Hello all,
I have copied a layout that contains a viewport (New Layout).
In the viewport there is an object in model space.
Now I copy this object to another place in the model space.
Her comes my question...
in my previously copied layout with the viewport (new layout), I want now to have the same view on the copied object as the 'old' viewport has on the 'old' object.
The whole thing should not work via commands or switching to the layouts or AF's, but programmatically via Lisp/Vlisp.
In my manual attempts I noticed that the only difference between the two AF's is the dxf 12 an 17. But these Points couldn't be changed by subst, and they are not in a vl-propetry list.
However, I don't know how to calculate this point, let alone what it should even mean.
So how can i point to the new view using (V)Lisp?
