Author Topic: How to improve the computing speed of MD5  (Read 5124 times)
d2010
Re: How to improve the computing speed of MD5
« Reply #15 on: October 21, 2022, 04:20:40 PM »
syz-md5.fas is implemented by calling the system api with pure lsp.
and this is great news, baitang36
well done
i think it brings lisp to a new level
Do you CormanLisp is more-fast than Visual-Lisp?
How to calculate the speed  of "CormanLisp"?
« Reply #16 on: October 21, 2022, 05:50:17 PM »
well done
Extending Autolisp with ObjextARX, in a general sense, is flawed because AutoCAD tries to translate some data structures.
For example, if you send  '(220 float float float)  from Autolisp to Arx, AutoCAD will crash with a LsAdsInvoke Internal Error.
'(10 float float float)  and you just a get a point on the arx side, so there's overhead of converting data structures back
However, like in this case, a MD5 routine, where the arguments are predetermined, Extending Autolisp with ObjextARX can be useful
« Reply #17 on: October 21, 2022, 11:34:40 PM »
Someone can test the performance of this. compiled for BricsCADv22 and autocad 2021-23 and the source is included
it's not optimal because I'm using all 8 bytes for each element, this list would only need 2 bytes for each.
it should generate a hash for any list.  :mrgreen:
« Last Edit: October 21, 2022, 11:51:37 PM by It's Alive! »
« Reply #18 on: October 22, 2022, 12:04:46 AM »
this one is slightly better, I didn't include NIL or T.. is it needed?
Code - C: [Select]
  1.     union uINT16Data
  2.     {
  3.         int16_t val;
  4.         BYTE buf[2];
  5.     };
  6.     union uINT32Data
  7.     {
  8.         int32_t val;
  9.         BYTE buf[4];
  10.     };
  11.     union uINT64Data
  12.     {
  13.         int64_t val;
  14.         BYTE buf[8];
  15.     };
  16.     union uDOUBLEData
  17.     {
  18.         double_t val;
  19.         BYTE buf[8];
  20.     };
  21.
  22.     //(ads_md5 '(39 50 50 5 33 36 37 37 25 29 31 32 32 1 19 24 24 25 28 29 13 14 14 17 18 21 21 23 12))
  23.     static int ads_ads_md5(void)
  24.     {
  25.         constexpr size_t MD5LEN = 16;
  26.         constexpr CHAR rgbDigits[] = "0123456789abcdef";
  27.
  28.         HCRYPTPROV hProv = 0;
  29.         HCRYPTHASH hHash = 0;
  30.         BYTE rgbHash[MD5LEN];
  31.         DWORD cbHash = 0, dwStatus = 0;
  32.         std::vector<BYTE> bytes;
  33.
  34.         unique_resbuf_ptr pArgs(acedGetArgs());
  35.
  36.         for (resbuf* pTail = pArgs.get(); pTail != nullptr; pTail = pTail->rbnext)
  37.         {
  38.             switch (pTail->restype)
  39.             {
  40.                 case RTSHORT:
  41.                 {
  42.                     uINT16Data dbl{ pTail->resval.rint };
  43.                     for (size_t idx = 0; idx < 2; idx++)
  44.                         bytes.push_back(dbl.buf[idx]);
  45.                 }
  46.                 break;
  47.                 case RTLONG:
  48.                 {
  49.                     uINT32Data dbl{ pTail->resval.rlong };
  50.                     for (size_t idx = 0; idx < 4; idx++)
  51.                         bytes.push_back(dbl.buf[idx]);
  52.                 }
  53.                 break;
  54.                 case RTREAL:
  55.                 {
  56.                     uDOUBLEData dbl{ pTail->resval.rreal };
  57.                     for (size_t idx = 0; idx < 8; idx++)
  58.                         bytes.push_back(dbl.buf[idx]);
  59.                 }
  60.                 break;
  61.                 case RTPOINT:
  62.                 {
  63.                     {
  64.                         uDOUBLEData dbl{ pTail->resval.rpoint[0] };
  65.                         for (size_t idx = 0; idx < 8; idx++)
  66.                             bytes.push_back(dbl.buf[idx]);
  67.                     }
  68.                     {
  69.                         uDOUBLEData dbl{ pTail->resval.rpoint[1] };
  70.                         for (size_t idx = 0; idx < 8; idx++)
  71.                             bytes.push_back(dbl.buf[idx]);
  72.                     }
  73.                 }
  74.                 break;
  75.                 case RT3DPOINT:
  76.                 {
  77.                     {
  78.                         uDOUBLEData dbl{ pTail->resval.rpoint[0] };
  79.                         for (size_t idx = 0; idx < 8; idx++)
  80.                             bytes.push_back(dbl.buf[idx]);
  81.                     }
  82.                     {
  83.                         uDOUBLEData dbl{ pTail->resval.rpoint[1] };
  84.                         for (size_t idx = 0; idx < 8; idx++)
  85.                             bytes.push_back(dbl.buf[idx]);
  86.                     }
  87.                     {
  88.                         uDOUBLEData dbl{ pTail->resval.rpoint[2] };
  89.                         for (size_t idx = 0; idx < 8; idx++)
  90.                             bytes.push_back(dbl.buf[idx]);
  91.                     }
  92.                 }
  93.                 break;
  94.                 case RTSTR:
  95.                 {
  96.                     std::string str = wstr_to_utf8(pTail->resval.rstring);
  97.                     for (auto ch : str)
  98.                         bytes.push_back(ch);
  99.                 }
  100.                 break;
  101.                 default:
  102.                     break;
  103.             }
  104.         }
  105.         if (!CryptAcquireContext(&hProv, NULL, NULL, PROV_RSA_FULL, CRYPT_VERIFYCONTEXT))
  106.         {
  107.             dwStatus = GetLastError();
  108.             acutPrintf(L"CryptAcquireContext failed: %d\n", dwStatus);
  109.             acedRetNil();
  110.             return (RSRSLT);
  111.         }
  112.
  113.         if (!CryptCreateHash(hProv, CALG_MD5, 0, 0, &hHash))
  114.         {
  115.             dwStatus = GetLastError();
  116.             acutPrintf(L"CryptAcquireContext failed: %d\n", dwStatus);
  117.             acedRetNil();
  118.             return (RSRSLT);
  119.         }
  120.
  121.         if (!CryptHashData(hHash, bytes.data(), bytes.size(), 0))
  122.         {
  123.             dwStatus = GetLastError();
  124.             acutPrintf(L"CryptHashData failed: %d\n", dwStatus);
  125.             CryptReleaseContext(hProv, 0);
  126.             CryptDestroyHash(hHash);
  127.             acedRetNil();
  128.             return dwStatus;
  129.         }
  130.
  131.         CString hash;
  132.         cbHash = MD5LEN;
  133.         if (CryptGetHashParam(hHash, HP_HASHVAL, rgbHash, &cbHash, 0))
  134.         {
  135.             for (DWORD i = 0; i < cbHash; i++)
  136.             {
  137.                 hash += (wchar_t(rgbDigits[rgbHash[i] >> 4]));
  138.                 hash += (wchar_t(rgbDigits[rgbHash[i] & 0xf]));
  139.             }
  140.             acedRetStr(hash);
  141.         }
  142.         else
  143.         {
  144.             dwStatus = GetLastError();
  145.             acutPrintf(L"CryptGetHashParam failed: %d\n", dwStatus);
  146.         }
  147.         CryptDestroyHash(hHash);
  148.         CryptReleaseContext(hProv, 0);
  149.         return (RSRSLT);
  150.     }
  151.
« Reply #19 on: October 22, 2022, 12:18:50 AM »
Actually, this could be handy for creating a hash map of lists... maybe
Code - Text: [Select]
  1. (map of lists
  2.   '("bada286cb105994eb4b2426308dee64d" 39 50 50 5 33 36 37 37 25 29 31 32 32 1 19 24 24 25 28 29 13 14 14 17 18 21 21 23 12)
  3.   '("100d9e9bc0ef4990807d95c7faebaba0" 39 50 50 5 33 36 37 37 25 29 31 32 32 1 19 24 24 25 28 29 13 14 14 17 18 21 21 23 32)
  4.    ...
  5. )
« Reply #20 on: October 22, 2022, 03:05:31 PM »
Here's an incredibly slow one... mostly due to the fact that I had to represent 32-bit unsigned integers as lists of binary digits (as AutoLISP only has signed 32-bit integers), and then recreate list equivalents to the lsh & boole functions (which can only operate on 32-bit signed integers) to perform the various bitwise operations...  :lol:
« Reply #21 on: October 22, 2022, 06:13:38 PM »
Awesome code LM!
« Reply #22 on: October 23, 2022, 05:30:11 AM »
Thanks Daniel  :-)
xdcad
« Reply #23 on: November 22, 2023, 06:19:10 PM »
when this possibility will be available for the normal people ? :-)
(xdrx-file-md5hash fn)
(xdrx-string-md5hash "abcdefg")
Command: (xdrx-string-md5hash "abcdefg")
"7ac66c0f148de9519b8bd264312c4d64"
https://github.com/xdcad
https://sourceforge.net/projects/xdrx-api-zip/
http://bbs.xdcad.net
