I am using "callout blocks" that use AutoCAD's fields functionality to hyperlink to "named views" and "sheet numbers" in CAD.
Currently all my hyperlinks work in CAD, but when I publish my drawings to PDF, only the "SheetNumber" hyperlinked text works and not the "ViewNumber" text.
I did verify that "Associate Hyperlinks" was enabled/checked.
I tried researching the issue, I did come across this post on the Autodesk Forums.
There was no working solution
https://forums.autodesk.com/t5/autocad-forum/publishing-hyperlinked-text-to-pdf-with-sheet-manager/td-p/8832815Does anyone have a work flow to allow the "ViewNumber" hyperlink to work in a PDF.
This functionality would be nice to have in a PDF, as a callout can then zoom to a specific detail on a specific page.
Thanks in advance,
Matthew H.
