Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
ApplicationServices.Application VS ApplicationServices.Core.Application
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: ApplicationServices.Application VS ApplicationServices.Core.Application (Read 3271 times)
kdub_nz
Mesozoic keyThumper
SuperMod
Water Moccasin
class keyThumper<T>:ILazy<T>
on:
November 19, 2022, 05:11:59 PM »
Going through some of my older code :
I'm finding I have various Alias declarations for AcadApp :-
Code - C#:
[Select]
using
AcadApp
Autodesk
AutoCAD
ApplicationServices
Core
Application
and
Code - C#:
[Select]
using
AcadApp
Autodesk
AutoCAD
ApplicationServices
Application
I have a preference for the
simply because it's the base class for
. . . but I'm wondering if it really makes a difference either way.
Has anyone done any research on this, or have a reasoned opinion ??
Logged
Called Kerry in my other life
I live at UTC + 13.00
gile
Gator
Marseille, France
WWW
Re: ApplicationServices.Application VS ApplicationServices.Core.Application
Reply #1 on:
November 20, 2022, 02:24:39 AM »
I would tend to use :
Code - C#:
[Select]
using
AcAp
Autodesk
AutoCAD
ApplicationServices
Application
because the Autodesk.AutoCAD.ApplicationServices.Core.Application class does not expose some methods I commonly use such as ShowModal.Dialog which warrants an alias to avoid confusion with System.Windows.Forms.Application.
I don't think using ApplicationServices.Application where one could use ApplicationServices.Core.Application has any real impact on code execution.
But we can also use two aliases:
Code - C#:
[Select]
using
AcAp
Autodesk
AutoCAD
ApplicationServices
Application
using
AcCoreAp
Autodesk
AutoCAD
ApplicationServices
Core
Application
Logged
kdub_nz
Mesozoic keyThumper
SuperMod
Water Moccasin
Reply #2 on:
November 20, 2022, 02:38:14 AM »
Hi Gilles,
Sitting outside in the sunshine this afternoon I decided to go not us the Core.Application.
As you say, I too think the impact either way will be minimal.
I'll save my worrying for important things.
Logged
Retired
Needs a day job
AKA Daniel
WWW
Reply #3 on:
November 20, 2022, 03:09:20 AM »
I concur
I also dropped coding this morning to go out in the sunshine. Went to Singapore’s botanic garden
Last Edit: November 20, 2022, 03:13:20 AM by It's Alive!
Logged
https://github.com/CEXT-Dan/PyRx
https://pyarx.blogspot.com/
n.yuan
Bull Frog
Reply #4 on:
November 20, 2022, 09:17:19 AM »
Well, if you write code that is generally intent to be shared by possible core console/Forge (now, called Platform), you may want to make sure you only use ...Core.Application, because you do not use acmgd.dll in plugins for core console/Forge.
Logged
kdub_nz
Mesozoic keyThumper
SuperMod
Water Moccasin
Reply #5 on:
November 20, 2022, 03:10:27 PM »
Thanks Norman, I'll keep that in mind.
Regards,
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
