Author Topic: Pls Help - Quick Assign ObjectData to Point  (Read 140 times)
Namae Wa
  • Mosquito
« on: May 23, 2022, 01:12:23 AM »
Hi everyone,
I'm trying to create a GIS shapefile (in AutoCAD Map3D/C3D) from a CAD drawing.
I want to make (or find) a lisp that does quick assign two TEXT Values (manhole elevation) to Object Data ( Data table created from ADEFDATA command)
Here is my idea workflow:
  1. Select two Texts (Ground level and Invert level)
  2. Select destination Point
  3. (automatic): Assign the Higher text value (Ground elevation) to Object Data1
                         Assign the Lower text value (Invert elevation) to Object Data2
Thanks in advance. :embarrassed2:
« Last Edit: May 23, 2022, 05:24:52 AM by Namae Wa »
