Hi guys, happy to meet you.
I have a problem with a dynamic block definition for which I can't extract the list of its visibility values, for which I have often used the successfully attached Lisp file.
I am also attaching a drawing with 3 block definitions, all containing only the "Visibility" parameter.
With the block definitions "Presa" and "Puntoluce" the program works perfectly, while with the definition "Comando" it returns nil.
Can anyone help me understand the problem?
Thank you all
