Author Topic: Change color - weird behaviour  (Read 939 times)
w64bit
« on: July 31, 2022, 06:58:59 AM »
I noticed that if I use in a script file:
(if (setq clr1 (ssget "X" (list '(-4 . "&=") '(62 . 250) (cons 410 "Model")))) (command "CHPROP" clr1 "" "C" 251 ""))
(if (setq clr2 (ssget "X" (list '(-4 . "&=") '(62 . 254) (cons 410 "Model")))) (command "CHPROP" clr2 "" "C" 253 ""))
The last line is changing the color to 251 instead 253. Why?
If I switch the lines, all it's OK.
Re: Change color - weird behaviour
« Reply #1 on: July 31, 2022, 05:05:47 PM »
DXF group 62 is not bit-coded and so you shouldn't use the bitwise operator in the ssget filter list - try:
  1. (if (setq clr1 (ssget "X" '((62 . 250) (410 . "Model")))) (command "_.CHPROP" clr1 "" "_C" 251 ""))
  2. (if (setq clr2 (ssget "X" '((62 . 254) (410 . "Model")))) (command "_.CHPROP" clr2 "" "_C" 253 ""))
w64bit
« Reply #2 on: August 01, 2022, 03:59:04 AM »
Thank you very much.
