Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Osmode won't set/Line not visible during command
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Osmode won't set/Line not visible during command (Read 576 times)
jlogan02
Bull Frog
on:
December 12, 2022, 04:04:35 PM »
Can't seem to set the osmode to 39 during the command. I start by setting it to something other than 39, execute the command and whatever I set it to prior to execution remains.
Code - Auto/Visual Lisp:
[Select]
defun
c:foo
*error*
osm pt1 pt2
defun
*error*
msg
if
osm
setvar
'osmode osm
if
not
member
msg '
"Function cancelled"
"quit / exit abort"
princ
strcat
\n
Error: "
msg
princ
setq
osm
getvar
'osmode
setq
pt1
getpoint
\n
Specify first point"
setq
pt2
getpoint
\n
Specify next point"
setvar
'osmode
39
command
".line"
pt1 pt2
setvar
'osmode osm
princ
Also, the line doesn't appear after I pick the first point. It does when typing line at the command line.
Layer is not locked or frozen.
Layer is current.
Layer color does not match background.
Graphics performance turned off.
Logged
J. Logan
ACAD 2018
I am one with the Force and the Force is with me.
AutoCAD Map 2018 Windows 10
Seagull
London, England
WWW
Re: Osmode won't set/Line not visible during command
Reply #1 on:
December 12, 2022, 04:26:17 PM »
Note that you are acquiring the points using the
getpoint
expressions, hence the
OSMODE
would need to be set prior to these expressions. To display a "preview" you can supply the second
getpoint
expression with the first point, representing "rubber band" argument.
[Select]
defun
c:foo
*error*
osm pt1 pt2
defun
*error*
msg
if
osm
setvar
'osmode osm
if
not
member
msg '
"quit / exit abort"
princ
strcat
\n
Error: "
msg
princ
setq
osm
getvar
'osmode
setvar
'osmode
39
;; Set OSMODE here
if
and
setq
pt1
getpoint
\n
setq
pt2
getpoint
\n
Specify next point"
pt1
;; Supply rubber band argument
command
"_.line"
"_non"
pt1
"_non"
pt2
setvar
'osmode osm
princ
Logged
Lee Mac Programming
Twitter
Exchange App Store
jlogan02
Bull Frog
Reply #2 on:
December 12, 2022, 04:49:05 PM »
My first attempt had
[Select]
setvar
'osmode
36
where you have it, and it wasn't working, so I moved it to where the OP shows. Had I added the pt1 for rubber banding, I wouldn't have gotten the results I was getting, which was a fail.
Logged
J. Logan
ACAD 2018
jlogan02
Bull Frog
Reply #3 on:
December 12, 2022, 04:49:35 PM »
36...39...whatever.
Logged
J. Logan
ACAD 2018
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
