Hi everyone,
I'm trying to create a GIS shapefile (in AutoCAD Map3D/C3D) from a CAD drawing.
I want to make (or find) a lisp that does quick assign two TEXT Values (manhole elevation) to Object Data ( Data table created from ADEFDATA command)
Here is my idea workflow:
1. Select two Texts (Ground level and Invert level)
2. Select destination Point
3. (automatic): Assign the Higher text value (Ground elevation) to Object Data1
Assign the Lower text value (Invert elevation) to Object Data2
Thanks in advance.
