Author Topic: Reverse ATTSYNC  (Read 1096 times)
Marc'Antonio Alessi
  • Marco
Reverse ATTSYNC
« on: December 17, 2022, 03:36:37 AM »
With ATTSYNC you can synchronize the attributes of a Block (INSERT) with its definition (BLOCK),
is it possible to synchronize the attributes of the definition (BLOCK) with the attributes of a Block (INSERT)?
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: Reverse ATTSYNC
« Reply #1 on: December 17, 2022, 04:06:17 PM »
Are you referring to something other than redefining the block definition ??
Called Kerry in my other life
I live at UTC + 13.00
Marc'Antonio Alessi
  • Marco
Re: Reverse ATTSYNC
« Reply #2 on: December 18, 2022, 03:21:07 AM »
If you use the Attsync command all Inserts will automatically change and will have 2 attributes like the definition,
the block with 1 attribute will not have 2 attributes but will always have one.
I correct myself: the block with 1 attribute will have 2 attributes - the new attrib have the defaoult value.
What I'm trying to do is: select one of the inserted blocks and just update the definition with the selected block's attributes
all other inserted blocks will not change.
