Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
LM:SentenceCase Use in routine
« previous
next »
Print
Pages:
1
2
All
Go Down
Author
Topic: LM:SentenceCase Use in routine (Read 5003 times)
kdub_nz
Mesozoic keyThumper
SuperMod
Water Moccasin
class keyThumper<T>:ILazy<T>
Re: LM:SentenceCase Use in routine
Reply #15 on:
November 22, 2022, 05:04:48 PM »
For Properties Filter :
consecutive changes => ok
I'll have a look at the Groups . .
Logged
Called Kerry in my other life
I live at UTC + 13.00
kdub_nz
Mesozoic keyThumper
SuperMod
Water Moccasin
Reply #16 on:
November 22, 2022, 05:25:17 PM »
@jlogan02,
You're correct.
The Group filters can be changed from the 'Rename' in the Layer Properties Manager,
and from the command Line manually,
but NOT using the function
I'll have a better look tonight.
Logged
kdub_nz
Mesozoic keyThumper
SuperMod
Water Moccasin
Reply #17 on:
November 22, 2022, 05:40:50 PM »
Looks like the Group data is kept somewhere else than theDictionary attached to the Table !!
added:
Unless the report from
MgdDbg
snoop is incomplete ??
Last Edit: November 22, 2022, 05:50:04 PM by kdub
Logged
jlogan02
Bull Frog
Reply #18 on:
November 22, 2022, 06:52:55 PM »
ACLYDICTIONARY
Code - Auto/Visual Lisp:
[Select]
defun
:LayerFilterList
:SubFilterList
; su returns list of main filter and sub filters right behind
defun
:SubFilterList
dict
ent lst
foreach
ent
mapcar
cdr
vl
remove
if
not
lambda
x
car
x
350
dict
setq
lst
append
lst
cons
ent
if
assoc
360
entget
ent
:SubFilterList
entget
cdr
assoc
360
entget
cdr
assoc
360
entget
ent
lst
mapcar
lambda
x
cdr
assoc
300
entget
x
:SubFilterList
dictsearch
vlax
vla
object
ename
vla-getextensiondictionary
vla-get-layers
vla-get-activedocument
vlax-get-acad-object
"ACLYDICTIONARY"
This returns the list of Property and Group filters.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/layer-filter-existence-test/m-p/7910315#M367448
Last Edit: November 22, 2022, 07:13:51 PM by jlogan02
Logged
J. Logan
ACAD 2018
I am one with the Force and the Force is with me.
AutoCAD Map 2018 Windows 10
kdub_nz
Mesozoic keyThumper
SuperMod
Water Moccasin
Reply #19 on:
November 22, 2022, 11:23:18 PM »
Cool, That looks like it will return names of Properties, Groups and nested Filters.
Could solve most of your issues
I learnt something 'cause I've not played with these before.
Logged
jlogan02
Bull Frog
Reply #20 on:
November 23, 2022, 10:50:53 AM »
I'm going to whittle with it today and see what I come up with.
Logged
J. Logan
ACAD 2018
kdub_nz
Mesozoic keyThumper
SuperMod
Water Moccasin
Reply #21 on:
November 23, 2022, 12:37:49 PM »
@jlogan02.
Fairly clean from here.
run (:LayerFilterList) to determine the current complete filter list.
determine if the newName exists (position) or (member) in list
if so ; finished
determine if the 0ldName exists (position) or (member) in list
if so ; proceed
run the .-layer filter command as previously.
have a beer.
Regards,
stay well
Logged
jlogan02
Bull Frog
Reply #22 on:
November 23, 2022, 06:25:53 PM »
Took a little stab before calling it a day.
Keeps getting a nil.
[Select]
defun
C:LayerFilterList
:SubFilterList oldName newName
defun
:SubFilterList
dict
ent lst
foreach
ent
mapcar
cdr
vl
remove
if
not
lambda
x
car
x
350
dict
setq
lst
append
lst
cons
ent
if
assoc
360
entget
ent
:SubFilterList
entget
cdr
assoc
360
entget
cdr
assoc
360
entget
ent
lst
mapcar
lambda
x
cdr
assoc
300
entget
x
:SubFilterList
dictsearch
vlax
vla
object
ename
vla-get-layers
"ACLYDICTIONARY"
setq
oldName
"Stations Standard Layer"
newName
"Stations Standard Layers"
if
member
newName lst
princ
"Stations Standard Layers already exists."
if
member
oldName lst
progn
command
"._-layer"
"filter"
"Rename"
oldName newName
Happy Thanksgiving. Back at it Monday.
Logged
J. Logan
ACAD 2018
kdub_nz
Mesozoic keyThumper
SuperMod
Water Moccasin
Reply #23 on:
November 23, 2022, 07:43:48 PM »
perhaps something like this
[Select]
defun
c:NewDoIt
oldName newName currentFilterList
setq
oldName
newName
currentFilterList
:LayerFilterList
if
vl-position
newname currentFilterList
princ
strcat
\n
\t
newName
"' filter already exists."
;; else
if
vl-position
oldname currentFilterList
progn
command
"._-layer"
"filter"
"Rename"
oldName newName
princ
strcat
\n
\t
oldName
"' filter changed to '"
newName
;;else
princ
strcat
\n
\t
oldName
"' filter does not exists."
princ
defun
:LayerFilterList
:SubFilterList
defun
:SubFilterList
dict
ent lst
foreach
ent
mapcar
cdr
vl
remove
if
not
lambda
x
car
x
350
dict
setq
lst
append
lst
cons
ent
if
assoc
360
entget
ent
:SubFilterList
entget
cdr
assoc
360
entget
cdr
assoc
360
entget
ent
lst
mapcar
lambda
x
cdr
assoc
300
entget
x
:SubFilterList
dictsearch
vlax
vla
object
ename
vla-get-layers
"ACLYDICTIONARY"
Enjoy your holiday.
Logged
jlogan02
Bull Frog
Reply #24 on:
November 29, 2022, 05:06:02 PM »
kdub, that did the trick. Made some minor adjustments to messaging but other than that, all is good. Thanks for your help. Much appreciated.
Logged
J. Logan
ACAD 2018
Print
Pages:
1
2
All
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
