Author Topic: vla-getboundingbox of a block of multileader  (Read 767 times)
AARYAN
« on: June 14, 2022, 04:38:15 AM »
Hi All,
I am writing a routine and stuck at a point where I need to get the bounding box of a block created with multileader.
1. Setup the mleaderstyle.
2. Inserted Mleader using lisp.
3. (entnext (entlast)) returns nil. Anyway to get the limits?
Thank you in advance for your help!
« Last Edit: June 14, 2022, 10:04:01 AM by AARYAN »
mhupp
Re: vla-getboundingbox of a block of multileader
« Reply #1 on: June 14, 2022, 07:20:17 AM »
Post your code if you want help with it.
kreaten_vhar
  • Mosquito
  • Professional Forum Lurker
« Reply #2 on: June 14, 2022, 08:06:06 AM »
I had a similar desire in a recent routine I've been working on. I found Lee Mac's Bounding box function http://www.lee-mac.com/boundingbox.html
Using that function in a call like so:
(LM:boundingbox (vlax-ename->vla-object (cdar (entget (entlast)))))
will get you the 4 points that make up the bounds of the most recently added object.
edit:
is probably the heart of what you want I'm guessing. As I had a similar experience using (entget (entlast)) not returning what I wanted because I wasn't aware what was going on in the background with regards to the Acad DB. Worth noting I still don't and I'm not sure how mleaders are handled lol
« Last Edit: June 14, 2022, 08:18:22 AM by kreaten_vhar »
AARYAN
« Reply #3 on: June 14, 2022, 08:32:42 AM »
Thanks for the reply guys!
I am simply using the command option to insert the multileader.
(command "_.MLeader" pt1 pt2)
(while (> (getvar "cmdactive") 1) (command ""))
(setq emleader (entlast))
(setq eblock (entnext emleader)) ; return nil.
I know the last line is not correct, I am looking to just get extent of the block that is drawn with multileader. The MleaderStyle content type is block. I believe I can use that block name to insert in the drawing and get the extent but the user can make changes to the block scale in the multileaderstyle and therefore, I assume its best to select the block that is drawn with multileader (which will have all settings applied e.g. scale) and get its extent. I will be adding the same block multiple times vertically or horizontally.
P.S. (vlax-ename->vla-object (cdar (entget (entlast)))) gives me the mleader and not the block.
Thank you!
kreaten_vhar
  • Mosquito
« Reply #4 on: June 14, 2022, 08:39:28 AM »
Hmm, yeah, I'm not too sure lol.
Could Entsel be of any use to you? It would prompt you to select the block outright.
mhupp
« Reply #5 on: June 14, 2022, 12:50:03 PM »
  1. (command "_.MLeader" pt1 pt2)
  2. (setq emleader (car (entlast))) ;this will get the entity name
  3.
that is all you need.
  1. (setq eblock (entnext emleader))
is nil because the last entity is emleader their isn't anything after it.
mhupp
« Reply #6 on: June 14, 2022, 01:13:25 PM »
  1. (setq mleader (vlax-invoke (vlax-ename->vla-object (car (entlast)))) 'explode))
  2.     (foreach ent mleader
  3.       (if (eq (vla-get-Objectname ent) "AcDbBlockReference")
  4.         (progn
  5.           (setq x (vla-get-XScaleFactor ent))
  6.           (setq y (vla-get-YScaleFactor ent))
  7.           (setq z (vla-get-ZScaleFactor ent))
  8.         )
  9.       )
  10.       (vla-delete ent)
  11.     )
This makes a copy of the mleader and explodes it. then steps thought each entity and if its a block pulls the scale factors for x y and z.
« Last Edit: June 14, 2022, 08:31:20 PM by mhupp »
AARYAN
« Reply #7 on: June 15, 2022, 12:10:14 AM »
vla-explode does not work with multileader objects. I tried already, any other method?
(setq sblock (vla-insertblock vspace (vlax-3d-point (cdr (assoc 15 (entget emleader)))) block scale scale scale rotation))
(setq icount 0)
(foreach satt (vlax-safearray->list (vlax-variant-value (vla-getattributes sblock)))
 (if (= icount 0)
  (vla-put-textstring satt "test")
  (vla-put-textstring satt ""))
 (setq icount (1+ icount)))
(vla-getboundingbox sblock 'lminpt 'lmaxpt)
(vla-delete sblock)
This is the best solution I could see so far. Inserting the block, apply the scale from the multileader style and getting the limits and finally delete the block that created.
Thanks for your inputs!
mhupp
« Reply #8 on: June 15, 2022, 12:21:52 AM »
Your right its probably because the leader is a anonymous type block.
prob easier to get the scale and block name with visual lisp.
  1. (setq mleader (vlax-ename->vla-object (car (entlast))))
  2. (setq scale (vla-get-ArrowheadSize mleader))
  3. (setq blkname (vla-get-arrowheadblock mleader))
« Last Edit: June 15, 2022, 12:51:15 AM by mhupp »
AARYAN
« Reply #9 on: June 15, 2022, 03:22:52 AM »
vla-get-arrowheadblock returns ""
I am not changing the arrow head to block. The actual content type is a block. The code I wrote (see above) did the job and I was expecting the bounding box without having to add, get the box and delete the block.
Thanks!
mhupp
« Reply #10 on: June 15, 2022, 07:27:37 AM »
Thanks!
that means the mleader doesn't have a block for the arrowhead. Its probably only a solid or a hatch.
