Author Topic: Attout and Attin but for Set Property Custom Data  (Read 2133 times)
jtm2020hyo
« on: October 10, 2022, 04:22:31 PM »
Anyone knows if is there any .net app to extract info from the Set Property Custom Data in AutoCAD MEP, Civil 3D and AutoCAD Architecture?
I mean, similar to Attin and ATTout for Attributes Definitions
It's Alive!
  • Retired
  • AKA Daniel
Re: Attout and Attin but for Set Property Custom Data
« Reply #1 on: October 10, 2022, 06:18:59 PM »
If those properties are included in dataextraction, then you may be able to use the dataextraction API
or maybe just use dataextraction
huiz
  • Certified Prof C3D
« Reply #2 on: October 11, 2022, 01:56:48 AM »
You can use Dynamo to extract the data.
