Author Topic: How-to entmake solid arrow.  (Read 1691 times)
ScottMC
« on: October 22, 2022, 09:59:24 PM »
Found one to make it using polyline but know there must be some way to get entmake to allow solid creation. Here's the one I've used to try to convert but can't get it..
https://www.theswamp.org/index.php?topic=3117.msg39113#msg39113
(defun SetBlk (n)
  (and (not (tblsearch "BLOCK" n))
       (eval (list (read n)))))
(defun arr ()
(entmake '((0 . "BLOCK") (2 . "ARR")(70 . 0)(10 0 0 0)))
(entmake '((0 . "POLYLINE")(8 . "0")(66 . 1)(10 0 0 0)))  ;; << --
(entmake '((0 . "VERTEX")(8 . "0")(10 -12 0 0)))
(entmake '((0 . "VERTEX")(8 . "0")(10 0 0 0)))
(entmake '((0 . "VERTEX")(8 . "0")(10 -8 8 0)))
(entmake '((0 . "VERTEX")(8 . "0")(10 8 0 0)))
(entmake '((0 . "VERTEX")(8 . "0")(10 -8 -8 0)))
(entmake '((0 . "SEQEND")(8 . "0")))
(entmake '((0 . "ENDBLK"))))
Any help will be appreciated.
BIGAL
  • 40 + years of using Autocad
Re: How-to entmake solid arrow.
« Reply #1 on: October 23, 2022, 12:05:23 AM »
Adding solid is about sequence of points do manualy 1 2 3 2 4 enter
Should be able to do multiple points this makes 1 of 2 solids. Just do bottom also.
(entmake '((0 . "SOLID") (410 . "Model") (8 . "0")(10 -8.0 8.0 0.0) (11 8.0 0.0 0.0) (12 0.0 0.0 0.0) (13 0.0 0.0 0.0)))
((0 . "SOLID") (410 . "Model") (8 . "0") (10 -8.0 8.0 0.0) (11 8.0 0.0 0.0) (12 0.0 0.0 0.0) (13 0.0 0.0 0.0))
« Last Edit: October 23, 2022, 12:32:05 AM by BIGAL »
ScottMC
« Reply #2 on: October 23, 2022, 08:23:47 AM »
Excellent. Thanks BIGAL. This gets me going!
(entmake '((0 . "SOLID")(410 . "Model")(8 . "0")
    (10 0.0 -4.0 0.0) (11 21.0 0.0 0.0) (12 0.0 4.0 0.0) (13 0.0 -4.0 0.0)))
Crank
« Reply #3 on: October 23, 2022, 10:01:11 AM »
Use MakeEntmake to find your answer.
BIGAL
« Reply #4 on: October 23, 2022, 07:36:43 PM »
Thanks Crank and to Cab in particular looking for entmake stuff can be time consuming.
ScottMC
« Reply #5 on: October 23, 2022, 07:49:31 PM »
Took the 'David Bethel' and attempted to get it to finish by creating a block but not able [failed]. Here's my attempt with xed block part.. Makes a solid which is OK.
Oops.. seems line 25 unecessary as item is created before with entmake solid.
(defun c:pi (/ )
    (defun SetBlk (n)
(defun arr ( / )
    ; (entmake '((0 . "BLOCK")
       ; (8 . "0") ;; assigned layer
         ; (2 . "ARR") ;; block created
         ; (10 0.0 0.0 0.0) ; base point
(entmake '((0 . "SOLID")(8 . "0")
  (10 0.0 -0.09 0.0)
  (11 0.54 0.0 0.0)
  (12 0.0 0.09 0.0)
  (13 0.0 -0.09 0.0)))
;(entmake '((0 . "ENDBLK")(8 . "0")))
(SetBlk "ARR") ;; ? confirm/safe block isn't [L-2]
[color=red];;(ARR) ;; call the entity to build[/color] causes duplicate
(command "move" "L" "" "0,0,0" "\\" "rotate" "L" "" (getvar 'lastpoint) "\\")
« Last Edit: October 24, 2022, 08:23:44 PM by ScottMC »
BIGAL
« Reply #6 on: October 24, 2022, 07:19:30 PM »
Using Cab great code very useful.
;; Revision :10/25/2022 @10:18
(defun c:eMake ()
  (entmake '((0 . "SOLID") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbTrace") (10 -8.0 8.0 0.0) (11 0.0 0.0 0.0) (12 8.0 0.0 0.0) (13 -8.0 -8.0 0.0) (39 . 0.0)))
  (entmake '((0 . "BLOCK") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbBlockReference") (2 . "ARR") (10 0.0 0.0 0.0) (70 . 0)))
  (entmake '((0 . "POLYLINE") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDb2dPolyline") (66 . 1) (10 0.0 0.0 0.0) (70 . 0) (40 . 0.0) (41 . 0.0) (71 . 0) (72 . 0) (73 . 0) (74 . 0) (75 . 0)))
  (entmake '((0 . "VERTEX") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbVertex") (100 . "AcDb2dVertex") (10 -12.0 0.0 0.0) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (70 . 0) (50 . 0.0)))
  (entmake '((0 . "VERTEX") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbVertex") (100 . "AcDb2dVertex") (10 0.0 0.0 0.0) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (70 . 0) (50 . 0.0)))
  (entmake '((0 . "VERTEX") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbVertex") (100 . "AcDb2dVertex") (10 -8.0 8.0 0.0) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (70 . 0) (50 . 0.0)))
  (entmake '((0 . "VERTEX") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbVertex") (100 . "AcDb2dVertex") (10 8.0 0.0 0.0) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (70 . 0) (50 . 0.0)))
  (entmake '((0 . "VERTEX") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbVertex") (100 . "AcDb2dVertex") (10 -8.0 -8.0 0.0) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (70 . 0) (50 . 0.0)))
  (entmake '((0 . "SEQEND") (100 . "AcDbEntity") (67 . 0) (8 . "0")))
  (entmake '((0 . "ENDBLK") (100 . "AcDbBlockEnd") (8 . "0")))
) ; end eMaker
ScottMC
« Reply #7 on: October 24, 2022, 08:46:12 PM »
Now getting into entmake, I'll probably work a library of regulars to make the block unecessary. I'll try CAB's maker, that will probably make the writing easier.
BIGAL
« Reply #8 on: October 25, 2022, 03:17:53 AM »
Library regulars
« Reply #9 on: October 30, 2022, 09:44:00 AM »
Glad you found it useful. 8)
