Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Remove Nested Xrefs
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Remove Nested Xrefs (Read 781 times)
CMU
Mosquito
Remove Nested Xrefs
on:
July 21, 2022, 04:02:23 PM »
Good Day,
Does anyone know of a lisp that will take all the nested xrefs and xrefs them back into the drawing as xrefs only, thereby eliminating nested xrefs?
Any help would be appreciated.
Thank you
C.M.U
Logged
Lonnie
Newt
Re: Remove Nested Xrefs
Reply #1 on:
August 01, 2022, 01:33:42 PM »
Might help. I had a similar problem. I ended up doing to via pdf but there may be a nugget here to help you.
http://www.theswamp.org/index.php?topic=57235.msg607569#msg607569
Logged
57gmc
Bull Frog
Reply #2 on:
August 01, 2022, 04:04:09 PM »
You could open the xref and run the BIND command.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
Remove Nested Xrefs
