Author Topic: Sort list of points perpendicular to line  (Read 1226 times)
abe123456789
« on: July 21, 2022, 09:09:38 PM »
How can I sort a list of points perpendicular to a line going towards the line? I found this code to sort points but does not give me control any help will be appreciated. I attached a drawing to illustrate what I am meaning.
Thank you,
(vl-sort ptlist
                    '(lambda (x y)
                       (if (= (car x) (car y))
                         (< (cadr x) (cadr y))
                         (< (car x) (car y)))
dexus
Re: Sort list of points perpendicular to line
« Reply #1 on: July 22, 2022, 03:35:59 AM »
Maybe you can sort them by distance from the line.
So something along these lines:
  1. (setq target (car (entsel)))
  2. (vl-sort ptlist
  3.   (function (lambda (a b)
  4.     (<
  5.       (distance a (vlax-curve-getClosestPointTo target a))
  6.       (distance b (vlax-curve-getClosestPointTo target b))
  7.     )
  8.   ))
  9. )
For a lot of points you might want to cache the distances calculated in the list and sort on those so they don't have to be checked all the time.
« Last Edit: July 22, 2022, 03:39:15 AM by dexus »
abe123456789
« Reply #2 on: July 22, 2022, 11:24:57 AM »
lets say we got a list of points( 7 1 0) (6 1 0) (5 1 0) ( 4 1 0)
and we got a line with the start pt (8 3 0) and the line end pt ( 8 1 0)
How can i sort the list of points going towards the line?
Stefan
« Reply #3 on: July 22, 2022, 01:38:02 PM »
How do you want them sorted?
What if there are point on the right of the line?  (8 1 0) (9 1 0) (10 1 0) (11 1 0)
What if the line is reversed? from ( 8 1 0) to (8 3 0)
What if the line and the points are completely random?
abe123456789
« Reply #5 on: July 22, 2022, 05:52:08 PM »
I like the vl-sort i posted but i want to add the control where it goes in the direction of the line.
there wouldnt be point to the right of the line
the points wouldnt be random.
BIGAL
  • 40 + years of using Autocad
« Reply #6 on: July 22, 2022, 10:07:41 PM »
If its points like in crossing parallel lines then yes dexus is correct use sort on distance but your list would be like ((dist x y)(dist x y) (dist x y) where dist is distance from a pt on line to new points. I use this method often. Maybe also closestpointto where perp is required.
Stefan
« Reply #7 on: July 23, 2022, 05:19:30 AM »
... i want to add the control where it goes in the direction of the line.
If there are no points on the right, then sorting by X is enough, maybe just changing "<" to ">", you first code should do it.
Sorry, but for me, "control where it goes in the direction of the line" has no meaning.
Better draw some points, draw a line, label the points in the order you want them. Repeat for other situations. Post a screenshot.
BIGAL
« Reply #9 on: July 24, 2022, 01:33:57 AM »
The other thing to look at "Is it left or right" lee_mac has a routine that checks this so could make dist -ve for left and +ve for right sort should still work.
