Author Topic: Sorting by point number  (Read 974 times)
milanp
« on: May 27, 2022, 02:50:44 AM »
I use this lisp to export points in the format (pt, y, x, z). Is it possible to sort points by the number of points in ascending order?
 Thanks!
defun C:eksport ()
(SETVAR "OSMODE" 0)
(setq F (OPEN (GETFILED "Sacuvaj" "g:/" "txt" 1) "w"))
(setq SSS (SSGET (list (cons 0 "POINT") (cons 8 "Detaljne_tacke"))))
(setq SSSL (SSLENGTH SSS))
(setq CONT 0)
(repeat sssl
(setq ENAME3 (SSNAME SSS CONT))
(setq PPP (ENTGET ENAME3 '("Milan")))
(setq COORD (CDR (ASSOC 10 (CDR PPP))))
(setq X (CAR COORD))
(setq Y (CADR COORD))
(setq Z (CADDR COORD))
(setq NUMTXT (CDR (CADR (CAR (CDR (ASSOC -3 (CDR PPP)))))))
(WRITE-LINE (STRCAT NUMTXT "," (RTOS X 2 3) "," (RTOS Y 2 3)"," (RTOS Z 2 3)) F)
(setq CONT (1+ CONT))
 );_end repeat
(CLOSE F)
(alert "Gotovo!")
« Last Edit: May 27, 2022, 02:58:27 AM by milanp »
BIGAL
  • 40 + years of using Autocad
Re: Sorting by point number
« Reply #1 on: May 27, 2022, 04:27:40 AM »
Ok 1st step is make a list of ptnum X Y Z etc ((1 23.345 45.678 123.45)(2 ...........
You can sort point number in a list via Vl-sort, one little hiccup is the way it sorts the number like 1 10 100 will be in order not 1-10 11-100.
There is some better sort routines out there google maybe start with Lee-mac in search.
Will try to find.
Your just taking in what ever order the selection returns.
milanp
« Reply #2 on: May 27, 2022, 05:55:30 AM »
Thanks for the prompt reply. I'll try to find it.  :-)
mhupp
« Reply #3 on: May 27, 2022, 10:17:31 AM »
depending on how may points you have and if its a string or integer. changing 1-9 to 01-09
  1. (setq ptnum (strcat (if (< (read ptnum) 10) "0" "") ptnum)) ;if ptnum is a string
  2. (setq ptnum (strcat (if (< ptnum 10) "0" "") (itoa ptnum))) ;if ptnum is a integer
« Last Edit: May 27, 2022, 07:44:39 PM by mhupp »
Tharwat
  • Hypersensitive
« Reply #4 on: May 27, 2022, 10:19:52 AM »
First off, create a list consists of your data then after that sort them based on the number of each point object then finally export them to your target file format.
eg:
  1. (setq lst (cons (list NUMTXT x y z) lst))
  2. (setq lst (vl-sort lst '(lambda (j k) (< (car j) (car k)))))
  3. (foreach itm lst
  4.   (WRITE-LINE (STRCAT (car itm) "," (RTOS X 2 3) "," (RTOS Y 2 3) "," (RTOS Z 2 3)) F)
  5.   )
  6.
« Last Edit: May 27, 2022, 10:23:24 AM by Tharwat »
milanp
« Reply #5 on: May 27, 2022, 11:28:55 AM »
Thanks to everyone for the instructions. I tried to export but now i get duplicate names with the same coordinates. I'm not doing something right. Here is an example of a  point file. Thanks a lot
Tharwat
  • Hypersensitive
« Reply #6 on: May 27, 2022, 12:07:41 PM »
Give this a shot and let me know.
  1.    ;; https://www.theswamp.org/index.php?topic=57600.msg610125#msg610125
  2. (defun c:Test (/ *error* txt opn sel int lst get)
  3.   ;;------------------------------------------------------------;;
  4.   ;;    Author: Tharwat Al Choufi - Date: 27.May.2022           ;;
  5.   ;;    website: https://autolispprograms.wordpress.com         ;;
  6.   ;;------------------------------------------------------------;;
  7.   (defun *error* (m)
  8.     (and opn (close opn))
  9.     (princ "\n*Cancel*")
  10.   )
  11.   (and
  12.     (princ
  13.       "\nSelect point objects on layer 'Detaljne_tacke' to export to text file : "
  14.     )
  15.     (setq int -1
  16.           sel (ssget
  17.                 '((0 . "POINT") (8 . "Detaljne_tacke") (-3 ("Milan")))
  18.               )
  19.     )
  20.     (while (setq int (1+ int)
  21.                  ent (ssname sel int)
  22.            )
  23.       (and (setq get (entget ent '("Milan")))
  24.            (numberp
  25.              (atoi (setq inc (cdr (cadar (cdr (assoc -3 get))))))
  26.            )
  27.            (setq lst (cons (list inc (cdr (assoc 10 get))) lst))
  28.       )
  29.     )
  30.     (setq
  31.       lst (vl-sort lst
  32.                    '(lambda (j k) (< (atoi (car j)) (atoi (car k))))
  33.           )
  34.     )
  35.     (setq txt (getfiled "Sacuvaj" "g:/" "txt" 1))
  36.     (setq opn (open txt "w"))
  37.     (foreach itm lst
  38.       (write-line
  39.         (vl-string-trim
  40.           " , "
  41.           (apply
  42.             'strcat
  43.             (append (list (car itm) " , ")
  44.                     (mapcar '(lambda (u) (strcat (rtos u 2 3) " , "))
  45.                             (cadr itm)
  46.                     )
  47.             )
  48.           )
  49.         )
  50.         opn
  51.       )
  52.     )
  53.     (setq opn (close opn))
  54.   )
  55.   (princ)
  56. )
  57.
« Last Edit: May 27, 2022, 12:29:28 PM by Tharwat »
milanp
« Reply #7 on: May 27, 2022, 12:24:01 PM »
Here is the txt file ....
1 , 7550478.101 , 4945540.066 , 72.56
10 , 7550485.716 , 4945515.14 , 73.47
100 , 7550526.529 , 4945458.405 , 78.121
101 , 7550530.971 , 4945452.037 , 78.027
102 , 7550530.579 , 4945451.796 , 78.097
103 , 7550532.556 , 4945450.007 , 78.201
104 , 7550532.077 , 4945449.761 , 78.229
105 , 7550533.835 , 4945447.392 , 78.425
106 , 7550532.768 , 4945447.153 , 78.45
107 , 7550534.469 , 4945444.179 , 78.647
108 , 7550533.453 , 4945443.098 , 78.805
109 , 7550534.099 , 4945441.779 , 78.838
11 , 7550483.956 , 4945514.682 , 73.564
110 , 7550533.406 , 4945439.933 , 79.059
111 , 7550531.335 , 4945437.153 , 79.283
112 , 7550529.983 , 4945438.052 , 79.401
113 , 7550529.713 , 4945436.949 , 79.421
114 , 7550527.222 , 4945437.342 , 80.178
115 , 7550523.734 , 4945433.223 , 80.636
116 , 7550525.315 , 4945433.815 , 80.392
117 , 7550524.785 , 4945432.008 , 80.26
118 , 7550526.185 , 4945433.192 , 79.959
119 , 7550527.87 , 4945433.204 , 79.789
12 , 7550478.939 , 4945514.299 , 73.632
I tried it and the points are not exported again in order ... maybe I'm not doing something properly? Thanks
Tharwat
  • Hypersensitive
« Reply #8 on: May 27, 2022, 12:30:38 PM »
Sorry, I did not test the codes before posting, now codes updated above please try again.
milanp
« Reply #9 on: May 27, 2022, 12:55:38 PM »
now it works properly...
1,7550478.101,4945540.066,72.56
2,7550483.135,4945537.879,72.475
3,7550486.67,4945538.48,72.659
4,7550481.461,4945529.178,72.851
5,7550479.765,4945528.411,73.061
6,7550485.063,4945524.219,73.018
7,7550487.326,4945525.985,73.027
8,7550487.859,4945523.472,73.118
9,7550483.759,4945522.294,73.098
10,7550485.716,4945515.14,73.47
11,7550483.956,4945514.682,73.564
12,7550478.939,4945514.299,73.632
13,7550473.375,4945511.98,73.871
14,7550465.426,4945508.804,74.313
15,7550466.095,4945507.922,74.497
16,7550468.645,4945507.781,74.738
17,7550468.716,4945503.594,74.815
18,7550466.162,4945503.536,74.781
19,7550465.11,4945500.01,74.895
20,7550465.893,4945499.035,75.059
21,7550465.964,4945497.009,75.198
Thank you all for the suggestions and especially to you Tharwat...thank you for your time and help
Tharwat
  • Hypersensitive
« Reply #10 on: May 27, 2022, 05:09:21 PM »
You're most welcome.
