Author Topic: date conflict US Europe  (Read 4307 times)
Amsterdammed
« on: July 02, 2005, 06:23:29 AM »
Hello all together.
I have a problem with the different date version in the States and in Europe.
So is there a way I can get the today’s date in a d-m-yyyy  format as return from an English Office version?
Thanks in advance,
Bernd :(
« Reply #1 on: July 02, 2005, 03:32:09 PM »
How about this?
Function EuroDate() As String
Dim MyDate
Dim dateVar
MyDate = Date
dateVar = Split(MyDate, "/")
MyDate = dateVar(1) & "/" & dateVar(0) & "/" & dateVar(2)
EuroDate = MyDate
End Function
Sub test()
Debug.Print EuroDate
Amsterdammed
« Reply #2 on: July 02, 2005, 04:55:34 PM »
Jeff,
I just found something easy
Sub test()
Dim EDate As String
EDate = Date
EDate = Format(EDate, ("DD-MM-YYYY"))
MsgBox EDate
I need the date also as part of a filename, so i need the - in it, no \
I just learned about the split finction, new to me.Really handy. You know VBA is pretty unknown to me.
 Bernd
Amsterdammed
« Reply #3 on: July 02, 2005, 04:59:40 PM »
But that works only if edate is declared as string not as date
« Reply #4 on: July 02, 2005, 05:04:43 PM »
Sub test()
MsgBox Format(Date, ("DD-MM-YYYY"))
This works, too.
« Reply #5 on: July 02, 2005, 05:40:13 PM »
:D
or
MsgBox Format(Date, ("YYYY-MM-DD"))
Amsterdammed
« Reply #6 on: July 03, 2005, 02:16:08 AM »
Yep, but i needed the string for a filename, the MsgBox was just for the test.
