Author Topic: To Modify Block align lisp by ribam  (Read 828 times)
dussla
« on: July 08, 2022, 11:14:30 AM »
I found this lisp
That lisp is block align
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/align-blocks-automatically-lisp/td-p/7169917
(defun c:scatterblks-with-gaps ( / dispositionmatrix s g i m l b c k rn mn w h bp rh ) (vl-load-com) (defun dispositionmatrix ( n / f k r l ) (setq f (1+ (fix (sqrt (- n 0.5))))) (setq k 0) (repeat f (repeat f (setq k (1+ k)) (if (<= k n) (setq r (cons 1 r)) (setq r (cons 0 r)) ) ) (setq l (cons (reverse r) l) r nil) ) (reverse l) ) (prompt "\nSelect overlapping group of blocks...") (setq s (ssget "_:L" '((0 . "INSERT")))) (initget 4) (setq g (getdist "\nPick or specify gap distance <0.0> : ")) (if (null g) (setq g 0.0) ) (if s (progn (setq i (sslength s)) (setq m (dispositionmatrix i)) (repeat i (setq l (cons (list (acet-ent-geomextents (setq b (ssname s (setq i (1- i))))) b) l)) ) (setq c (mapcar (function (lambda ( x ) (/ x (length l)))) (apply (function mapcar) (cons (function +) (mapcar (function (lambda ( x y ) (mapcar (function (lambda ( a b ) (/ (+ a b) 2))) x y))) (mapcar (function caar) l) (mapcar (function cadar) l)))))) (setq k 0) (foreach r m (foreach v r (if (= v 1) (setq rn (cons (nth k l) rn) k (1+ k)) (setq rn (cons nil rn)) ) ) (setq mn (cons (reverse rn) mn) rn nil) ) (setq mn (reverse mn)) (setq w (apply (function max) (mapcar (function (lambda ( x ) (apply (function +) (mapcar (function (lambda ( y ) (if y (abs (- (car (cadr (car y))) (car (car (car y))))) 0.0))) x)))) mn))) (setq h (apply (function max) (mapcar (function (lambda ( x ) (apply (function +) (mapcar (function (lambda ( y ) (if y (abs (- (cadr (cadr (car y))) (cadr (car (car y))))) 0.0))) x)))) (apply (function mapcar) (cons (function list) mn))))) (setq bp (mapcar (function -) c (list (+ (/ w 2) (/ (* (1- (length (car m))) g) 2)) (+ (/ h 2) (/ (* (1- (length m)) g) 2))))) (setq rh 0.0) (foreach rn mn (setq bp (mapcar (function +) bp (list 0.0 rh))) (setq rh 0.0) (foreach vn rn (if vn (progn (vla-move (vlax-ename->vla-object (cadr vn)) (vlax-3d-point (caar vn)) (vlax-3d-point bp)) (setq bp (mapcar (function +) bp (list (+ g (abs (- (car (cadr (car vn))) (car (car (car vn)))))) 0.0))) ) ) (if (and vn (< rh (+ g (abs (- (cadr (cadr (car vn))) (cadr (car (car vn)))))))) (setq rh (+ g (abs (- (cadr (cadr (car vn))) (cadr (car (car vn))))))) ) ) (setq bp (subst (- (car c) (+ (/ w 2) (/ (* (1- (length (car m))) g) 2))) (car bp) bp)) ) ) ) (princ) )
I changed  block  selection -> polyline
But i want to  align by area
Small size -> big size
Sorry many ask
How can i modify that ?
« Last Edit: July 08, 2022, 11:37:48 AM by dussla »
ribarm
  • Marko Ribar, architect
Re: To Modify Block align lisp by ribam
« Reply #1 on: July 08, 2022, 11:28:18 AM »
So what if it's black background... I was experimenting with HTML options...
Ako bas hoces, evo neceg novog...
  1. (defun c:rhomb ( / *error* rec gr p a b p1 p2 p3 p4 )
  2.
  3.
  4.   (defun *error* ( m )
  5.     (if m
  6.       (prompt m)
  7.     )
  8.     (princ)
  9.   )
  10.
  11.     (list
  12.       (cons 0 "CIRCLE")
  13.       (list 10 0.0 0.0 0.0)
  14.       (list 40 1.0)
  15.     )
  16.   )
  17.   (setq rec
  18.     (entmakex
  19.       (list
  20.         (cons 0 "LWPOLYLINE")
  21.         (cons 100 "AcDbEntity")
  22.         (cons 100 "AcDbPolyline")
  23.         (cons 90 4)
  24.         (cons 70 (1+ (* 128 (getvar 'plinegen))))
  25.         (cons 38 0.0)
  26.         (list 10 0.0 0.0)
  27.         (list 10 1.0 0.0)
  28.         (list 10 1.0 1.0)
  29.         (list 10 0.0 1.0)
  30.         (list 210 0.0 0.0 1.0)
  31.       )
  32.     )
  33.   )
  34.   (while (/= 3 (car (setq gr (grread t))))
  35.     (setq p (cadr gr))
  36.     (setq a (angle (list 0.0 0.0) p))
  37.     (setq b (+ a (* 0.25 pi)))
  38.     (setq p1 (list 0.0 0.0) p2 (list (cos a) (sin a)) p3 (polar (list 0.0 0.0) b (+ (sqrt 2.0) (* (- 2.0 (sqrt 2.0)) (/ (* 0.25 pi) a)))) p4 (list (sin a) (cos a)))
  39.     (entupd (cdr (assoc -1 (entmod (mapcar (function (lambda ( x y ) (if (= (car x) 10) (cons 10 y) x))) (entget rec) (list p1 p2 p3 p4))))))
  40.   )
  41.   (*error* nil)
  42. )
  43.
M.R.
M.R. on Youtube
« Reply #2 on: July 08, 2022, 11:53:46 AM »
Huh?! You alright ribarm (that response doesn't make sense)?
ribarm
« Reply #3 on: July 08, 2022, 01:20:17 PM »
(defun c:rhomb ( / *error* rec recx gr p a b p1 p2 p3 p4 k )
    (if m
      (prompt m)
  (entmake
    (list
      (cons 0 "CIRCLE")
      (cons 40 1.0)
  (setq rec
    (entmakex
      (list
        (cons 90 4)
        (cons 38 0.0)
        (list 10 0.0 0.0)
        (list 10 1.0 0.0)
        (list 10 1.0 1.0)
        (list 10 0.0 1.0)
  (setq recx (entget rec))
  (vla-zoomwindow (vlax-get-acad-object) (vlax-3d-point (list -2.0 -2.0)) (vlax-3d-point (list 2.0 2.0)))
    (setq p (cadr gr))
    (setq aa (rem a (* 0.5 pi)))
    (setq p1 (list 0.0 0.0))
    (setq p3 (polar (list 0.0 0.0) b (+ (sqrt 2.0) (* (- 2.0 (sqrt 2.0)) (progn (if (> aa (* 0.25 pi)) (if (< (- (* 0.25 pi) (- aa (* 0.25 pi))) 0.0) (abs (- (* 0.25 pi) (- aa (* 0.25 pi)))) (- (* 0.25 pi) (- aa (* 0.25 pi)))) aa))))))
    (setq p2 (polar (list (/ (car p3) 2.0) (/ (cadr p3) 2.0)) (- b (* 0.5 pi)) (- (/ (sqrt 2.0) 2.0) (* (/ (sqrt 2.0) 2.0) (progn (if (> aa (* 0.25 pi)) (if (< (- (* 0.25 pi) (- aa (* 0.25 pi))) 0.0) (abs (- (* 0.25 pi) (- aa (* 0.25 pi)))) (- (* 0.25 pi) (- aa (* 0.25 pi)))) aa))))))
    (setq p4 (polar (list (/ (car p3) 2.0) (/ (cadr p3) 2.0)) (+ b (* 0.5 pi)) (- (/ (sqrt 2.0) 2.0) (* (/ (sqrt 2.0) 2.0) (progn (if (> aa (* 0.25 pi)) (if (< (- (* 0.25 pi) (- aa (* 0.25 pi))) 0.0) (abs (- (* 0.25 pi) (- aa (* 0.25 pi)))) (- (* 0.25 pi) (- aa (* 0.25 pi)))) aa))))))
    (setq k nil)
    (entupd (cdr (assoc -1 (entmod (setq recx (mapcar (function (lambda ( x ) (if (= (car x) 10) (progn (setq k (if (not k) 0 (1+ k))) (cons 10 (nth k (list p1 p2 p3 p4)))) x))) recx))))))
  (*error* nil)
;;; Sta je starije, rhomb, square, rectangle ili jaje... Sunce ili svetionik, borac ili vekovnik...
;;; Pa naravno, odlucite sami, ali i pored toga postoje i others cudi...
;;; Sto se tice trojstva covek, pas, macka ili Bog, sin, znacka... Otkucaje povezuje i predskazuje godisnjak sveta svetova slave...
;;; E sad, ovo sa tornadima je egzibicija na ksi, pa posto je Bogu draza od psi, onda je i lambda sama kao fama, a gamma prazna kao tama...
« Last Edit: July 17, 2022, 12:04:50 PM by ribarm »
M.R. on Youtube
