Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Counter Clockwise only close polyline
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Counter Clockwise only close polyline (Read 1810 times)
PM
Guest
on:
November 20, 2022, 11:55:57 AM »
Hi. Fro mthe code bellow i use PL-CCWA (CounterClockwise ALL). Is it possible to reverse only the close polyline ?
Code - Auto/Visual Lisp:
[Select]
defun
C:PL
CW
Pl
CW
VVA
"_:L"
t
;;;Clockwise
defun
C:PL
CCW
Pl
CW
VVA
"_:L"
nil
;;;CounterClockwise
defun
C:PL
CWA
Pl
CW
VVA
"_ALL"
t
;;;Clockwise ALL
defun
C:PL
CCWA
Pl
CW
VVA
"_ALL"
nil
;;;CounterClockwise ALL
defun
C:PLI
CCW
Pl
CW
Irneb
"_:L"
nil
;;;CounterClockwise Irneb version
defun
C:PLI
CW
Pl
CW
Irneb
"_:L"
t
;;;Clockwise Irneb version
defun
Pl
CW
Irneb
mode what
int:i e1 res clk
ss
;;; posted Irneb
;;; url http://www.cadtutor.net/forum/showthread.php?59671-all-polylinienrichtungen-counterclockwise
;;; what - t Clockwise
;;; what - nil CounterClockwise
;;; mode - string for ssget "_:L" or "_ALL:
vl-load-com
or
pl
activedoc
setq
pl
activedoc
vla-get-activedocument
vlax-get-acad-object
vla-startundomark
pl
activedoc
princ
strcat
\n
if
what
"Clockwise mode"
"CounterClockwise mode"
" Select Polyline"
setq
ss
nil
ss
ssget
mode '
0
"*POLYLINE"
setq
int:i '
1
clk
0
while
and
ss
setq
e1
ssname
ss
setq
int:i
1+
int:i
if
vlax-write-enabled-p
vlax
ename
vla-object
e1
;_editable
if
what
;;;Reverse CounterClockwise->Clockwise
if
PL
CounterClockWise
p e1
progn
pl:geom
allpline
reverse
e1
setq
clk
1+
clk
;;;Reverse Clockwise->CounterClockwise
if
null
PL
CounterClockWise
p e1
progn
pl:geom
allpline
reverse
e1
setq
clk
1+
clk
princ
strcat
\n
Check "
itoa
int:i
" polyline."
princ
\n
\t
princ
clk
princ
if
what
\t
CounterClockwise (reverse)"
\t
princ
\n
\t
princ
int:i clk
princ
if
what
\t
Clockwise"
\t
CounterClockwise"
setq
ss
nil
vla-endundomark
pl
activedoc
princ
defun
Pl
CW
VVA
mode what
int:i e1 res clk
ss
;;; Posted VVA
;;; Url http://www.cadtutor.net/forum/showthread.php?59671-all-polylinienrichtungen-counterclockwise
vl-load-com
or
pl
activedoc
setq
pl
activedoc
vla-startundomark
pl
activedoc
princ
strcat
\n
if
what
"Clockwise mode"
" Select Polyline"
setq
ss
nil
ss
ssget
mode '
0
"*POLYLINE"
setq
int:i '
1
clk
0
while
and
ss
setq
e1
ssname
ss
setq
int:i
1+
int:i
if
what
if
null
pl:clockwise
p e1
progn
pl:geom
allpline
reverse
e1
setq
clk
1+
clk
if
pl:clockwise
p e1
progn
pl:geom
allpline
reverse
e1
setq
clk
1+
clk
princ
strcat
\n
Check "
itoa
int:i
" polyline."
princ
\n
\t
princ
clk
princ
if
what
\t
\t
princ
\n
\t
princ
int:i clk
princ
if
what
\t
Clockwise"
\t
CounterClockwise"
setq
ss
nil
vla-endundomark
pl
activedoc
princ
defun
pl:geom
allpline
reverse
pl
pln ret
if
type
pl
VLA-OBJECT
setq
pln
vlax
vla
object
ename pl
setq
pln pl
cond
pl:dxf
0
entget
pln
"LWPOLYLINE"
setq
ret
pl:geom
LWpolyline
revers pln
pl:dxf
0
entget
pln
"POLYLINE"
setq
ret
pl:geom
polyline
revers pln
t
setq
ret
nil
ret
defun
pl:geom
LWpolyline
revers
lw
e x1 x2 x3 x4 x5 x6
if
type
lw
VLA-OBJECT
setq
lw
vlax
vla
object
ename lw
setq
e
entget
lw
foreach
a1 e
cond
car
a1
10
setq
x2
cons
a1 x2
car
a1
40
setq
x4
cons
cons
41
cdr
a1
x4
car
a1
41
setq
x3
cons
cons
40
cdr
a1
x3
car
a1
42
setq
x5
cons
cons
42
cdr
a1
x5
car
a1
210
setq
x6
cons
a1 x6
t
setq
x1
cons
a1 x1
;_ end of cond
entmod
append
reverse
x1
append
apply
function
append
apply
function
mapcar
cons
list
list
x2
cdr
reverse
cons
car
x3
reverse
x3
cdr
reverse
cons
car
x4
reverse
x4
cdr
reverse
cons
car
x5
reverse
x5
;_ end of list
;_ end of cons
;_ end of apply
;_ end of apply
x6
;_ end of append
;_ end of append
;_ end of entmod
entupd
lw
;_ end of defun
defun
pl:geom
polyline
revers
ent_name
_dxf
code
data tmp_ent
i poly_ent
vert_ent vertex_list
bulge_list start_width_list
end_width_list
if
type
ent_name
VLA-OBJECT
setq
ent_name
vlax
vla
object
ename ent_name
;; Reverse "POLYLINE"
setq
tmp_ent ent_name
i
0
;_ end of setq
setq
bulge_list
nil
vertex_list
nil
start_width_list
nil
end_width_list
nil
while
not
"SEQEND"
pl:dxf
0
setq
tmp_ent
entnext
tmp_ent
;_ end of not
setq
bulge_list
cons
pl:dxf
42
tmp_ent
bulge_list
vertex_list
cons
entget
tmp_ent
vertex_list
start_width_list
cons
pl:dxf
40
tmp_ent
start_width_list
;_ end of cons
end_width_list
cons
pl:dxf
41
tmp_ent
end_width_list
i
1+
i
;_ end of setq
;_ end of while
setq
bulge_list
append
cdr
bulge_list
list
car
bulge_list
start_width_list
append
cdr
start_width_list
list
car
start_width_list
;_ end of append
end_width_list
append
cdr
end_width_list
list
car
end_width_list
;_ end of append
i
0
bulge_list
mapcar
lambda
x
0
x
bulge_list
tmp_ent ent_name
poly_ent
cdr
entget
tmp_ent '
;;;Added to revers with XData
poly_ent
subst
cons
40
car
end_width_list
assoc
40
poly_ent
poly_ent
;_ end of subst
poly_ent
subst
cons
41
last
start_width_list
assoc
41
poly_ent
poly_ent
;_ end of subst
;_ end of setq
entmakex
poly_ent
; polyline
while
not
"SEQEND"
pl:dxf
0
setq
tmp_ent
entnext
tmp_ent
;_ end of not
progn
setq
vert_ent
nth
i vertex_list
vert_ent
subst
cons
40
nth
i end_width_list
assoc
40
vert_ent
vert_ent
;_ end of subst
vert_ent
subst
cons
41
nth
i start_width_list
assoc
41
vert_ent
vert_ent
;_ end of subst
vert_ent
subst
cons
42
nth
i bulge_list
assoc
42
vert_ent
vert_ent
;_ end of subst
i
1+
i
;_ end of setq
entmakex
vert_ent
;_ end of progn
;_ end of while
entmakex
cdr
entget
tmp_ent
; seqend
entdel
ent_name
redraw
entlast
entlast
;_ end of defun
defun
pl:dxf
code lst
if
type
lst
'ENAME
setq
lst
entget
lst
cdr
assoc
code lst
;;; Function to test if polyline is counter-clock-wise
;;; obj= vla-object / ename of the polyline
;;; Result is nil if clockwise, T if counter-clockwise
defun
PL
CounterClockWise
p
obj
ang ang1 ang2 angT param
if
type
Obj
'ENAME
setq
Obj
vlax
ename
vla-object
Obj
setq
param
1.5
angT
0.0
ang1
angle
0.0
0.0
0.0
vlax-curve-getFirstDeriv
obj
0.5
while
param
vlax-curve-getEndParam
obj
setq
ang2
angle
0.0
0.0
0.0
obj param
setq
ang
ang2 ang1
if
abs
ang
pi
setq
ang
if
ang
0.0
1.0
1.0
abs
ang
pi
2
setq
angT
angT ang
ang1 ang2
param
1+
param
angT
0.0
defun
pl:clockwise
p
lw
LST MAXP MINP
if
type
lw
'ENAME
setq
lw
vlax
ename
vla-object
lw
vla-GetBoundingBox
lw 'MinP 'MaxP
setq
minp
vlax
safearray
list
minp
MaxP
vlax
safearray
list
MaxP
lst
mapcar
function
lambda
x
vlax-curve-getParamAtPoint
lw
vlax-curve-getClosestPointTo
lw x
list
minp
list
car
minp
cadr
MaxP
MaxP
list
car
MaxP
cadr
minp
if
or
car
lst
cadr
lst
caddr
lst
cadddr
lst
cadr
lst
caddr
lst
cadddr
lst
car
lst
caddr
lst
cadddr
lst
car
lst
cadr
lst
cadddr
lst
car
lst
cadr
lst
caddr
lst
t
nil
princ
\n
Type Pl-CW, PL-CWA (ClockWise) or PL-CCW, PL-CCWA (CounterClockWise) in command line"
princ
\n
For difficult cases with a polyline use PlI-CW (ClockWise) or PLI-CCW (CounterClockWise) in command line"
princ
Logged
mhupp
Bull Frog
Re: Counter Clockwise only close polyline
Reply #1 on:
November 20, 2022, 01:41:26 PM »
if you modified the The original code to only work on closed polylines it would affect the other commands to only work with closed polylines as well.
I made this to build a selection set of only closed polylines and feed it to the direction checker. if true use their reverse command. So keep the other lisp loaded.
[Select]
Defun
C:CCWALL
SS
if
setq
SS
ssget
"_A"
0
"*POLYLINE"
70
1
foreach
e1
vl
remove
if
listp
mapcar
cadr
ssnamex
SS
if
pl:clockwise
p e1
pl:geom
allpline
reverse
e1
Logged
PM
Guest
Reply #2 on:
November 20, 2022, 03:30:59 PM »
Thanks mhupp . I use the code works fine
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
