Goodeverning everybody, i'm learning ObjectARX and i got a question.
So i have a class definition like image[1]
then inside this class a have AcDbObjectPointer<AcDbLine> variables and i do not declare the class destructor( use default)
In the command.cpp file, i created instance of above class like Image[2]
so , my question is when "panelObj" come out of its scope . all object controled by above smartpointers is auto close(Database object) / delete (not database object) ?
And this way is safe from memory leak ?
Thank you in advance!
