Author Topic: Any Testers out there ?  (Read 4951 times)
« on: July 02, 2005, 11:30:33 PM »
This is the functions library :
< redundant file removed [ UCS_Testing.fas ]>
NOTE :
FILE UPDATED
HEADER UPDATED
This is the header
  1. ;|
  2. Header for UCS_Testing ..
  3. kwb 2005.JUL.03
  4.
  5. [i]Header included in Later post[/i]
  6.
  7. |;
This is a test routine :
  1. (or (= 'SUBR (type kb:VEC:GetPathVector)) (load "UCS_Testing.fas"))
  2.
  3. (defun c:test ()
  4.   (if
  5.     (and (setq TemplateEnt (entsel "\nSelect Template Entity :"))
  6.          (setq RefPointInUCS (getpoint "\nSelect Reference Point : "))
  7.          (setq NewPointInUCS (getpoint "\nSelect Insertion Point : "))
  8.          (setq
  9.            vlaTemplateEnt (vla-Copy
  10.                             (vlax-ename->vla-object (car TemplateEnt))
  11.                           )
  12.          )
  13.     )
  14.      (kb:CopyFromPlanarToWCS->PlanarToUCS vlaTemplateEnt
  15.                                           RefPointInUCS
  16.                                           NewPointInUCS
  17.      )
  18.   )
  19.   (princ)
  20. )
Functionality:
Copy the selected object as represented in the WCS plane to the current UCS plane.
Origin can be any point planar to the WCS.
Target can be any point planar to the UCS.
« Last Edit: January 12, 2014, 10:05:57 PM by Kerry »
daron
« Reply #1 on: July 02, 2005, 11:33:13 PM »
Sorry Kerry. I wish I could test it for you. I don't have ACAD here at home. Hope someone pops in soon who does.
« Reply #2 on: July 02, 2005, 11:37:30 PM »
:D Thanks for the thought Daron.
I'ts not bomb proof yet, but I would be interested in seeing where it breaks.
... I have an idea how inventive some folks can be ..
« Reply #3 on: July 02, 2005, 11:43:13 PM »
This is some examples from the Library ..
Sorry, I dont have a CHM for it yet ..
(kb:VEC:CalculateLength '(4 3 0))
=> 5.0
(kb:VEC:Normalize '(4 3 0))
=> (0.8 0.6 0.0)
(kb:VEC:CalculateLength (kb:VEC:Normalize '(4 3 0)))
=> 1.0
(kb:VEC:Convert->Radians '(4 3 0))
=> 0.643501
(kbsf:rtd (kb:VEC:Convert->Radians '(4 3 0)))
=> 36.8699
« Reply #4 on: July 02, 2005, 11:45:36 PM »
Jeez, a Saturday night of a (USA) 3-day weekend, my wife is working graveyard shift, I'm watching a rain-delayed NASCAR race and otherwise quite bored, and here comes Kerry to wake me up!
But, of course, I don't use UCS's (also meaning that I don't know HOW to use them properly) so I can't even set up a test platform to test his test. :(
*shrug* /me wishes Kerry good luck and goes back to the race.....
daron
« Reply #5 on: July 02, 2005, 11:48:04 PM »
Interesting. Looks like some kind of logarithmic thing I don't yet have a firm grasp on, but I like how you can wrap one function inside another for differing results.
« Reply #6 on: July 02, 2005, 11:58:57 PM »
Jeff :- you a fuelHead ?
Long story short:
I'm using a closed entity < circle, pline, region > as a template to extrude along a path object located anywhere in 3D space < any linear object >
There were 2 glitches
UCS's must be named to extract ActiveX info.
Regions have their 'Normal property ReadOnly, so we have to go through hoops with translations.
I think this library solves those issues. .. but I'm just about brain dead, and it's almost time for the football.
ps .. Have a fun holiday weekend if you get one ..
« Reply #7 on: July 03, 2005, 12:10:23 AM »
Jeff, this is the sort stuff I play with when I'm not hacking code :
« Reply #8 on: July 03, 2005, 12:20:59 AM »
Whoa! That's pretty cool Kerry. Are those for the BIGGG earthmovers?
BTW, thanks for the quick explanation. And, yeah, I put racing pretty high on my priority list. I used to work on Sprint cars, many moons ago, but now I'm just an Easy chair "backseat" driver. The only track close to me is a road course (Infineon, formerly known as Sears Point) and for years I attended most races held there. But the amount of fans has increased to the point it's more enjoyable at home or the local pub with a handful of fellow fans.
I will have a good remainder of my weekend, thanks. Enjoy your football (is that football or soccer?)
« Reply #9 on: July 03, 2005, 12:27:40 AM »
Rugby league .. today [ I used to play .. which explains the bumps on my head ]
Rugby Union and Australian Rules Football Yesterday. < I read during the boring bits>
Not really a big soccer fan .. but sometimes get caught up in a game.
not earthmoving ..
Those are a type of underpan used in the mining industry .. catch the wet junk during processing.
These are about 3.700 M X  1.800 M and a shade under 2 tonne each. < sorry for the metric >
Amsterdammed
« Reply #10 on: July 03, 2005, 02:34:37 AM »
Kerry,
You want with this code copy a solid from on side of the construction and use it on another side?
Bernd
« Reply #11 on: July 03, 2005, 02:43:37 AM »
Quote from: Amsterdammed
Kerry,
Bernd
... should work with solids as well.
basically from anywhere to anywhere, BUT .. the "view" in the WCS is copied into the "View" of the UCS. < if you know what I mean :) > .
« Reply #12 on: July 03, 2005, 07:34:19 AM »
** WOOt **
Translate and extrude  8)
  1. (defun c:test2 ()
  2.   ;; kwb 2005.JUL.03
  3.   ;;
  4.   ;; Variables local for testing
  5.   (setq TemplateEnt (kbsf:entsel "Select Template Entity"
  6.                                  nil
  7.                                  nil
  8.                                  ;;'("Region" "LwPolyline""Circle" "Polyline" "Ellipse")
  9.                                  ;; NOTE check that LWPLine is closed.
  10.                                  ;; restrict selection initially.
  11.                                  ;;
  12.                                  (list "Region")
  13.                                  nil
  14.                                  nil
  15.                     )
  16.   )
  17.   (setq vlaTemplate
  18.          (vla-Copy (vlax-ename->vla-object (car TemplateEnt)))
  19.   )
  20.   (setq RefPointInUCS (getpoint "\nSelect Reference Point : "))
  21.   (setq RefPointInWCS (trans RefPointInUCS acucs acworld))
  22.   (setq PathEnt (kbsf:entsel "Select Path Entity"
  23.                              nil
  24.                              nil
  25.                              ;;'("Line" "LwPolyline" "Polyline" "Circle" "Arc" "Ellipse" "Spline")
  26.                              ;; restrict selection initially.
  27.                              ;; added : path type options increased kwb
  28.                              ;; (list "LwPolyline" )
  29.                              (list "LwPolyline"  "Polyline"
  30.                                    "Circle"      "Arc"
  31.                                    "Ellipse"     "Line"
  32.                                   )
  33.                              nil
  34.                              nil
  35.                 )
  36.   )
  37.   (setq vlaPathObj (vlax-ename->vla-object (car PathEnt)))
  38.   (setq PathVector (kb:VEC:GetPathVector vlaPathObj))
  39.   (setq vlaOriginalUCS (kb:UCS:NameCurrent "saved"))
  40.   ;; assume path is LWPLine for now ...
  41.   ;; so the translated Template YAxis will be the Path Normal
  42.   ;; grab the variant safearray Normal
  43.   ;;
  44.   (setq PathNormal (vlax-get vlaPathObj 'Normal))
  45.   (setq PathStartPointInWCS (vlax-curve-getStartPoint vlaPathObj))
  46.   (setq vlaNewUCS (kb:UCS:BlackBox
  47.                     "Path"                        ; Name
  48.                     PathStartPointInWCS           ; Origin      :<PointList (X Y Z)>
  49.                     (kb:VEC:CrossProduct PathNormal PathVector)
  50.                                                   ; XAxis               :<VectorList (X Y Z)>
  51.                     PathNormal                    ; YAxis               :<VectorList (X Y Z)>
  52.                     T                             ; Activate
  53.                   )
  54.   )
  55.   ;;
  56.   ;; mojo with the template ..
  57.   (kb:CopyFromPlanarToWCS->PlanarToUCS
  58.     vlaTemplate
  59.     (trans RefPointInWCS acworld acucs)
  60.     '(0.0 0.0 0.0)
  61.   )
  62.   ;; The template is already a region, so no need to convert it.
  63.   ;; ... will need to when we do the other stuff later ...
  64.   ;;
  65.   ;; assume model space for this test .. check later
  66.   ;;
  67.   (setq vlaSolid (vla-AddExtrudedSolidAlongPath g:modelspace
  68.                                                 vlaTemplate
  69.                                                 vlaPathObj
  70.                  )
  71.   )
  72.   (vla-put-color vlaSolid acYellow)
  73.   (vla-put-activeUCS g:activedoc vlaOriginalUCS)
  74.   (vla-delete vlaTemplate)
  75.   (princ)
  76. )
  77.
Before ..
.... and after ...
The Cyan rectangle is the template, The red Pline is the Path target.
« Last Edit: January 12, 2014, 10:02:31 PM by Kerry »
« Reply #13 on: July 03, 2005, 07:40:40 AM »
Ooops . ya'all need this ..
added at update : a variation of this has been added to the UCS-VEC-LIBrary.fas Library file.
  1. ;;;------------------------------------------------------------------
  2. ;;;------------------------------------------------------------------
  3. ;;;
  4. ;;; kwb 20021103
  5. ;;; kbsf:entsel (msg kwd def typelist selectflag lockflag
  6.
  7. ;;; Arguments:
  8. ;;; msg : The prompt string.
  9. ;;; kwd : Initget keywords string.
  10. ;;; def : Value to return if response is <enter>.
  11. ;;; typelist  : Stringlist of entity types allowed for selection. If nil select anything.
  12. ;;; selectflag : If true nentsel permitted , otherwise use entsel.
  13. ;;; lockflag  : If true dont allow selection from locked layers.
  14. ;;;
  15. ;;; Note : Arguments may be set to nil
  16. ;;;
  17. ;;; Return output from (n)entsel, a key word, the default argument, or nil.
  18. ;;;
  19. ;; example1 : (kbsf:EntSel "Select Arc Object" nil nil (list "ARC" "CIRCLE") nil T)
  20. ;;  ==>  (<Entity name: 40bcd540> (-28175.1 154575.0 1250.0))
  21. ;; example2 : (kbsf:EntSel "Select Datum Line" nil nil (list "LINE") T T) ; line in block
  22. ;;  ==>  (<Entity name: 4022c680> (-21613.1 142392.0 0.0)
  23. ;;  ((70.0 0.0 0.0) (0.0 70.0 0.0) (0.0 0.0 70.0) (-21611.9 142635.0 0.0))
  24. ;;          (<Entity name: 4022c6b8>)  )
  25.
  26.        (msg kwd def typelist selectflag lockflag / pickok returnvalue tmp)
  27.   (setq msg (strcat "\n"
  28.                     (cond (msg)
  29.                           ("Select object")
  30.                     )
  31.                     " : "
  32.             )
  33.   )
  34.   (while (not pickok)
  35.     (setvar "ERRNO" 0)
  36.     (if kwd
  37.       (initget kwd)
  38.     )
  39.     (setq returnvalue (if selectflag
  40.                         (nentsel msg)
  41.                         (entsel msg)
  42.                       )
  43.     )
  44.     (cond
  45.       ((= (getvar "ERRNO") 52)      ; enter
  46.        (if def
  47.          (setq returnvalue def)
  48.        )
  49.        ;; skip out
  50.        (setq pickok t)
  51.       )
  52.       ((= (getvar "ERRNO") 7)
  53.        (princ "Nothing found at selectedpoint. ")
  54.       )
  55.       ((= (type returnvalue) 'str) (setq pickok t))         ; keyword
  56.       ((and (setq tmp (entget (car returnvalue)))           ; object type
  57.             typelist
  58.             (not (member (cdr (assoc 0 tmp)) (mapcar 'strcase typelist)))
  59.        )                                                    ; wrong type
  60.        (alert
  61.          (strcat
  62.            "Selected object is not"
  63.            "\na "
  64.            (apply
  65.              'strcat
  66.              (cons (car typelist)
  67.                    (mapcar '(lambda (x) (strcat "\nor " x)) (cdr typelist))
  68.              )
  69.            )
  70.            ". "
  71.          )
  72.        )
  73.       )
  74.       ((and lockflag                                        ;Locked Layer Not Permitted
  75.             (setq                                           ;layer name
  76.               tmp (entget (tblobjname "LAYER" (cdr (assoc 8 tmp))))
  77.             )
  78.             (= (logand 4 (cdr (assoc 70 tmp))) 4)           ;is layer locked
  79.        )
  80.        (princ "Selected object is on a locked layer. ")
  81.       )
  82.       ;; skip out
  83.       ((setq pickok t))
  84.     )
  85.   )
  86.   returnvalue
  87. )
« Last Edit: January 12, 2014, 10:03:23 PM by Kerry »
« Reply #14 on: July 04, 2005, 05:07:14 AM »
The holiday on that side of the pond has given me a chance to progress with this before too many people rip it apart.
The original <now redundant> fas has been removed from the lilly-pond.
New Library File :
http://www.theswamp.org/lilly_pond/kerrybrown/UCS-VEC-LIBrary.fas?nossi=1
New Test Code :
The rotation option may be interesting for some.
"Confirm Rotation about Axis [X +180/ Y +180/ Z+ 90/ Z- 270/ Continue]"
Options : rotate the template around the target UCS axes before extrusion.  Just use X, Y, Z or Z- ...   < see the piccy >
I use :- UCSICON  3  On and displayed at origin.
Template and Path TYPE's updated as indicated in the source.
I would be grateful if someone lets me know if they breaks this.  :wink:
  1.
  2. (or (= 'SUBR (type kb:VEC:GetPathVector))
  3.     (load "UCS-VEC-LIBrary.fas")
  4. )
  5.
  6. ;;;-------------------------------------------------------------
  7. ;;;-------------------------------------------------------------
  8. ;;
  9.
  10. (defun c:test6 (/                *error*          CurentSpace
  11.                 PathEnt          PathNormal       PathStartPointInWCS
  12.                 PathVector       RefPointInUCS    RefPointInWCS
  13.                 TemplateEnt      vlaNewUCS        vlaOriginalUCS
  14.                 vlaPathObj       vlaRegion        vlaSolid
  15.                 vlaTemplate
  16.                )
  17.   ;; kwb 2005.JUL.04
  18.   ;;
  19.   ;; add error trapping
  20.   ;;
  21.   ;;------standard error trap------------------
  22.   (defun *error* (msg /) (kb:on-error msg))
  23.   (vla-endundomark g:activedoc)                   ; end any open undo group
  24.   (vla-startundomark g:activedoc)                 ; start new group
  25.   ;;-------------------------------------------
  26.   (kb:savesysvar '(("CMDECHO" 0)
  27.                    ("expert" 5)
  28.                    ("UCSICON" 3)
  29.                    ("BLIPMODE" 0)
  30.                    ("SNAPANG" 0)
  31.                    ("SNAPMODE" 0)
  32.                    ("OSMODE" 0)
  33.                    ("SNAPANG" 0)
  34.                    ("PICKADD" 1)
  35.                    ("PICKBOX" 5)
  36.                    ("SORTENTS" 1)
  37.
  38.                   )
  39.   )
  40.   ;;-------------------------------------------
  41.   (setq TemplateEnt    (kb:entsel "Select Template Entity { to extrude } "
  42.                                   nil
  43.                                   nil
  44.                                   (list "Region"       "Circle"
  45.                                         "Ellipse"      "LwPolyline"
  46.                                         "Polyline"
  47.                                        )
  48.                                   nil
  49.                                   nil
  50.                        )
  51.         RefPointInUCS  (getpoint "\nSelect Reference Point on Template : ")
  52.         RefPointInWCS  (trans RefPointInUCS acucs acworld)
  53.         PathEnt        (kb:entsel "Select Path Entity"
  54.                                   nil
  55.                                   nil
  56.                                   (list "LwPolyline"  "Polyline"
  57.                                         "Circle"      "Arc"
  58.                                         "Ellipse"     "Line"
  59.                                        )
  60.                                   nil
  61.                                   nil
  62.                        )
  63.         vlaPathObj     (vlax-ename->vla-object (car PathEnt))
  64.         PathVector     (kb:VEC:GetPathVector vlaPathObj)
  65.         vlaOriginalUCS (kb:UCS:NameCurrent "saved")
  66.   )
  67.   ;; the translated Template YAxis will be oriented to the Path Normal initially
  68.   ;; grab the variant safearray Normal
  69.   ;;
  70.   (setq PathNormal          (vlax-get vlaPathObj 'Normal)
  71.         PathStartPointInWCS (vlax-curve-getStartPoint vlaPathObj)
  72.         vlaNewUCS           (kb:UCS:BlackBox
  73.                               "Path"              ; Name
  74.                               PathStartPointInWCS ; Origin      :<PointList (X Y Z)>
  75.                               (kb:VEC:CrossProduct PathNormal PathVector)
  76.                                                   ; XAxis               :<VectorList (X Y Z)>
  77.                               PathNormal          ; YAxis               :<VectorList (X Y Z)>
  78.                               T                   ; Activate
  79.                             )
  80.         ;;
  81.         ;; mojo with the template ..
  82.         ;;
  83.         vlaTemplate         (vla-Copy (vlax-ename->vla-object (car TemplateEnt)))
  84.         CurentSpace         (if
  85.                               (or
  86.                                 (= acmodelspace (vla-get-activespace g:activedoc))
  87.                                 (= :vlax-true (vla-get-mspace g:activedoc))
  88.                               )
  89.                                g:modelspace
  90.                                (vla-get-paperspace g:activedoc)
  91.                             )
  92.   )
  93.   (kb:CopyFromPlanarToWCS->PlanarToUCS
  94.     vlaTemplate
  95.     (trans RefPointInWCS acworld acucs)
  96.     '(0.0 0.0 0.0)
  97.   )
  98.   ;;
  99.   ;; convert the template to a region
  100.   ;;
  101.   (cond
  102.     ((= "AcDbRegion" (vla-get-objectname vlaTemplate))
  103.      ;; It's a region already, no need to convert
  104.      (setq vlaRegion vlaTemplate)
  105.     )
  106.     ((vl-position (vla-get-objectname vlaTemplate)
  107.                   '("AcDbCircle" "AcDbEllipse")
  108.      )
  109.      (setq vlaRegion (kb:convertToRegion vlaTemplate CurentSpace))
  110.     )
  111.     ((vl-position (vla-get-objectname vlaTemplate)
  112.                   '("AcDbPolyline" "AcDb3dPolyline")
  113.      )
  114.      (if (= :vlax-true (vla-get-closed vlaTemplate))
  115.        (setq vlaRegion (kb:convertToRegion vlaTemplate CurentSpace))
  116.        ;; else
  117.        (prompt "\nUnable to Create Region to Extruded.")
  118.      )
  119.     )
  120.     (T (prompt "\nUnable to Create Region to Extruded."))
  121.   )
  122.   ;;
  123.   ;; Confirm the Rotation
  124.   ;;
  125.   ;;
  126.   (if vlaRegion
  127.     (progn (if (not (vlax-erased-p vlaTemplate))
  128.              (vla-delete vlaTemplate)
  129.            )
  130.            (kb:ConfirmRotate vlaRegion)
  131.            (setq vlaSolid (vla-AddExtrudedSolidAlongPath CurentSpace
  132.                                                          vlaRegion
  133.                                                          vlaPathObj
  134.                           )
  135.            )
  136.            (vla-put-color vlaSolid acYellow)
  137.     )
  138.   )
  139.   ;;
  140.   ;;
  141.   (vla-put-activeUCS g:activedoc vlaOriginalUCS)
  142.   (if (not (vlax-erased-p vlaRegion))
  143.     (vla-delete vlaRegion)
  144.   )
  145.   (*error* nil)
  146.   (princ)
  147. )
  148.
  149. ;;;-------------------------------------------------------------
  150. ;;;-------------------------------------------------------------
  151. ;;
  152.
  153. ;|«Visual LISP© Format Options»
  154. (70 2 50 2 nil "end of " 70 40 0 0 0 nil nil nil T)
  155. ;*** DO NOT add text below the comment! ***|;
Revised Header file for UCS-VEC-LIBrary.fas
  1. ;|
  3. kwb 2005.JUL.03 : initial compilation.
  4. kwb 2005.JUL.04 : revised and supplemented.
  5. Exported Functions Defined as SUBRS :
  6.
  7. /////
  8.
  9. kb:UCS:BlackBox                                         (NewUcsName Origin XAxis YAxis Activate
  10. kb:UCS:CheckAxisZero                    (vlaCurrentUCS
  11. kb:UCS:GetCurrentNormal
  12. kb:UCS:NameCurrent                              (UCSName < string or nil for default >
  13. kb:UCS:NameWorld                                        (MakeActive < T or nil >
  14. kb:UCS:TransFromWCStoUCS        (entname < ename or vlaObject >
  15. kb:UCS:TransPointToOCS          (3dPt
  16.
  17. kb:VEC:CalculateLength          (Vector
  18. kb:VEC:Convert->Radians         (Vector
  19. kb:VEC:CrossProduct                     (Vector1 Vector2
  20. kb:VEC:GetPathVector                    (vlaObj
  21. kb:VEC:Normalize                                        (Vector
  22. kb:VEC:points->vector           (3dPt1 3dPt2
  23. kb:VEC:ZeroAxisFuzz                     (VectorList
  24. kb:VEC:vla3dPoint->List         (vla3dPoint
  25.
  26. kb:ConfirmRotate                                        (vlaRegion
  27. kb:convertToRegion                              (vlaObject CurentSpace
  28. kb:CopyFromPlanarToWCS->PlanarToUCS (VLATemplateObject RefPointInUCS NewPointInUCS
  29. kb:entsel                                                               (msg kwd def typelist selectflag lockflag
  30. kb:getpoint                                                     (msg
  31. kb:getword                                                              (msg def bit kwd
  32. kb:lisp-value                                           (val
  33. kb:on-error                                                     (msg
  34. kb:ptos        (pt
  35. kb:savesysvar                                           (vars_list
  36. /////
  37. Global Variables Defined as VLA-OBJECT :
  38.
  39. g:acadapp                       : IAcadApplication Object
  40. g:activedoc     : IAcadDocument Object
  41. g:modelspace    : IAcadModelSpace Object
  42. g:utility       : IAcadUtility Object
  43. g:documents     : IAcadDocuments Collection
  44. g:blocks                                : IAcadBlocks Collection
  45. g:ucss                                  : IAcadUCSs Collection
  46. g:layers                                : IAcadLayers Collection
  47.
  48. |;
Snapshot at rotation prior to extrusion :-
« Last Edit: January 12, 2014, 10:05:13 PM by Kerry »
