Author Topic: Sheet Set Manager - Hyperlink View Number - PDF  (Read 2670 times)
Matthew H
« on: December 15, 2022, 05:41:55 PM »
I am using "callout blocks" that use AutoCAD's fields functionality to hyperlink to "named views" and "sheet numbers" in CAD.
Currently all my hyperlinks work in CAD, but when I publish my drawings to PDF, only the "SheetNumber" hyperlinked text works and not the "ViewNumber" text.
I did verify that "Associate Hyperlinks" was enabled/checked.
I tried researching the issue, I did come across this post on the Autodesk Forums.
There was no working solution
https://forums.autodesk.com/t5/autocad-forum/publishing-hyperlinked-text-to-pdf-with-sheet-manager/td-p/8832815
Does anyone have a work flow to allow the "ViewNumber" hyperlink to work in a PDF.
This functionality would be nice to have in a PDF, as a callout can then zoom to a specific detail on a specific page.
Thanks in advance,
Matthew H.
« Last Edit: December 15, 2022, 05:45:24 PM by Matthew H »
Re: Sheet Set Manager - Hyperlink View Number - PDF
« Reply #1 on: December 16, 2022, 06:44:07 PM »
Not a direct answer to your question .. quick test and creating a named view then a hyperlink to it works in the PDF.
