It's likely the self-intersecting areas of your polyline - using the
AREA command with the Object option, I receive an output different to both of your examples.
You can prove this by exploding the polyline, trimming/removing the overlapping lines to leave the 'islands' and then converting the result to a region:
Such region then has a consistent area of 805.4531.
