Author Topic: Enter causes routine to run on last items picked with unexpected results.  (Read 577 times)
jlogan02
After I run this once I hit an enter to run it again and pick other objects, but instead of allowing me to pick another entity it is running the routine a second time on the first set of entities and pushing them back to the original layer minus the -F.
  1. (defun c:futlyr ( / i lyrname s x )
  2. (prompt "\nSelect Object to Set to -F Construction Layer")
  3.    (setq s (ssget ":L" '((8 . "S*"))))
  4.         (repeat (setq i (sslength s))
  5.         (setq x (entget (ssname s (setq i (1- i))))
  6.               lyrname (cdr (assoc 8 x))
  7.               n (strcat (substr lyrname 1 (- (strlen lyrname) 0)) "-F") ;;(strlen old_suffix)))))
  8.         )
  9.             (if (not (tblsearch "layer" n))
  10.               (progn (setq e (entget (tblobjname "layer" lyrname)))
  11.                (entmake (subst (cons 2 n) (assoc 2 e) (subst '(62 . 1) (assoc 62 e) e)))
  12.               )
  13.             )
  14.               (entmod (subst (cons 8 n) (assoc 8 x) x))
  15.           )
  16.
  17.   (prompt "\nAll objects have been moved to -F construction layer")
  18.   (princ)
  19. )
  20.
  21. (c:futlyr)
J. Logan
ACAD 2018
I am one with the Force and the Force is with me.
AutoCAD Map 2018 Windows 10
mhupp
Their is nothing in the code to push them back (error handling?). All tho you can select things multiple times. ending up with layers like "layername-F-F-F"
Added a check to exclude items that are on a layer ending with "-F"
and gives a count of how many things have changed layers
  1. (defun c:futlyr (/ s layname x n i)
  3.   (setq i 0)
  4.   (setq s (ssget ":L" '((8 . "S*"))))
  5.   (foreach ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
  6.     (if (and (setq layname (cdr (assoc 8 (setq x (entget ent))))) (/= (substr layname (- (strlen layname) 1)) "-F"))
  7.       (progn
  8.         (if (not (tblsearch "layer" (setq n (strcat layname "-F"))))
  9.           (progn
  10.             (setq e (entget (tblobjname "layer" layname)))
  12.           )
  13.         )
  15.         (setq i (1+ i))
  16.       )
  17.     )
  18.   )
  19.   (prompt (strcat "\n" (itoa i) " objects moved to -F construction layer"))
  20.   (princ)
  21. )
jlogan02
Man, my whole post was wonky. I wrote it once asking about the multiple -Fs. Then decided to try and remove the entmake section as a test because I don't need it changing the color to red. When I removed it, I got the enter issue.
I forgot to remove that section from my post before.
  1. (if (not (tblsearch "layer" n))
  2.               (progn (setq e (entget (tblobjname "layer" lyrname)))
  3.                (entmake (subst (cons 2 n) (assoc 2 e) (subst '(62 . 1) (assoc 62 e) e)))
  4.               )
  5.             )
Thanks for adding the check. That went through my mind earlier in the day but didn't get it done.
J. Logan
ACAD 2018
You can also filter out the items directly like so:
  1. (defun c:futlyr (/ e i layname n s x)
  3.   (setq i 0)
  4.   ;; Direct filter for layer that starts with S and does not end in -F
  5.   (if (setq s (ssget ":L" '((8 . "S*,") (8 . "~*-F"))))
  6.     (progn
  7.       (foreach ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
  8.         (if (setq layname (cdr (assoc 8 (setq x (entget ent)))))
  9.           (progn (if (not (tblsearch "layer" (setq n (strcat layname "-F"))))
  10.                    (progn (setq e (entget (tblobjname "layer" layname)))
  12.                    )
  13.                  )
  15.                  (setq i (1+ i))
  16.           )
  17.         )
  18.       )
  20.     )
  21.   )
  22.   (princ)
  23. )
