Author Topic: Stumped as usual  (Read 898 times)
Biscuits
Stumped as usual
« on: December 12, 2022, 02:22:16 PM »
Trying to move an object based on the angle and distance from 2 selected points.
Could some one tell me what I'm doing wrong? I'm gettin' too old for this snit!
(defun C:doit  ()
(setq p1(getpoint))
(setq p2(getpoint))
(setq dis (distance p1 p2))
(setq ang (angle p1 p2))
(command "move" "all" "" dis ang)
Re: Stumped as usual
« Reply #1 on: December 12, 2022, 04:22:31 PM »
By default the MOVE command is expecting two points (a base point and a new point relative to such base point); for these prompts, you are supplying two numerical values (AutoCAD does not know that such numbers represent distances & angles).
Personally, I would suggest the following approach:
  1. (defun c:doit ( / p1 p2 )
  2.     (if
  3.         (and
  4.             (setq p1 (getpoint "\n1st point: "))
  5.             (setq p2 (getpoint "\n2nd point: "))
  6.         )
  7.         (command "_.move" "_all" "" "_non" p1 "_non" p2)
  8.     )
  9.     (princ)
  10. )
Biscuits
« Reply #2 on: December 15, 2022, 08:40:20 AM »
Once again I owe you a big thank you. Nothing like overthinking it!
Merry Christmas LM!!
« Reply #3 on: December 15, 2022, 02:59:57 PM »
You're welcome!
Merry Christmas to you too!  :-)
MSTG007
« Reply #4 on: December 15, 2022, 05:20:50 PM »
how does Lee make it look so simple? lol. We sometime come up tons of lines of code, then someone gets it down to a few lines.
Merry Christmas you guys.
Civil3D 2020
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #5 on: December 15, 2022, 05:30:12 PM »
Practice, dedication and an inquiring mind , perhaps ?
Called Kerry in my other life
I live at UTC + 13.00
BIGAL
  • 40 + years of using Autocad
« Reply #6 on: December 15, 2022, 06:20:07 PM »
I agree "how does Lee make it look so simple? " helped me many times.
Next issue is speed, 1st go for a task 35 minutes, current version 2 minutes.
