Author Topic: How to draw?  (Read 1352 times)
masao
How to draw?
« on: July 03, 2022, 10:45:35 AM »
How to draw center line?
didier
  • expatrié
Re: How to draw?
« Reply #1 on: July 03, 2022, 12:04:42 PM »
Bonjour
I would say that the centerline command is perfect, but you should know more about the qualities of your entities if this native command is not the solution.
Amicalement
eternal beginner ...
my english is not fluent ...
Tharwat
  • Hypersensitive
Re: How to draw?
« Reply #2 on: July 03, 2022, 12:44:42 PM »
Use getpoint & getcorn functions then create the center lines based on width & length of the imaginary rectangle.
Re: How to draw?
« Reply #3 on: July 03, 2022, 06:53:06 PM »
I would suggest something like this:
  1. (defun c:cl ( / i l s x )
  2.     (if (setq s (ssget '((0 . "LINE"))))
  3.         (progn
  4.             (repeat (setq i (sslength s))
  5.                 (setq i (1- i)
  6.                       x (entget (ssname s i))
  7.                       l (vl-list* (cdr (assoc 10 x)) (cdr (assoc 11 x)) l)
  8.                 )
  9.             )
  10.             (setq l (mapcar '(lambda ( x ) (apply 'mapcar (cons x l))) '(min max)))
  11.             (entmake
  12.                 (list
  13.                    '(0 . "LINE")
  14.                     (list 10 (caar  l) (/ (+ (cadar l) (cadadr l)) 2.0))
  15.                     (list 11 (caadr l) (/ (+ (cadar l) (cadadr l)) 2.0))
  16.                 )
  17.             )
  18.             (entmake
  19.                 (list
  20.                    '(0 . "LINE")
  21.                     (list 10 (/ (+ (caar l) (caadr l)) 2.0) (cadar  l))
  22.                     (list 11 (/ (+ (caar l) (caadr l)) 2.0) (cadadr l))
  23.                 )
  24.             )
  25.         )
  26.     )
  27.     (princ)
  28. )
masao
Re: How to draw?
« Reply #4 on: July 04, 2022, 08:31:17 AM »
  3.         (progn
  5.                 (setq i (1- i)
  8.                 )
  9.             )
  11.             (entmake
  12.                 (list
  13.                    '(0 . "LINE")
  16.                 )
  17.             )
  18.             (entmake
  19.                 (list
  20.                    '(0 . "LINE")
  23.                 )
  24.             )
  25.         )
  26.     )
  27.     (princ)
  28. )
Lee Mac thank you so much! :-D
but i can't understand this LISP now. :cry:
this LISP can add else? for example LWpolyline or circle.
dexus
Re: How to draw?
« Reply #5 on: July 04, 2022, 10:07:24 AM »
Maybe these comments will help understanding the code better and you can try to change it to your needs:
  2.     (if (setq s (ssget '((0 . "LINE")))) ; Create selectionset (ssget), only valid entrys are lines
  3.         (progn
  4.             (repeat (setq i (sslength s)) ; Repeat over the amount of items in the selectionset
  5.                 (setq i (1- i) ; Use a counter to iterate over the selectionset
  6.                       x (entget (ssname s i)) ; Get the dxf data of object i
  7.                       l (vl-list* (cdr (assoc 10 x)) (cdr (assoc 11 x)) l) ; Add the start point and end point to the start of a list (l)
  8.                 )
  9.             )
  10.             ; This one is complicated, but it compares all the coordinates and gets the lowest and highest x and y values in the saved list (l)
  11.             ; It creates an array which goes like this:
  12.             ; '(
  13.             ;   (lowest-x lowest-y)
  14.             ;   (highest-x highest-y)
  15.             ; )
  16.             (setq l (mapcar '(lambda ( x ) (apply 'mapcar (cons x l))) '(min max)))
  17.             (entmake ; Create a new object
  18.                 (list
  19.                    '(0 . "LINE") ; type line
  20.                     (list 10 ; start point of line
  21.                       (caar  l) ; lowest x value
  22.                       (/ (+ (cadar l) (cadadr l)) 2.0) ; lowest + highest y value and divide by 2. So this is the average height
  23.                     )
  24.                     (list 11 ; end point of line
  25.                       (caadr l) ; highest x value
  26.                       (/ (+ (cadar l) (cadadr l)) 2.0) ; same formula as above
  27.                     )
  28.                 )
  29.             )
  30.             (entmake ; Create the other line, but flip x and y
  31.                 (list
  32.                    '(0 . "LINE")
  33.                     (list 10 (/ (+ (caar l) (caadr l)) 2.0) (cadar  l))
  34.                     (list 11 (/ (+ (caar l) (caadr l)) 2.0) (cadadr l))
  35.                 )
  36.             )
  37.         )
  38.     )
  39.     (princ)
  40. )
[/quote]
Re: How to draw?
« Reply #6 on: July 04, 2022, 05:12:59 PM »
Great explanation dexus  :-)
