Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Visual DCL Programming
OpenDCL
Topic:
dcl-TextBox-SetSel looks like it doesn't work
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: dcl-TextBox-SetSel looks like it doesn't work (Read 1002 times)
domenicomaria
Bull Frog
on:
June 10, 2022, 04:14:54 AM »
(dcl-TextBox-SetSel dgs-prj dgs-frm "textbox" 0 -1)
dcl-TextBox-SetSel
looks like it
doesn't work
doesn't select text
doesn't select anything !
is there anyone who has experienced the same problem ?
Logged
owenwengerd
Bull Frog
WWW
Re: dcl-TextBox-SetSel looks like it doesn't work
Reply #1 on:
June 10, 2022, 12:33:06 PM »
The string "textbox" is invalid. Perhaps you intended this:
Code - Auto/Visual Lisp:
[Select]
dcl
Control
SetText dgs
prj
"textbox"
dcl
TextBox
SetSel dgs
prj dgs
frm
0
1
Logged
Owen Wengerd @
Outside The Box
ManuSoft
CADLock, Inc.
domenicomaria
Bull Frog
Reply #2 on:
June 10, 2022, 01:42:20 PM »
dgs-prj
is the variabile that contains the name of the odcl
project
while
dgs-frm
form
and
"textbox"
is the name of the
textbox control
Last Edit: June 10, 2022, 01:56:56 PM by domenicomaria
Logged
owenwengerd
Bull Frog
WWW
Reply #3 on:
June 10, 2022, 05:25:42 PM »
Ah, I see, you use strings instead of symbols to refer to the control. In that case, maybe the failure is related to the context in which the function is called. Does it work in a button clicked event?
Logged
Owen Wengerd @
Outside The Box
ManuSoft
CADLock, Inc.
domenicomaria
Bull Frog
Reply #4 on:
June 11, 2022, 01:47:32 AM »
It is called at ON-INITIALIZE event
Logged
domenicomaria
Bull Frog
Reply #5 on:
June 11, 2022, 02:15:30 AM »
[Select]
defun
:DCL
GETSTRING
title description default left
top
lst
dgs
frm
dgs
prj default description r
string title
defun
c:DCL
GETSTRING
ONINITIALIZE
dcl
control
setcaption
dgs
prj
dgs
frm
"title"
title
dcl
control
setcaption
dgs
prj
dgs
frm
"description"
description
dcl
control
settext
dgs
prj
dgs
frm
"textbox"
default
dcl
TextBox
SetSel
dgs
prj
dgs
frm
"textbox"
0
1
dcl
Control
SetFocus
dgs
prj
dgs
frm
"textbox"
defun
C:DGS
OK
setq
r
string
dcl
control
gettext
dgs
prj
dgs
frm
"textbox"
dcl
form
close
dgs
prj
dgs
frm
defun
C:DGS
ONRETURNPRESSED
setq
r
string
dcl
control
gettext
dgs
prj
dgs
frm
"textbox"
dcl
form
close
dgs
prj
dgs
frm
defun
C:DGS
CANCEL
setq
r
string
nil
dcl
form
close
dgs
prj
dgs
frm
setq
dgs
prj
"dcl-getstring"
dgs
frm
"dcl-getstring-frm"
dcl
loadproject
dgs
prj t
cond
and
left
top
lst
listp
left
top
lst
dcl
form
show
dgs
prj
dgs
frm
car
left
top
lst
cadr
left
top
lst
left
top
lst T
setq
left
top
lst
dcl
getmousecoords
dcl
form
show
dgs
prj
dgs
frm
car
left
top
lst
cadr
left
top
lst
T
dcl
form
show
dgs
prj
dgs
frm
r
string
defun
c:k
setq
mc
dcl
getmousecoords
left
nth
0
mc
top
nth
1
mc
r
:DCL
GETSTRING
"... NEW SUB-MENU NAME ..."
" enter the new sub menu name, below :"
"[ M E N U 0 1 ]"
list
left top
r
Last Edit: June 11, 2022, 02:19:40 AM by domenicomaria
Logged
domenicomaria
Bull Frog
Reply #6 on:
June 11, 2022, 10:26:03 AM »
It depends from the
control tab order
if I put the textbox control
in the
first position
everything works well !
Logged
owenwengerd
Bull Frog
WWW
Reply #7 on:
June 11, 2022, 10:32:36 AM »
I see you discovered a solution while I was composing a reply. Posting anyway in case it is useful in the future.
-- snip --
I suppose your call happens too early, and either gets undone by following initialization by the form itself, or the control just doesn't process selection methods before it is visible. You might try delaying the call by setting a timer and doing it from the timer event; or make this the first control in the form's tab order so the dialog does the work for you when it sets initial focus to the textbox.
Logged
Owen Wengerd @
Outside The Box
ManuSoft
CADLock, Inc.
domenicomaria
Bull Frog
Reply #8 on:
June 11, 2022, 10:43:09 AM »
or make this the first control in the form's tab order"
I think this is the simplest thing ...
thanks for your attention, Owen ...
Ciao
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
OpenDCL
Topic:
