LM:SentenceCase Use in routine
jlogan02:
I want to set the layer filter name to Sentence Case using Lee Mac's LM:SentenceCase
--- Code - Auto/Visual Lisp: ---;; Sentence Case - Lee Mac;; Returns the supplied string converted to Sentence Case (defun LM:SentenceCase ( s / f ) (vl-list->string (mapcar (function (lambda ( a b c ) (if (or f (= 46 a)) (progn (setq f (= 32 b)) b) c) ) ) (cons 46 (vl-string->list s)) (vl-string->list (strcase s)) (vl-string->list (strcase s t)) ) ))
I'm just not sure where to put the defun (LM:SentenceCase) in the code below.
--- Code - Auto/Visual Lisp: ---(vl-load-com) ;| --------------------------------Function created by unknown-------------------------------- |; (defun get-layer-filter-names (/ collection) (setq names (list "")) (if (not (vl-catch-all-error-p (setq collection (vl-catch-all-apply (function (lambda () (vla-item (vla-getextensiondictionary (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))) ) "ACAD_LAYERFILTERS" ) ) ) ) ) ) ) (vlax-for item collection (setq names (cons (strcase (vla-get-name item)) names)) ) ) names); function (get-layer-filter-names) ;; get layer filter name.. (setq layn (strcase "Stations Standard Layers"))(if (member layn names) (princ "\nStations Standard Layers already exists.") (command "._-layer" "filter" "Rename" "Stations Standard Layer" layn "")); if(princ)
jlogan02:
My question still stands. However, I was wanting Title Case not Sentence Case.
--- Code - Auto/Visual Lisp: ---;; Title Case - Lee Mac;; Returns the supplied string converted to Title Case (defun LM:TitleCase ( s ) (vl-list->string (mapcar (function (lambda ( a b c ) (if (= 32 a) b c)) ) (cons 32 (vl-string->list s)) (vl-string->list (strcase s)) (vl-string->list (strcase s t)) ) ))
Usage (LM:TitleCase "Stations Standard Layers")
jlogan02:
Solved. Instead of using the variable
--- Code - Auto/Visual Lisp: ---layn, just spell it out like you want it.
--- Code - Auto/Visual Lisp: ---(setq layn (strcase "Stations Standard Layers"))(if (member layn names) (princ "\nStations Standard Layers already exists.") (command "._-layer" "filter" "Rename" "Stations Standard Layer" "Stations Standard Layers" "")
kdub:
Ahh, now I understand . . . You just want to add an 's' to a specific filter name.
. . . but you don't seem to be checking if the layerFilter you are renaming actually exists.
I assume you want to batch process drawings, or run this as part of a config routine, but you do realise that Right-click on the Filter name offers a rename option.
Regards,
added:
a piccy if 'Renamed' filter does not exist
jlogan02:
The "Stations Standard Layers already exists" message doesn't work. If the filter name exists I get...
Invalid layer filter name.
Enter new layer filter name:
This is generated by the command line syntax for the layer filter rename.
--- Code - Auto/Visual Lisp: --- (setq layn (strcase "Stations Standard Layers"))(if (member layn names) (princ "Stations Standard Layers already exists.") (command "._-layer" "filter" "Rename" "Stations Standard Layer" "Stations Standard Layers" "")); if(princ)
Clearly I'm wrong somewhere.
kdub, this would be in startup. Check if it exists if not add the "s"
Navigation
[0] Message Index
[#] Next page
Go to full version
