Author Topic: Editing an Excel file  (Read 234 times)
civil.eng
« on: September 13, 2022, 03:28:07 PM »
Hello everyone,
I have a subrutin to open an Excel file and add some changes into it, it works well when the excel file is visible, but changes not saved after closing it by using programmatically :
  (setq f "D:\\262.csv")
  (setq excel (vlax-get-or-create-object "Excel.Application"))
  (vla-put-visible excel :vlax-true)
  (setq workbooks (vlax-get-property excel 'workbooks))
  (setq currworkbook (vlax-invoke-method workbooks 'open f))
  (setq xlsheets (vlax-get-property currworkbook "Sheets"))
  (setq xlsht (vlax-get-property xlsheets 'item 1))
  (vlax-put-property xlsht 'name "Points")
  (setq xlrng (vlax-get-property xlsht 'usedrange))
  (setq xlcol (vlax-get-property xlrng 'columns))
  (vl-catch-all-apply
    'vlax-invoke-method
    (list xlcol 'autofit)
  (vlax-invoke-method workbooks 'Close :vlax-true)
  (vlax-release-object workbooks)
  (vlax-invoke-method excel 'Quit)
  (vlax-release-object excel)
My aim is to open Excel file in a hidden way then making the changes and finally closing it automatically.
civil.eng
Re: Editing an Excel file
« Reply #1 on: September 19, 2022, 04:15:32 AM »
Any help
It's Alive!
  • Retired
  • AKA Daniel
« Reply #2 on: September 19, 2022, 05:06:10 AM »
Retired
dexus
« Reply #3 on: September 19, 2022, 05:54:59 AM »
When I try it I get a "Too many actual parameters" on the line: "(vlax-invoke-method workbooks 'Close :vlax-true)"
So I can't get the code to work, even when excel is opened.
