Author Topic: Dynamic block extraction values, visibility parameter  (Read 760 times)
Giuseppe Beatrice
« on: May 23, 2022, 05:56:35 AM »
Hi guys, happy to meet you.
I have a problem with a dynamic block definition for which I can't extract the list of its visibility values, for which I have often used the successfully attached Lisp file.
I am also attaching a drawing with 3 block definitions, all containing only the "Visibility" parameter.
With the block definitions "Presa" and "Puntoluce" the program works perfectly, while with the definition "Comando" it returns nil.
Can anyone help me understand the problem?
Thank you all
mhupp
Re: Dynamic block extraction values, visibility parameter
« Reply #1 on: May 23, 2022, 11:49:21 AM »
Reason the other two work and that one doesn't is block names are case sensitive and it needs upper case C.
  1. (setq vis1 (ESTR_VALPARAM_DYNBLKDEF "Presa" "VIS.")) ;matches
  2. (setq vis2 (ESTR_VALPARAM_DYNBLKDEF "punto luce" "VIS.")) ;matches
  3. (setq vis3 (ESTR_VALPARAM_DYNBLKDEF "comando" "VIS.")) ;doesn't match
  4. (setq vis3 (ESTR_VALPARAM_DYNBLKDEF "Comando" "VIS.")) ;matches
« Last Edit: May 23, 2022, 12:00:41 PM by mhupp »
