Author Topic: Questions about Layer  (Read 827 times)
MeasureUp
« on: July 19, 2022, 02:36:41 AM »
1st of all, there is no "filter" on the "-layer" command return list on the command prompt:
[?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile/Xref]
I am wondering if there is something else missing on the list as well. If yes, what are they?
Secondly, I know how to rename a layer by using "-layer" command:
(command ".-Layer" "Rename" "ABC" "Abc" "")
I'd like know how to make change from the layer table (list) in routine:
for example,
((0 . "LAYER") (2 . "ABC") (70 . 0) (62 . 7) (6 . "Continuous"))
Finally, how to switch from current layer group to the top parent "All" in routine?
Your helps are much appreciated.
dexus
Re: Questions about Layer
« Reply #1 on: July 19, 2022, 03:11:58 AM »
A couple of questions, I think this might answers one of them:
  1.   (subst
  2.     (cons 2 "NEW NAME")
  3.     (cons 2 "OLD NAME")
  4.     (entget (tblobjname "layer" "OLD NAME"))
  5.   )
  6. )
tombu
  • ByLayer=>Not0
« Reply #2 on: July 19, 2022, 07:34:24 AM »
While "-layer" has no filter option "+layer" does.
Enter it at the command line to see the options available.
Some verticals like Civil 3D also have Filter commands like LayerSaveFilterTree and LayerLoadFilterTree.
Tom Beauford P.S.M.
MeasureUp
« Reply #3 on: July 19, 2022, 08:00:23 PM »
Thanks dexus.
It works!
And thanks tombu.
"+layer" works.
But I have to use "layerclose" turn off the layer properties manager after setting the layer group to "All".
And IMO switching "filedia" value between "0" and "1" is not a good idea.
Both methods seem not good.
Is there a workaround?
Thanks.
Edit:
I figured it out.
It doesn't change to "All" while Layer Properties Manager is on.
It will show correctly when reopen Layer Properties Manager.
Now the 1st question in post #1 is still not resolved.
It seems the "+LAYER" command is invented to ONLY work for layer group.
Command: +LAYER
Specify filter [All/All Used Layers/Unreconciled New Layers/Viewport Overrides] <All>:
Why "+LAYER" command is not found in HELP?
And again, would any other functions not be listed in "-LAYER" options when "filter" function is hidden?
« Last Edit: July 20, 2022, 01:27:39 AM by MeasureUp »
tombu
  • ByLayer=>Not0
« Reply #4 on: July 21, 2022, 07:36:05 AM »
And thanks tombu.
"+layer" works.
Command: +LAYER
Unfortunately there's lots of functionality not described in AutoCAD Help. Try entering either
(command "_.layer" "_filter") or (command "_.layer" "_fi")
at the command line to see the filter options for the LAYER command.
Tom Beauford P.S.M.
