Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Help: Rotate text and block by viewport ucs rotation
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Help: Rotate text and block by viewport ucs rotation (Read 220 times)
PM
Bull Frog
on:
July 31, 2022, 01:01:53 PM »
Hi. I am using this code to rote the text (to be easy to read) when i rotate viewport ucs (in case to print a drawing). I need help to update this code. I want to select multiple block and text or Mtext
Code - Auto/Visual Lisp:
[Select]
defun
c:ROV
ss2 i vta tmp
vl-load-com
prompt
\n
Select TEXT and MTEXT to rotate "
setq
ss2
ssget
0
"*TEXT"
i
0
vta
0
getvar
"viewtwist"
repeat
sslength
ss2
setq
tmp
vlax
ename
vla-object
ssname
ss2 i
if
eq
vla-get-ObjectName
tmp
"AcDbText"
progn
vlax-put
tmp
"Rotation"
vta
vlax-put
tmp
"Alignment"
acAlignmentLeft
progn
vlax-put
tmp
"Rotation"
0.0
vlax-put
tmp
"AttachmentPoint"
acAttachmentPointTopLeft
setq
i
1+
i
Logged
BIGAL
Swamp Rat
40 + years of using Autocad
Re: Help: Rotate text and block by viewport ucs rotation
Reply #1 on:
July 31, 2022, 07:46:25 PM »
Not sure how you want to pick blocks, (setq ss2 (ssget '((0 . "*TEXT,INSERT")))
Mtext supports the auto rotation in a viewport your homework.
Logged
Crank
Swamp Rat
Reply #2 on:
August 01, 2022, 01:20:15 PM »
@PM:
If you have the expresstools installed, then look at the TORIENT command. (You can find the lisp in ACETTXT.lsp)
Logged
Vault Professional 2022 + AEC Collection
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
