Author Topic: Function similar to DOS_Copy  (Read 2150 times)
Marc'Antonio Alessi
  • Marco
« on: September 16, 2022, 10:25:15 AM »
What do you think about this function to get a result similar to DOS_Copy?
  1. ; (ALE_Files_CopyDir "Z:\\Temp\\" "Z:\\Temp2\\" "Foo*.txt" 1)
  2. ; (ALE_Files_CopyDir "Z:\\Temp\\" "Z:\\Temp2\\" "Foo.txt" 1)
  3. ; SrcDir - [str] Source Directory
  4. ; DstDir - [str] Destination Directory
  5. ; FlsPat - [str] Pattern
  6. ; BitVal - [bol] 1= overwrite existing file
  7. ; BitVal - [bol] 2= move existing file
  8. ; Return Values  Type: List > if the copy was successful, otherwise nil.
  9. ;
  10. (defun ALE_Files_CopyDir (SrcDir DstDir FlsPat BitVal / FilLst FunNam OwrBit MovBit)
  11.   (or (wcmatch SrcDir "*[\\/]") (setq SrcDir (strcat SrcDir "\\")))
  12.   (or (wcmatch DstDir "*[\\/]") (setq DstDir (strcat DstDir "\\")))
  13.   (and
  14.     BitVal
  15.     (progn
  16.       (and (= 1 (logand 1 BitVal)) (setq OwrBit T))
  17.       (and (= 2 (logand 2 BitVal)) (setq MovBit T))
  18.     )
  19.   )
  20.   (if (setq FilLst (vl-directory-files SrcDir FlsPat 1))
  21.     (progn
  22.       (or (vl-file-directory-p DstDir) (vl-mkdir DstDir))
  23.       (setq FunNam (if MovBit vl-file-rename vl-file-copy))
  24.       (foreach ForElm FilLst
  25.         (if (findfile (setq DstFil (strcat DstDir ForElm)))
  26.           (and
  27.             OwrBit
  28.             (vl-file-delete DstFil)
  29.             (FunNam (strcat SrcDir ForElm) DstFil)
  30.           )
  31.           (FunNam (strcat SrcDir ForElm) DstFil)
  32.         )
  33.       )
  34.       (cons DstDir (vl-directory-files DstDir FlsPat 1))
  35.     )
  36.   )
  37. )
  38.
VovKa
  • Ukraine
Re: Function similar to DOS_Copy
« Reply #1 on: September 16, 2022, 11:40:00 AM »
it's not safe to delete a file prior to successful copying
Marc'Antonio Alessi
  • Marco
« Reply #2 on: September 16, 2022, 03:12:20 PM »
You're right, it's the destination file anyway ... maybe it's better to rename it with a temporary name and then delete it after copying or rename it again if the copy fails?
(this because the vl-file-copy function will not overwrite an existing file).
VovKa
  • Ukraine
« Reply #3 on: September 16, 2022, 04:10:37 PM »
or copy to a temporary name and then if copying successful delete existing file and rename temporary
BIGAL
  • 40 + years of using Autocad
« Reply #4 on: September 16, 2022, 08:03:50 PM »
You can use Shell and get at the old fashioned DOS commands XCOPY comes to mind.
(command "shell" ..... do your thing)
More recently starting to use Powershell inside windows. Can do stuff like unzip. Lots of help out there.
Marc'Antonio Alessi
  • Marco
« Reply #5 on: September 17, 2022, 03:28:01 AM »
Yes, with Shell you can do a lot of things but I think IMHO that in case of error you have less possibility of control.
Marc'Antonio Alessi
  • Marco
« Reply #6 on: September 17, 2022, 03:31:29 AM »
Maybe this is more safe:
  2. ; Version 1.01
  9. ;
  13.   (and
  14.     BitVal
  15.     (progn
  18.     )
  19.   )
  21.     (progn
  26.           (and
  27.             OwrBit
  28.             (if (and (vl-file-rename DstFil (strcat DstFil ".tmp")) (FunNam (strcat SrcDir ForElm) DstFil))
  29.               (vl-file-delete (strcat DstFil ".tmp"))
  30.               (progn
  31.                 (vl-file-rename (strcat DstFil ".tmp") DstFil)
  32.                 (alert (strcat "File " SrcDir ForElm " not Copied or Renamed."))
  33.               )
  34.             )
  35.           )
  36.           (FunNam (strcat SrcDir ForElm) DstFil)
  37.         )
  38.       )
  39.       (cons DstDir (vl-directory-files DstDir FlsPat 1))
  40.     )
  41.   )
  42. )
« Reply #7 on: September 19, 2022, 03:35:26 PM »
Marc'Antonio Alessi
  • Marco
« Reply #9 on: September 20, 2022, 09:40:06 AM »
Xcopy is faster… tested with 430 existing files
(Benchmark '(
(ALE_Files_CopyDir "Z:\\Temp\\testfiles" "Z:\\Temp2\\testfiles" "*.*" 1)
(LM:copyfolder "z:\\temp\\testfiles" "z:\\temp2\\testfiles" T)
(rjp-xcopy "z:\\temp\\testfiles" "*.*" "z:\\temp2\\testfiles" "/d/c/i/k/r/y/q/s")
--- Benchmark utility: In memory of Michael Puckett ---
Elapsed milliseconds / relative speed for 16 iteration(s):
    (RJP-XCOPY "z:\\temp\\testfiles" "*....)......1171 / 30.61 <fastest>
    (RJP-XCOPY "z:\\temp\\testfiles" "*....)......1610 / 22.26
    (LM:copyfolder "z:\\temp\\tes..........).....16032 / 2.24
    (LM:copyfolder "z:\\temp\\tes..........).....16313 / 2.2
    (ALE_FILES_COPYDIR "Z:\\Temp\\testfi...).....27437 / 1.31
    (ALE_FILES_COPYDIR "Z:\\Temp\\testfi...).....35844 / 1 <slowest>
ALE_FILES_COPYDIR2 >> no vl-file-rename existing files but deleting before copy
(Benchmark '(
(ALE_Files_CopyDir2 "Z:\\Temp\\testfiles" "Z:\\Temp2\\testfiles" "*.*" 1)
    (RJP-XCOPY "z:\\temp\\testfiles" "*....)......1375 / 17.62 <fastest>
    (RJP-XCOPY "z:\\temp\\testfiles" "*....)......2250 / 10.77
    (ALE_FILES_COPYDIR2 "Z:\\Temp\\testf...).....21671 / 1.12
    (ALE_FILES_COPYDIR2 "Z:\\Temp\\testf...).....24234 / 1 <slowest>
Marc'Antonio Alessi
  • Marco
« Reply #10 on: September 20, 2022, 09:53:21 AM »
DOS_Copy
(Benchmark '(
(dos_copy "Z:\\Temp\\testfiles\\*.*" "Z:\\Temp2\\testfiles")
    (RJP-XCOPY "z:\\temp\\testfiles" "*....)......2015 / 12.51 <fastest>
    (RJP-XCOPY "z:\\temp\\testfiles" "*....)......2063 / 12.22
    (DOS_COPY "Z:\\Temp\\testfiles\\*.*"...).....23531 / 1.07
    (DOS_COPY "Z:\\Temp\\testfiles\\*.*"...).....25203 / 1 <slowest>
« Reply #11 on: September 20, 2022, 01:11:26 PM »
Marc'Antonio Alessi
  • Marco
« Reply #12 on: September 21, 2022, 08:29:40 AM »
Might try the robocopy version too :)
http://www.theswamp.org/index.php?topic=39415.msg582702#msg582702
Yes... robocopy is faster…
(Benchmark '(
(rjp-robocopy "z:\\temp\\testfiles" "*.*" "z:\\temp2\\testfiles" "/XD")
Elapsed milliseconds / relative speed for 64 iteration(s):
    (RJP-ROBOCOPY "z:\\temp\\testfiles" ...).....1015 / 4.4 <fastest>
    (RJP-ROBOCOPY "z:\\temp\\testfiles" ...).....1016 / 4.4
    (RJP-XCOPY "z:\\temp\\testfiles" "*....).....4469 / 1
    (RJP-XCOPY "z:\\temp\\testfiles" "*....).....4469 / 1 <slowest>
Edit: I have found out I swapped 2 parameters but strangely the program works the same...
this is the right syntax (rjp-robocopy "z:\\temp\\testfiles" "z:\\temp2\\testfiles" "*.*" "/XD")
