Author Topic: Import Dimension Style  (Read 901 times)
V-Man
« on: September 14, 2022, 09:31:07 AM »
Good morning, Having a little issue with the following code for inserting settings to dimension style. I believe the code is CAB's
(defun c:IDIM (/ acdoc dsobj obj)
  (setq acdoc (vla-get-activedocument (vlax-get-acad-object)))
  (setq dsobj (vla-get-dimstyles acdoc))
  (vlax-for obj dsobj
    (vla-put-activedimstyle acdoc (vla-item dsobj (vla-get-name obj))) ;set dimstyle current
    (vlax-invoke acdoc 'setvariable "DIMADEC" 0)
    (vlax-invoke acdoc 'setvariable "DIMALT" 0)
    (vlax-invoke acdoc 'setvariable "DIMALTD" 2)
    (vlax-invoke acdoc 'setvariable "DIMALTF" 25.4000)
    (vlax-invoke acdoc 'setvariable "DIMALTRND" 0.0000)
    (vlax-invoke acdoc 'setvariable "DIMALTTD" 2)
    (vlax-invoke acdoc 'setvariable "DIMALTTZ" 0)
    (vlax-invoke acdoc 'setvariable "DIMALTU" 2)
    (vlax-invoke acdoc 'setvariable "DIMALTZ" 0)
    (vlax-invoke acdoc 'setvariable "DIMARCSYM" 0)
    (vlax-invoke acdoc 'setvariable "DIMASSOC" 2)
    (vlax-invoke acdoc 'setvariable "DIMASZ" 0.1800)
    (vlax-invoke acdoc 'setvariable "DIMATFIT" 3)
    (vlax-invoke acdoc 'setvariable "DIMAUNIT" 0)
    (vlax-invoke acdoc 'setvariable "DIMAZIN" 0)
    (vlax-invoke acdoc 'setvariable "DIMCEN" 0.0900)
    (vlax-invoke acdoc 'setvariable "DIMCLRD" 0)
    (vlax-invoke acdoc 'setvariable "DIMCLRE" 0)
    (vlax-invoke acdoc 'setvariable "DIMCLRT" 0)
    (vlax-invoke acdoc 'setvariable "DIMCONSTRAINTICON" 3)
    (vlax-invoke acdoc 'setvariable "DIMCONTINUEMODE" 1)
    (vlax-invoke acdoc 'setvariable "DIMDEC" 2)
    (vlax-invoke acdoc 'setvariable "DIMDLE" 0.0000)
    (vlax-invoke acdoc 'setvariable "DIMDLI" 0.3800)
    (vlax-invoke acdoc 'setvariable "DIMEXE" 0.1800)
    (vlax-invoke acdoc 'setvariable "DIMEXO" 0.0625)
    (vlax-invoke acdoc 'setvariable "DIMFRAC" 0)
    (vlax-invoke acdoc 'setvariable "DIMFXL" 1.0000)
    (vlax-invoke acdoc 'setvariable "DIMFXLON" 0)
    (vlax-invoke acdoc 'setvariable "DIMGAP" 1.0000)
    ;(vlax-invoke acdoc 'setvariable "DIMJOGANG" 0.7854)
    (vlax-invoke acdoc 'setvariable "DIMJUST" 0)
    (vlax-invoke acdoc 'setvariable "DIMLFAC" 1.0000)
    (vlax-invoke acdoc 'setvariable "DIMLIM" 0)
    (vlax-invoke acdoc 'setvariable "DIMLUNIT" 2)
    (vlax-invoke acdoc 'setvariable "DIMLWD" -2)
    (vlax-invoke acdoc 'setvariable "DIMLWE" -2)
    (vlax-invoke acdoc 'setvariable "DIMPICKBOX" 5)
    (vlax-invoke acdoc 'setvariable "DIMRND" 0.0000)
    (vlax-invoke acdoc 'setvariable "DIMSAH" 0)
    (vlax-invoke acdoc 'setvariable "DIMSCALE" 1.0000)
    (vlax-invoke acdoc 'setvariable "DIMSD1" 1)
    (vlax-invoke acdoc 'setvariable "DIMSD2" 1)
    (vlax-invoke acdoc 'setvariable "DIMSE1" 1)
    (vlax-invoke acdoc 'setvariable "DIMSE2" 1)
    (vlax-invoke acdoc 'setvariable "DIMSOXD" 0)
    (vlax-invoke acdoc 'setvariable "DIMTAD" 1)
    (vlax-invoke acdoc 'setvariable "DIMTDEC" 2)
    (vlax-invoke acdoc 'setvariable "DIMTFAC" 1.0000)
    (vlax-invoke acdoc 'setvariable "DIMTFILL" 0)
    (vlax-invoke acdoc 'setvariable "DIMTFILLCLR" 0)
    (vlax-invoke acdoc 'setvariable "DIMTIH" 0)
    (vlax-invoke acdoc 'setvariable "DIMTIX" 0)
    (vlax-invoke acdoc 'setvariable "DIMTM" 0.0000)
    (vlax-invoke acdoc 'setvariable "DIMTMOVE" 0)
    (vlax-invoke acdoc 'setvariable "DIMTOFL" 0)
    (vlax-invoke acdoc 'setvariable "DIMTOH" 0)
    (vlax-invoke acdoc 'setvariable "DIMTOL" 0)
    (vlax-invoke acdoc 'setvariable "DIMTOLJ" 1)
    (vlax-invoke acdoc 'setvariable "DIMTP" 0.0000)
    (vlax-invoke acdoc 'setvariable "DIMTSZ" 0.0000)
    (vlax-invoke acdoc 'setvariable "DIMTVP" 0.0000)
    (vlax-invoke acdoc 'setvariable "DIMTXSTY" Standard)
    (vlax-invoke acdoc 'setvariable "DIMTXT" 3.5000)
    (vlax-invoke acdoc 'setvariable "DIMTXTDIRECTION" 0)
    (vlax-invoke acdoc 'setvariable "DIMTXTRULER" 1)
    (vlax-invoke acdoc 'setvariable "DIMTZIN" 0)
    (vlax-invoke acdoc 'setvariable "DIMUPT" 0)
    (vlax-invoke acdoc 'setvariable "DIMZIN" 0)
    (vla-copyfrom obj acdoc) ; update the Dim Style
It produces the following error in Autocad Civil 3D
; error: Autodesk Civil 3D 2023: Error setting system variable
Tharwat
  • Hypersensitive
Re: Import Dimension Style
« Reply #1 on: September 14, 2022, 10:57:28 AM »
HINT, if you have the dimension style created then create a block with that dimension style in a separate DWG and locate it in any of AutoCAD search paths.
So now you can import the block with the insert command very easily.
« Reply #2 on: September 14, 2022, 11:06:11 AM »
The error is because you are trying to set an error Civil3D doesn't like. I'm sure if you used VSCode/vlide you can find the pesky variable.
FWITW: I still use this ancient method (almost the same principal). I have not found a reason to update it, honestly.
  1. (defun c:CreateDimstyle ()
  2.  (command "-style" "Annotative-Default" "Arial.ttf" "Annotative" "yes" "no" "0.09375" "1.0" "0" "no" "no")
  3.  (mapcar        'eval
  4.   '((setvar "DIMADEC" 0)          (setvar "DIMALT" 0)             (setvar "DIMALTD" 2)
  5.     (setvar "DIMALTF" 25.4)       (setvar "DIMALTRND" 0.0)        (setvar "DIMALTTD" 2)
  6.     (setvar "DIMALTTZ" 0)         (setvar "DIMALTU" 2)            (setvar "DIMALTZ" 0)
  7.     (setvar "DIMAPOST" "")        (setvar "DIMASZ" 0.125)         (setvar "DIMATFIT" 3)
  8.     (setvar "DIMAUNIT" 0)         (setvar "DIMAZIN" 0)            (setvar "DIMBLK1" "")
  9.     (setvar "DIMBLK2" "")         (setvar "DIMCEN" 0.09375)       (setvar "DIMCLRD" 256)
  10.     (setvar "DIMCLRE" 256)        (setvar "DIMCLRT" 256)          (setvar "DIMDEC" 1)
  11.     (setvar "DIMDLE" 0.0)         (setvar "DIMDLI" 0.125)         (setvar "DIMEXE" 0.0625)
  12.     (setvar "DIMEXO" 0.0625)      (setvar "DIMFRAC" 0)            (setvar "DIMGAP" 0.0625)
  13.     (setvar "DIMJUST" 0)          (setvar "DIMLFAC" 1.0)          (setvar "DIMLIM" 0)
  14.     (setvar "DIMLUNIT" 2)         (setvar "DIMLWD" -2)            (setvar "DIMLWE" -2)
  15.     (setvar "DIMPOST" "")         (setvar "DIMRND" 0.0)           (setvar "DIMSAH" 0)
  16.     (setvar "DIMSD1" 0)           (setvar "DIMSD2" 0)             (setvar "DIMSE1" 0)
  17.     (setvar "DIMSE2" 0)           (setvar "DIMSOXD" 0)            (setvar "DIMTAD" 1)
  18.     (setvar "DIMTDEC" 1)          (setvar "DIMTFAC" 1.0)          (setvar "DIMTIH" 1)
  19.     (setvar "DIMTIX" 0)           (setvar "DIMTM" 0.0)            (setvar "DIMTMOVE" 0)
  20.     (setvar "DIMTOFL" 0)          (setvar "DIMTOH" 1)             (setvar "DIMTOL" 0)
  21.     (setvar "DIMTOLJ" 1)          (setvar "DIMTP" 0.0)            (setvar "DIMTSZ" 0.0)
  22.     (setvar "DIMTXT" 0.03125)     (setvar "DIMTZIN" 0)            (setvar "DIMUPT" 0)
  23.     (setvar "DIMTVP" 0.0)         (setvar "DIMTXSTY" "Annotative-Default")
  24.     )
  25.   )
  26.   (command "-dimstyle" "AN" "yes" "Annotative-Default" "")
  27. )
V-Man
« Reply #3 on: September 14, 2022, 11:10:32 AM »
@Tharwat - Just a fantastic idea.
@JohnK - Thanks for the input.
Much appreciated guys.....
Thanks,
V-Man
Lonnie
« Reply #4 on: September 14, 2022, 04:28:04 PM »
Something along Tharwat's answer.
I did this not a week ago for layers.
  1. (defun SS_sslist ()
  2.
  3.         ssl (if ss (sslength ss) 0)
  4.         cnt 0
  5.         ELst '()
  6. )
  7.
  8. (repeat ssl
  9.         (setq
  10.                 ELst (cons (ssname ss cnt) ELst)
  11.                 cnt (1+ cnt)
  12.         )
  13. )
  14. ;(setq tear_into_this (reverse ELst))
  15.
  16.     (command "change" ss "" "p" "layer" set-to-this-layer "")
  17.    (foreach temp_var ELst (if (or (= (cdr (assoc 0 (entget temp_var))) "TEXT")
  18.                                             (= (cdr (assoc 0 (entget temp_var))) "LEADER")
  19.                                             (= (cdr (assoc 0 (entget temp_var))) "MTEXT"))
  20. (COMMAND "CHANGE" temp_var "" "p" "layer" set-to-this-layer-for-txt ""))
  21.   )
  22.   (Princ "Moved to ") (prin1 (strcase set-to-this-layer)) (Prompt " or ") (prin1 (strcase set-to-this-layer-for-txt))
  23.   (setvar "cmdecho" 0)
  24. )
  25.
  26. ---End This needs to be here---
  27.
  28. ;;; 2022-09-01 Fire Control Layers
  29.
  30.     (defun c:F-AUX0 ()
  31.   (setq ss (ssget))(command "undo" "begin")
  32.   (setq set-to-this-layer "F-AUX0")
  33.   (setq set-to-this-layer-for-txt "F-AUX0")
  34.          (if (= (tblsearch "layer" set-to-this-layer) nil) (command "-INSERT" "*//designdata/cadd/ACAD/DEFAULT/General/Symbols/firecontrollayers.DWG" "0,0" "1" ""))
  35. (setvar "clayer" set-to-this-layer)(SS_sslist)(command "undo" "end")
  36.   )
EDIT (John): Added code tags.
« Last Edit: September 15, 2022, 09:06:16 AM by JohnK »
