Author Topic: A Rose by any name . . .  (Read 2765 times)
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« on: November 12, 2022, 11:25:08 PM »
I've struck the inevitable roadblock.
What do I name a class.  ??
I'm (planning on) building an abstract base class for some purpose-built classes in a namespace.
The children classes are responsible for reading and writing config files . .
Well, actually, classes explicitly for
INI files,
XML files,
Registry entry
perhaps also
Config files,
Json files (or perhaps not)
The base class will contain common methods and fields for the derived classes.
I expect to be able implement most of the functionality in the base class
The issue is, what do I name the base class ?? ; something that represents what it is.
I have a couple of candidates, but they seem a bit lame-assed.
Regards,
Called Kerry in my other life
I live at UTC + 13.00
Re: A Rose by any name . . .
« Reply #1 on: November 13, 2022, 03:41:29 AM »
use interfaces  :laugh:
« Reply #2 on: November 13, 2022, 03:55:29 AM »
AbstractFile
AbstractFileStream
BaseFileStream
FileStream : BaseFileStream, ISerializable
BaseFileStream : ISerializable
FileStream : BaseFileStream, IFormatter
kdub_nz
  • SuperMod
« Reply #3 on: November 13, 2022, 04:39:59 AM »
Yep.  but I still use the base to handle the repeatable stuff.
« Reply #4 on: November 13, 2022, 05:47:13 AM »
I’ve been using Serialize a ton.
My last project I have a class ODBCSysVar, that implements Serialize
I call ODBCSysVar.Load in kInitAppMsg, and ODBCSysVar.Store in kUnloadAppMsg. It’s a singleton, with its own path, responsible for itself.
Something like this, I would name it after the data it holds.
BaseStream
INIStream : BaseStream
XMLSteam : BaseStream
RegistryStream : BaseStream
JsonStream : BaseStream
DisplayConfig
    read(const BaseStream stream...);
    write(BaseStream stream...);
just throwing out ideas  :mrgreen:
« Last Edit: November 13, 2022, 05:53:28 AM by It's Alive! »
kdub_nz
  • SuperMod
« Reply #5 on: November 13, 2022, 03:41:00 PM »
'Stream' may do it.
looks like that's another pack of jelly beans I owe you !
I had 'Config' and 'Profile' floating around in my head.
. . from configuration file and the Windows Profile API ( GetPrivateProfileString )
. . . pretty lame, and could be confusing.
Thanks for the input Dan
added:
Yes, I had proposed suffixing the <purpose> name with the <base> name , but I hadn't thought of actually prefifing the base name with 'base'.
The great thing is it's easy to refactor if I get hit by a creative bolt of lightning.
« Last Edit: November 13, 2022, 03:49:50 PM by kdub »
kdub_nz
  • SuperMod
« Reply #6 on: November 13, 2022, 11:42:23 PM »
I found something that can be pannelbeaten into something near to what I think I want.
https://www.codeproject.com/Articles/5304/Read-Write-XML-files-Config-files-INI-files-or-the
. . . put on my overalls :)
« Reply #7 on: November 14, 2022, 01:06:34 AM »
Lol, I remember that! Back in the days where the sweetest thing for a thousand miles was Chinese red bean paste
