Author Topic: Current state of DWG Preview handler?  (Read 2896 times)
Peter2
« on: December 20, 2022, 11:46:12 AM »
I googled around to find some information of the DWG preview handler to display a "dynamic" preview in MS Explorer like this
https://ww3.cad.de/foren/ubb/uploads/Gigerota/pdf.jpg
(so I'm not talking about creating and viewing thumbnails)
Very old information says it was installed with previous AutoCAD version.
Semi old information says it was installed with "DWG TrueView"
Now it seemts that it is not available with Autocad nor DWG Trueview nor Bricscad.
is it right?
Or does someone knows a solution? Maybe with a 3rd party tool?
Thanks and regards
Peter2
Peter
BricsCAD V23
Peter2
Re: Current state of DWG Preview handler?
« Reply #1 on: December 27, 2022, 05:17:26 AM »
Seem to be a less viral topic ;-)
Does anyone know https://longbowsoftware.com/previewer ?
Good product? or not?
Peter
BricsCAD V23
trogg
« Reply #2 on: December 31, 2022, 03:01:20 PM »
I have had the Longbow Previewer for a few years now.
It does give a better preview than without it and gives you useful info about the file by simply previewing it.
However, after using it to preview DGN Microstation files where it lets you zoom and pan around the drawing, I wish that it would do that for DWG files. I do have MicroStation installed so I don't know if previewing DGN files in window explorer doest zoom and pan stuff without Longbow being installed...
The enlarged preview that it produces is static and is dependent on the last saved view when the file was closed. So there isn't much control in that realm. But I really like it and the price is reasonable.
Peter2
« Reply #3 on: January 09, 2023, 04:13:29 AM »
Thanks, trogg
they told me just now:
"Currently, it is raster based but we are moving to vector soon!"
I think I will try it..
Peter
BricsCAD V23
