Author Topic: How to improve the computing speed of MD5  (Read 5122 times)
baitang36
« on: October 16, 2022, 09:28:21 PM »
The MD5 algorithm of the lsp version is very slow, which is criticized by many people. Can you optimize it and improve the speed?
Yc-MD5.lsp is the source code of MD5 algorithm for lsp version found in the forum. It has been changed from time to time with little speed improvement. It seems that we need to find another way out.
The problem with the lsp version of MD5 is that it uses lsp to build wheels and uses lsp statements to implement MD5.
After searching, it is found that the Windows kernel has MD5 algorithm, that is, it provides the API of MD5 algorithm, so long as it is called, there is no need to make your own wheel.
syz-md5.fas is implemented by calling the system api with pure lsp. 32-bit and 64 bit are common. The usage is after loading (syz-md5 "string"). The return value is the MD5 value string of the string. The speed can be described as fast. In my test, 500 MD5 calculations were performed, and the yc-md5 program took 14.15 seconds; The syz-md5 program takes 0.032 seconds, and the speed difference is 400 times.
Tt5.lsp is the test program.
Command: (LOAD "D:/aa/tt5. lsp") C: TT5
Command: tt5
This method is only applicable to autocad because it uses the unexposed functions of autocad
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: How to improve the computing speed of MD5
« Reply #1 on: October 17, 2022, 02:11:25 AM »
500 MD5 calculations seems a lot.
Called Kerry in my other life
I live at UTC + 13.00
d2010
« Reply #2 on: October 17, 2022, 11:13:07 AM »
For optimize the code source.lisp, then you  must learn, before, other programming  language. (e.g Java, Julia, ). Why?
Because .. The module javac.exe contain hunders * hunders of optimizations.
Too many years, 10-50 engineers work at
--a)code optimization of speed
--b)code optimization of eating memory
--c)code optimization of parse the variabile (local, static ,global , dynamical, incapsulate inside Object)
Ps:=Visual Lisp are too weak for support the optimizations.
 :sleezy:
« Last Edit: October 17, 2022, 11:17:04 AM by d2010 »
VovKa
  • Ukraine
« Reply #3 on: October 17, 2022, 01:53:50 PM »
and this is great news, baitang36
well done
i think it brings lisp to a new level
domenicomaria
« Reply #4 on: October 17, 2022, 02:00:06 PM »
when this possibility will be available for the normal people ? :-)
baitang36
« Reply #5 on: October 18, 2022, 07:43:17 PM »
Because this technology is not disclosed by autodesk, I am afraid that if it is disclosed, it will be blocked and will not be used in the future
baitang36
« Reply #6 on: October 18, 2022, 07:44:58 PM »
well done
I tested that there was no problem in the 32-bit system. However, in 64 bit systems, some APIs will make mistakes
domenicomaria
« Reply #7 on: October 18, 2022, 10:55:19 PM »
but maybe with Bricscad it could be different ...
VovKa
  • Ukraine
« Reply #8 on: October 19, 2022, 05:26:15 AM »
i guess the api function that generates MD5 hash works with strings, takes a string as an argument and returns a string
what about arrays?
is there a way to pass an array as an argument to dll calls?
baitang36
« Reply #9 on: October 19, 2022, 07:19:27 AM »
what about arrays?
In fact, the input of md5 is a pile of binary data, and the output is also binary. It is made into a string for reading convenience
The array can be converted to a string first, and then MD5 can be calculated
baitang36
« Reply #10 on: October 19, 2022, 07:24:54 AM »
well done
  Called ntdll.dll, core code is :
(syz-api "ntdll.dll" "MD5Init" ctx)
  (syz-api "ntdll.dll" "MD5Update" ctx str1  (strlen str1)  )
  (syz-api "ntdll.dll" "MD5Final" ctx)
VovKa
  • Ukraine
« Reply #11 on: October 19, 2022, 08:10:55 AM »
this is clear
what if i want to pass to a dll function an array of floats (list of point coordinates for example)?
is it possible with syz-api?
baitang36
« Reply #12 on: October 19, 2022, 08:34:40 AM »
this is clear
(syz-md5(strcat(rtos x)(rtos y)(rtos z)))
VovKa
  • Ukraine
« Reply #13 on: October 19, 2022, 09:09:03 AM »
a have a library of functions written i C++ and compiled to a dll file (i can not modify it)
i want to call one of these functions from lisp and pass two arguments to it, one is a float and another is an array of floats
can it be done with your syz-api function?
baitang36
« Reply #14 on: October 19, 2022, 09:50:09 PM »
syz-api only support string and inter(addr)
