setq entt (nentsel str))
  5.                (setq ATTr (car entt))
  6.                (member (vla-get-objectname (setq ATTr (vlax-ename->vla-object ATTr)))
  7.                        '("AcDbAttribute" "AcDbText" "*DIM*" "AcDbMText")))
  8.         ATTr (progn (princ str) nil))))
  9.   ATTr
  10.   )
It's Alive!
  • Retired
  • AKA Daniel
Re: Error: no function definition: VLAX-ENAME->VLA-OBJECT
« Reply #1 on: December 26, 2022, 06:24:56 AM »
maybe something like  :mrgreen:
  1.      'HandleToObject (vlax-make-variant (cdr (assoc 5 (entget  (car (entsel))))) vlax-vbString)))
  2.
or maybe
  1.
« Last Edit: December 26, 2022, 07:02:25 AM by Nigel Tufnel »
tombu
  • ByLayer=>Not0
« Reply #2 on: January 02, 2023, 10:34:01 PM »
Are you running AutoCAD 2019 on a MacOS?
Tom Beauford P.S.M.
« Reply #3 on: January 03, 2023, 10:58:18 AM »
  1. ;; Change this
  2. (member (vla-get-objectname (setq attr (vlax-ename->vla-object attr)))
  3.         '("AcDbAttribute" "AcDbText" "*DIM*" "AcDbMText")
  4. )
  5. ;; to this
  6. (wcmatch (cdr (assoc 0 (entget attr))) "ATTRIB,*DIM*,*TEXT")
It will return an ename rather vla object but you can still retrieve the "_value". Not sure why we're checking for *DIM*, if selecting text within a dimension it will return MTEXT.
« Last Edit: January 03, 2023, 11:04:49 AM by ronjonp »
