thanks for the reply BIGAL, makes perfect sense what you say if I wanted one action after another, but it's not the case, if I do it that way, I would have as a result a routine that opens the flatshot command and creates a block with the content of the whole drawing, located where the object is, and also a flatshot command that asks me to select objects and would create another block with only selected objects but located in a random place as the original flatshot command does.
I need that only once the command is invoked, and creates the block with only the selected objects AND in the place of the original objects.
I don't know if I explained myself well
