\r\n
Open the file in Notepad++ and perform the following find/replacements:
Quote from: Lee Mac on July 06, 2022, 08:39:49 AMOpen the file in Notepad++ and perform the following find/replacements:Thanks Lee Mac SirIn the Notepad++ works but if there will be a Route that could do faster
Is this an editor question or a Lisp question? -i.e. should this be moved to the general programming forum?
Open Notepad of below
You can record the operations as a macro in Notepad++ so that everything can be performed with a single keyboard shortcut.
Quote from: JohnK on July 06, 2022, 03:34:01 PMIs this an editor question or a Lisp question? -i.e. should this be moved to the general programming forum?I wasn't sure either - I only tended toward editor because the OP mentioned this:Quote from: mohan on July 06, 2022, 02:22:02 AMOpen Notepad of below
Quote from: JohnK on July 06, 2022, 03:34:01 PMIs this an editor question or a Lisp question? -i.e. should this be moved to the general programming forum?At any rate your suggestion is library worthy for me. Good starting point!!
