For those using AutoCAD Map 3D & verticals only the undocumented "-MAPINSERTPLE" command will add North Arrows in Paper Space matching Model Space Rotation by selecting a Viewport Boundary. If you twist the viewport afterwards the North Arrow automatically rotates to match.
Described here:
https://forums.autodesk.com/t5/civil-3d-customization/civil-3d-2015-mapinsertple-command/m-p/9970125#M19256and here:
http://www.theswamp.org/index.php?topic=48049.0;allFor the record, here are the 3 "types":
2 = North Arrow
3 = Scale Bar
4 = Legend
(The "Select a viewport for the <type>:" command prompt changes based on which number you use.)
The Symbols folder for the "Map - North Arrows.dwg" can be opened with the Macro:
^C^C^P(progn(startapp "explorer" (strcat "/n,/e," (vl-string-subst (strcat "Map" (chr 92) "Sample" (chr 92) "Symbols") "express" (vl-filename-directory (findfile "acetauto.lsp")))))(princ));
I modified all of them to use masked Mtext with Standard text style referencing TrueType fonts so they wouldn't require adding additional text styles and displayed better over images into "Blocks.dwg" attached. Added a drop-down with macros of the North Arrows I've used like this one:
Command Name: Aerial N↑
Macro: ^C^C(command "-MAPINSERTPLE" "G://ENGDESGN//BeaufordT//Blocks//Blocks.dwg,Aerial,2")
Notice macro includes drawing name with path,block name,type=2.
