Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
help: Add Vertices to selected overlaping polylines at intersecting point
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: help: Add Vertices to selected overlaping polylines at intersecting point (Read 1067 times)
PM
Guest
on:
October 12, 2022, 09:06:59 AM »
hi. I use this code to add vertex on intersection of polylines, but this code works only for one polyline a time. Is it possible to select multyle polylines and insert to all the extra vertex?
Code - Auto/Visual Lisp:
[Select]
;;; pvx - adds vertices at intersection of pline and selection set of curves ;;;
defun
c:pvx
intersobj1obj2 LM:Unique AT:GetVertices member
fuzz add_vtx
s1 ss ent n entx intpts intptsall plpts par f
vl-load-com
defun
intersobj1obj2
obj1 obj2
coords pt ptlst
if
eq
type
obj1
'ENAME
setq
obj1
vlax
ename
vla-object
obj1
if
eq
type
obj2
'ENAME
setq
obj2
vlax
ename
vla-object
obj2
setq
coords
vl
catch
all
apply
'vlax
safearray
list
list
vl
catch
all
apply
'vlax
variant-value
list
vla-intersectwith
obj1 obj2 AcExtendNone
if
vl-catch-all-error-p
coords
setq
ptlst
nil
repeat
length
coords
3
setq
pt
list
car
coords
cadr
coords
caddr
coords
setq
ptlst
cons
pt ptlst
setq
coords
cdddr
coords
ptlst
defun
LM:Unique
lst
if
lst
cons
car
lst
LM:Unique
vl-remove
car
lst
cdr
lst
defun
AT:GetVertices
e
p l
LM:Unique
if
e
if
eq
setq
p
vlax-curve-getEndParam
e
fix
p
repeat
setq
p
1+
fix
p
setq
l
cons
vlax-curve-getPointAtParam
e
setq
p
1-
p
l
list
vlax-curve-getStartPoint
e
vlax-curve-getEndPoint
e
defun
member
fuzz
expr lst fuzz
while
and
lst
not
equal
car
lst
expr fuzz
setq
lst
cdr
lst
lst
defun
add_vtx
obj add_pt ent_name
bulg sw ew
vla-GetWidth
obj
fix
add_pt
'sw 'ew
vla-addVertex
obj
1+
fix
add_pt
vlax
make
variant
vlax-safearray-fill
vlax
make
safearray
vlax-vbdouble
cons
0
1
list
car
trans
vlax-curve-getpointatparam
obj add_pt
0
ent_name
cadr
trans
obj add_pt
0
ent_name
setq
bulg
vla-GetBulge
obj
fix
add_pt
vla-SetBulge
obj
fix
add_pt
sin
4
atan
bulg
add_pt
fix
add_pt
4
cos
4
atan
bulg
add_pt
fix
add_pt
4
vla-SetBulge
obj
1+
fix
add_pt
sin
4
atan
bulg
1+
fix
add_pt
add_pt
4
cos
4
atan
bulg
1+
fix
add_pt
add_pt
4
vla-SetWidth
obj
fix
add_pt
sw
sw
ew sw
add_pt
fix
add_pt
vla-SetWidth
obj
1+
fix
add_pt
sw
ew sw
add_pt
fix
add_pt
ew
vla-update
obj
prompt
\n
Pick source POLYLINE..."
setq
s1
ssget
"_+.:E:S:L"
list
0
"*POLYLINE"
4
"<or"
70
0
70
1
70
128
70
129
4
"or>"
cons
410
if
1
getvar
'cvport
getvar
'ctab
"Model"
while
not
s1
prompt
\n
Missed... Try picking source POLYLINE on unlocked layer again..."
setq
s1
ssget
"_+.:E:S:L"
list
0
"*POLYLINE"
4
"<or"
70
0
70
1
70
128
70
129
4
"or>"
cons
410
if
1
getvar
'cvport
getvar
'ctab
"Model"
prompt
\n
Now select intersecting curves..."
setq
ss
ssget
list
0
"*POLYLINE,SPLINE,LINE,ARC,CIRCLE,ELLIPSE,HELIX,RAY,XRAY"
cons
410
if
1
getvar
'cvport
getvar
'ctab
"Model"
while
not
ss
prompt
\n
Empty sel.set... Please reselect intersecting curves again..."
setq
ss
ssget
list
0
cons
410
if
1
getvar
'cvport
getvar
'ctab
"Model"
setq
ent
ssname
s1
0
if
cdr
assoc
0
entget
ent
"POLYLINE"
progn
command
"_.CONVERTPOLY"
"_L"
ent
entupd
setq
ent
entlast
vla-update
vlax
ename
vla-object
ent
setq
f t
repeat
setq
n
sslength
ss
setq
entx
ssname
ss
setq
n
1-
n
setq
intpts
intersobj1obj2 ent entx
setq
intptsall
append
intpts intptsall
foreach
intpt intptsall
setq
plpts
AT:GetVertices ent
if
and
not
member
fuzz intpt plpts 1e
6
setq
par
vlax-curve-getparamatpoint
ent
vlax-curve-getclosestpointto
ent intpt
add_vtx
vlax
ename
vla-object
ent
par ent
if
f
progn
command
"_.CONVERTPOLY"
"_H"
ent
entupd
setq
ent
entlast
vla-update
vlax
ename
vla-object
ent
princ
Logged
ribarm
Gator
Marko Ribar, architect
WWW
Re: help: Add Vertices to selected overlaping polylines at intersecting point
Reply #1 on:
October 12, 2022, 10:25:12 AM »
Here are my plintav*.lsp routines from my PLINETOOLS archive...
You should be able to achieve what you asked with some of them...
M.R.
Logged
Marko Ribar, d.i.a.
(graduated engineer of architecture)
M.R. on Youtube
PM
Guest
Reply #2 on:
October 15, 2022, 02:19:14 PM »
Thanks. What the differense between this 4 files. The plintav-new.lsp is the last version?
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
