Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Routine hangs just a bit with text selection ListTiledepedencyV1-1.lsp
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Routine hangs just a bit with text selection ListTiledepedencyV1-1.lsp (Read 140 times)
jlogan02
Bull Frog
on:
June 17, 2022, 12:47:48 PM »
Lee Mac helped me with this routine to insert blocks selected from a dual column dialog box. It's hanging ever so slightly after selecting the text to edit. Looking to see if anyone else is getting that same behavior.
I've provided a block "Approval-NA-SL" and the ListTileDependencyV1-1.lsp to go along with the quoted code in the post.
Code - Auto/Visual Lisp:
[Select]
defun
c:StampIns
*error*
osm dch dcl des str lst rtn ss hnd
defun
*error*
msg
if
'file
type
des
close
des
if
0
dch
unload_dialog
dch
if
and
'str
type
dcl
findfile
dcl
vl-file-delete
dcl
if
and
msg
not
wcmatch
strcase
msg t
"*break,*cancel*,*exit*"
princ
strcat
\n
Error: "
msg
princ
setq
lst
"Static"
"Approval-NA-SL"
"Approval-Schem-ACDC"
"Approval-NA-PLO"
"Approval-NA-ND"
"Note_RemRet"
"Note_RemOnly"
"Note_RefOnly"
"Note_RefDwgNum"
"User"
"Note_Rev_NewDwg"
"Note_Rev_ExistDwg"
"Note_Delta_Revision"
if
and
setq
dcl
vl-filename-mktemp
"tmp.dcl"
setq
des
open
dcl
"w"
foreach
str
"lbx : list_box"
" alignment = centered;"
" fixed_width = true;"
" fixed_height = true;"
" width = 30;"
" height = 15;"
"test : dialog"
" label =
Annotation
" spacer;"
" : row"
" : lbx { key =
lb0
; label =
Insert
" : lbx { key =
lb1
; label =
Annotation
" spacer;"
" ok_cancel;"
write-line
str des
not
setq
des
close
des
0
setq
dch
load_dialog
dcl
new_dialog
"test"
dch
progn
setq
rtn '
0
0
LM:dcld:action '
"lb0"
"lb1"
'lst 'rtn
setq
Osm
getvar
'osmode
if
1
start_dialog
progn
setq
rtn
LM:dcld:getitems rtn lst
command
"osmode"
1
command
"_.-insert"
cadr
rtn
"_S"
getvar
'dimscale
"_R"
0.0
if
"Static"
car
rtn
command
"_non"
0
0
command
command
"._explode"
"_l"
if
and
setq
ss
ssget
setq
i
1
repeat
sslength
ss
setq
hnd
ssname
ss
setq
i
1+
i
command
"_textedit"
hnd
command
"_change"
hnd
"P"
"C"
"1"
princ
\n
*Cancel*"
setvar
'osmode Osm
*error*
nil
princ
Command: Stampins
Select the Approval-NA-SL from the list
Text edit command launches
User edits the text
hits enter
Text changes from brown to red.
Logged
J. Logan
ACAD 2018
I am one with the Force and the Force is with me.
AutoCAD Map 2018 Windows 10
jlogan02
Bull Frog
Re: Routine hangs just a bit with text selection ListTiledepedencyV1-1.lsp
Reply #1 on:
June 21, 2022, 03:41:01 PM »
May have solved the issue. I had a comment in my lisp description that didn't have the (;
in front of it. That particular line usually says ;;command: Stampins
Logged
J. Logan
ACAD 2018
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
