Author Topic: ApplicationServices.Application VS ApplicationServices.Core.Application  (Read 2428 times)
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Going through some of my older code :
I'm finding I have various Alias declarations for AcadApp :-
Code - C#: [Select]
  1. using AcadApp = Autodesk.AutoCAD.ApplicationServices.Core.Application;
and
Code - C#: [Select]
  1. using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
I have a preference for the  ApplicationServices.Core.Application simply because it's the base class for ApplicationServices.Application
. . . but I'm wondering if it really makes a difference either way.
Has anyone done any research on this, or have a reasoned opinion ??
Called Kerry in my other life
I live at UTC + 13.00
some people complain about loading the dishwasher
Sometimes the question is more important than the answer.[/i
gile
  • Marseille, France
Re: ApplicationServices.Application VS ApplicationServices.Core.Application
« Reply #1 on: November 20, 2022, 02:24:39 AM »
I would tend to use :
Code - C#: [Select]
  1. using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
because the Autodesk.AutoCAD.ApplicationServices.Core.Application class does not expose some methods I commonly use such as ShowModal.Dialog which warrants an alias to avoid confusion with System.Windows.Forms.Application.
I don't think using ApplicationServices.Application where one could use ApplicationServices.Core.Application has any real impact on code execution.
But we can also use two aliases:
Code - C#: [Select]
  2. using AcCoreAp = Autodesk.AutoCAD.ApplicationServices.Core.Application;
kdub_nz
  • SuperMod
« Reply #2 on: November 20, 2022, 02:38:14 AM »
Hi Gilles,
Sitting outside in the sunshine this afternoon I decided to go not us the Core.Application.
As you say, I too think the impact either way will be minimal.
I'll save my worrying for important things.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #3 on: November 20, 2022, 03:09:20 AM »
I concur
I also dropped coding this morning to go out in the sunshine. Went to Singapore’s botanic garden
« Last Edit: November 20, 2022, 03:13:20 AM by It's Alive! »
Retired
n.yuan
« Reply #4 on: November 20, 2022, 09:17:19 AM »
Well, if you write code that is generally intent to be shared by possible core console/Forge (now, called Platform), you may want to make sure you only use ...Core.Application, because you do not use acmgd.dll in plugins for core console/Forge.
kdub_nz
  • SuperMod
« Reply #5 on: November 20, 2022, 03:10:27 PM »
Thanks Norman, I'll keep that in mind.
Regards,
